2016 Giant ToughRoad SLR2
#276
Quoted: 95 Post(s)
Liked 9 Times
my tyres arrived - I replaced the inner tubes with Continental 28 Slim and saved 50 grams per tube over the original Giant inner tubes - that's 100 grams ! just on inner tubes.
I then installed 700x35 Continental cyclocross speed and man, these tyres are fast !
Got to get used to the 2 finger braking handle. And also the Q factor is quite large - being a three ring crank. But i really love the range of gears the SLR2 provides - you can pretty much nearly ride up anything.
#279
There's a huge amount of clearance. The fork has 2.90in of clearance at the tire, and similar vertically. Amazingly, the rear actually had more horizontally, maybe slightly less vertically.
You should be able to fit any 2.35in tires and possibly still have room for fenders.
#280
I test rode the SLR 2 today and liked it. The things i didn't like and I hope you can advise me are:
- Shimano shifters don't work when hitting the brake since one needs the index finger to shift to smaller sprocket. Google tells me this is a Shimano problem for all their shifters (My current bike has SRAM)
- it has a non-car air valve. i really don't want to have some adapter to get air from a compressor. I doubt they saved any money. I could buy a new tube with a Schrader valve and drill a larger hole, but don't want to buy an expensive new bike and buy new things for it.
- I couldn't find good information on the M315 brakes except they cost $16 (the SLR 1 brakes cost over $100). Not a good sign. I never had hydraulic brakes before, so my little testride didn't tell me much except they didn't work worse than the rim brakes on the Escape 1.
I haven't ridden it yet, but also like the SLR 1. Has much better hardware (and SRAM shifters!). Drawback is the price and that the front sprocket only has 42 teeth (44 for the SLR 1). On my SLR 2 test ride i was able to get into 27th (fastest) gear quickly, so I wouldn't want less. It also seems there are no cranks for 10-speed with more teeth (as an option in case it annoys me later).
I also rode the Escape 1 today, but that is heavier and the skinny tires don't ride well and likley damage the rim on bad streets. I don't go off-road beyond some unpaved trails, so the toughroad is a good bike in general.
Any advice or alleviation of my concerns is appreciated.
#281
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
So if I have to throw away the cheap brakes so that I can put on brakes I am happy with, so be it.
I have already replaced my crank for a Hollowtech II crank with External Bearing BB.
Next on the agenda is new brakes and larger rotors.
I just haven't had any problems or issues with Presta valves, if you want to be able to go to a garage to pump up your tyres, keep a converter in your saddlebag.
#282
ColonelSanders: thanks, that is valid advice. I'm still to have to test the SLR 1, but I think I will like the 2x10 (and SRAM shifters) better. But considering the cost of replacing all what would be needed (basically full drive train and the shifters) I could as well just buy the SLR 1 and be financially better off. I'm right now (and probably few more days) reading all the Sheldon Brown articles to educate myself better. Really great stuff I didn't know despite biking all my life...
I was mentally prepared to look into just buying a good frame and build it myself and pick right away what want. but it seems it is hard to find frames (with enough information etc.). for example i like the SLR 1/2 have the holes to route the hydraulic and cables in the frame. but this may be more to bit then i can chew and may not be economical. Despite my concerns i think Giant did a good job fitting the SLR 1/2.
some more SLR 2 questions:
- did anyone cross-shop it with the SLR 1? and if so what is the conclusion / opinion and why did you chose the one over the other?
- can the wheels (rims) be fitted with tube-less tires? I would consider doing that once the original set wears out. I'm surprised it isn't common yet in a weight- and puncture conscious industry like the bike industry.
#283
Quoted: 5 Post(s)
Hi, I was about to make a new thread but I guess it would be better to ask this here. I am about to buy a new bike which I would be using on country roads and cycle trails (gravel, chippings). I thought that a mountain bike wouldn't be needed as I won't ever be doing real mountain biking and the trails I am going on are mostly in good condition. I was advised these bikes in my price range:
I am thinking of getting the Giant Toughroad SLR2 and would just like people in the know to confirm for me that it would be the best choice? I don't want to have to buy another bike for at least five years or longer so will it be a good longterm choice? Also, would it be okay for going up hills on country roads? Would I need to buy an extra set of tyres to cover both the roads and off-road trails or will the tyres supplied be okay for both?
Thanks
- Giant Toughroad SLR 2 (Told this was the best choice)
- Cube travel
- Cube sl road
- Lapierre cross 300
- Cannondale Quick CX 4 city.
Thanks
#284
Bikes: 2017 Trek DS 4, 2014 Niner RLT 9 [storage], K2 Shadow 9 [indoor trainer]
Quoted: 77 Post(s)
Thanks
- Cube travel
- Cube sl road
Thanks
#285
Quoted: 13 Post(s)
Thanks
- Cube travel
- Cube sl road
Thanks
#286
Quoted: 147 Post(s)
Liked 8 Times
Urban MTBs are a new category. Rigid MTBs designed around a neutral geometry that can handle urban potholed streets and decent off-road trails with equal aplomb.
Why buy two bikes when you can do it with one? That's the Giant TR SLR and Marin Muirwoods. They're designed for casual riders seeking to do more with their bike.
#287
Liked 310 Times
But for me, I tend to be very specific in what I want, so even though I want front and rear racks, the ones on the Giant weren't exactly what I wanted, so I didn't see that as a plus on the SLR 1, but many other folks wouldn't care and be happy with those racks.
The single biggest reason is that I want gear indicators on my shifters and the Sram shifters on the SLR 1 didn't have that.
Now the SLR 2 does have gear indicators, so I like that, but as I plan to update my shifters to XT eventually, again I don't feel bad about junking the cheaper shifters on the SLR 2, as I would, compared to junking the more expensive ones on the SLR 1.
Also, I wanted a crankset that had a trouser guard, so that meant I would need to replace whatever crankset was on either the SLR 1 or 2, but again as the SLR 2's crankset was a much cheaper version, I won't lose any sleep over junking it either.
Then you can throw in that I was curious to see how well Acera and Alivio components work these days, compared to 20 years ago, when I had them on my old 1996 Trek 830.
There was also the opportunity to mess around a bit with a triple crank, to see if it might suit me better than a double crank, before I made the decision to upgrade my crankset.
Now it wouldn't surprise me if my reasons for going with the SLR 2 don't resonate with you and you think the SLR 1 is the better buy. That is a perfectly reasonable point of view.
#288
The SLR 1 & 2 don't have any cables routed through the frame, it looks that way and the bike has a very clean look about it, but that is because they run all the cables on the underside of the downtube and have a plastic guard which serves as a bit of a frame protector and spray protector for you, cover up all the cables.
Can you tell the the routing inder the frame exposes any cable, or if it is one single cable shield? I would prefer not exposed cable as that can corrode and let water into the cable.
#289
Quoted: 5 Post(s)
The Giant Toughroad SLR 2 is definitely the best choice on that list but really they are all good. It will certainly last you 5 years. I suggest you ride the tires it comes with until either they wear out or you cant stand them. You will know by then the kind of tire you want but the stock tires should be fine for mixed use.
Would you have any suggestions in the same price range? I can safely say that I will only be going on country roads and the same cycle trail. I guess I could encounter some mud/potholes. I had thought I was going to get a mountain bike but it would be a bit too cumbersome for going at speed on regular trails
#290
Quoted: 13 Post(s)
Thanks
#291
Quoted: 2975 Post(s)
Liked 1,180 Times
The suspension on these bikes in the ~$1000 range is junk. It's just dead weight doing a whole lot of nothing for the rider.
For the posters desired use, suspension isn't necessary.
#292
Bikes: Giant ToughRoad Giant talon
Quoted: 705 Post(s)
#293
Quoted: 13 Post(s)
That's generally true but I'm afraid it's not entirely correct. That suntour fork isn't junk - it's clearly not designed to handle technical terrain, but does take some of the harshness off a trail that's not always smooth. It's only 63mm travel, so going over the odd root and bumps is a little smoother. I've got a Toughroad and my friend has the Roam, I can tell you from experience that his is a lot smoother ride.
#294
Quoted: 5 Post(s)
#295
Quoted: 13 Post(s)
Liked 310 Times
sorry, I mixed that up witht eh "Escape 1", which has the cables routed through the frame, which I liked.
i will look for that, no gear indicators really would suck. is yours a 2016? (that woudl giv eme hope the 2017 has indicators...
Do you recall if the cranks were the 170 or the 175 mm? That model is offered in both sizes, but the specs don't Make that clear.
As I chose a Large, I got a 175mm crank with the bike. But when I put on new cranks, I chose 170mm cranks and I think I am happier for it.
how well are they? about 20 years ago I hade a bike with Deore, which I liked a lot and held up well. but at the time Acera was only a 7-speed cassette, not is is 9, so much different...
Did you actually go to a double? the 2x10 is new to me, but the more i read about it (and for my riding style) a 2x seems to be better for me. so if you switched I like to hear.
#297
Quoted: 95 Post(s)
Liked 9 Times
Got a new digital bathroom scales and was able to weigh my Toughroad SLR2 - it's 11.4kg. This is with Continental Cyclocross 35c tyres, Continental Race 28 inner tubes, Adamo ISM Attack saddle and Shimano 747 clipless pedals.
The Toughroad has got quite a stretched out geometry - the top tube feels longer than the usual medium - the medium looked like a large with me on it. I exchanged bike with another rider riding a Giant XTC - medium and for awhile i thought he had a 'small' frame in comparison. But i am comfortable on it - actually kind of like the stretched out feeling. I'm 5' 8.5'' and ride a medium in all my bikes.
#298
I recently removed the downtube plastic armor while swapping the brakes.
There's bolts on the underside of the downtube for a bottle cage, should anyone be inclined.
#299
I just bought a Toughroad SLR 1. Now tubes for on the road and the problem of converting to Schrader valve came up again. Did anyone drill a larger hole in the rim? I noticed the rim is relatively narrow and it looks like the 50 mm tires are almost as thick as it is possible for those rims.
my concern with a Schrader valve would be the structural properties of the rim.
i guess I'm almost answering the question on why road bikes etc. often have PResta valves. But wonder if someone uses Schrader on the Toughroad or if you have an opinion of possible problems.
Edit: I found the tubes are relatively rare. I found these for $12 (Schraderversion only $10). Not that I expect lot of tube use. From what I saw CRC and other stores don't even carry that large 700c tubes.
Edit again: anyone used these "self-sealing" tubes?
#300
Liked 310 Times
Why not just stick with the Presta valves?
The Presta valves on my Toughroad means that for the first time in my life I have had a bike with Presta valves, but it has been no big deal.
