The Wacky World of Craigslist and eBay Ads
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Vintage Cannondale mountain bike
"original Odyssey Aerator seatpost tire pump" never seen that before, sounds at least as plausible as the CO2 cartridge in the Hollowtech spindle
Hmmm
Commence to jigglin’ huh?!?!
Liked 1,699 Times
Q: Hello Friend, Where is the piece of carbon from the passage of the cables that is missing ... ********** If you have not lost the piece, you can fix .... !!!!! You have it **********??? Thanks
A: I got these bars installed form the local bike shop that way, I am unaware if there is supposed to be a piece of carbon there as they wrapped the handlebars all the way though.
And it still sold for $150.
Quoted: 18374 Post(s)
Liked 4,509 Times
Yeah, there is a huge price discrepancy between the "branded" and "unbranded" integrated CF bars. That mod probably doesn't make a big difference, but it seems odd. However, it does seem to cut into the lower structural elements of the bars so I would have cut off at $30 or so.
Perhaps there was some kind of a blockage for the cable routing.
I'm thinking about building up a bike with 3 shifters, and still trying to figure out the cable routing.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
So in use, are you supposed to leave the seat on the post leave it hanging out the other side from the side you're pumping on? That doesn't sound too unreasonable if you have a QR seatpost bolt. However it looks like the placement of the chuck could cause some interference between seat and tire.
Genesis 49:16-17
Genesis 49:16-17
Liked 4,509 Times
There are newer ones that use a hose, either at the top or the bottom of the seatpost.
That one might work if one had a new wheel with paired (or triplet) spokes.
Now, if only they had bothered to center the valve. But, perhaps they decided it was safer near the spokes.
Otherwise, removing the seatpost, then removing the seat would be a big pain. I suppose if one got to only getting a single flat every 10,000 miles or so, then one would be ok taking everything apart, especially if one usually had friends that would donate their pump.
Disco Infiltrator
Liked 2,105 Times
^^^ Those wheels are highly engineered by smart people, I'm sure there's a reason why.
Genesis 49:16-17
Genesis 49:16-17
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,428 Times
My parents have matching Dahon folders that have seatpost pumps as a standard feature, although they use a hose instead of just a chuck.
https://www.usa.dahon.com/mainnav/fol...eat-posts.html
Disco Infiltrator
Liked 2,105 Times
Man, I just had an idea. It's an awful idea but I bet it's good enough to sell some stupid pumps. I don't like it, it feels unethical.
Genesis 49:16-17
Genesis 49:16-17
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,428 Times
Quick, make a kickstarter to protect your IP. Prior art, man!
Liked 1,699 Times
If the was struck in a manner hard enough to crack off that chunk, what else was cracked?
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Liked 4,509 Times
Why on Earth would the seller mount a 26" wheel/tire on the bike... and then state that it also includes the original 700c wheel?
kent 700 series road - $65 (Springfield ,or)
Flat tire?
Flat tire?
Liked 4,509 Times
Uhhh..... Ohhh.... not another botched fixie conversion.
2 TONE FIXED GEAR FRAME AND FORK 56cm - $70 (EUGENE)
Disco Infiltrator
Liked 2,105 Times
Genesis 49:16-17
Genesis 49:16-17
Liked 4,509 Times
I don't see any cable stops anywhere on the bike. Not all bikes had them, but most frames that had water bottle bosses and integrated derailleur hangers had at least some cable stops.
Those chainstay bosses puzzled me too. My best guess would be Cantilever/V-Brake Bosses. But it seems like an odd place to put them.
Disco Infiltrator
Liked 2,105 Times
Awesome $3000 full suspension bike, carbon frame, Sid fork, Fox shock, XT/XTR components... 7-speed Mega Range freewheel in back, superfluous disk in front?
Trek Fuel 98 full carbon mountain bike
Genesis 49:16-17
Genesis 49:16-17
Liked 4,509 Times
That bike probably had disc brake mounts, but had mounted front and rear V-Brakes.
So, somewhere along the way, the bike lost its original wheels.
I wonder how effective the gear indexing is on the 9 --> 7 gear configuration.
It looks like it once was a nice MTB. $3K worth???? Aluminum frame with CF suspension and rear triangle?
Quoted: 4233 Post(s)
Liked 2,948 Times
Aren't those just normal U brake studs?
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Bikes: Swobo Sanchez 3x1
Quoted: 137 Post(s)
Liked 2,948 Times
Well, except I don't see any studs on the fork, so it might mean that it's a mystery bike that used to be an mtb that got in a front end collision and has a new fork (hence the paint to match). Other than that, if it hadn't been drewed it might be worth taking out and building up into a drop bar commuter if it fit. Clamp on cable guides could get around the removal of the originals (assuming they existed, and since u-brake means mid-late 80's, they probably did), but my fear of a front end collision would say no thanks to this on. Of course, I could be mistaken and it could be something that came with a centerpull front brake.
Quoted: 1119 Post(s)
Liked 2,255 Times
Who buys these things? Who in their right mind would want to go 40 MPH on a $98 new Magna Great Divide? Why not start with a better donor bike with more capable brakes? I guess I should be grateful they didn't kludge up a nice vintage mtb or something.
[h=2]bicycle new with 66cc 21 speeds & shocks - $555 (coon rapids,mn)[/h]bicycle new with 66cc 21 speeds & shocks
ew only one mile on recently built 21 speed motorbike. NEW BIKE SOLD BY TARGET AND NEW ENGINE INSTALLED BY OLDEST CYCLE SHOP IN STATE OF MINN. OVER 100 MPG EASY START HAND CLUTCH MOTORCYCLE HANDLEBARS. AUTOMATIC CLUTCH. CYCLE CHAIN DRIVE. MOUNTAIN TIRES. 26 INCH. ELECTICAL SYSTEM SUPPORT LED LIGHTS FOR NIGHT DRIVING. NO LICENSE REQUIRED. RIDE THE BICYCLE LANES. NO PARKING PROBLEMS. JUST LOCK IT UP WHEN NOT IN USE.
WE BUILD THEM............YOU RIDE THEM. TWIST GRIP SPEED CONTROL SAME AS MOTORCYCLE. 40 MPH AFTER BREAKIN. GOOD BRAKES. BALL BEARING ENGINE FOR LONG LIFE USING AMZOIL. ONE MILE WEST OF NORTHTOWN SHOPPING CENTER AND UNIVERSITY AVE NE.
Disco Infiltrator
Liked 2,105 Times
Genesis 49:16-17
Genesis 49:16-17
Bikes: 89 Raleigh Technium PRE, 92 SP 1000 ti, '09 Team Pro, 72 International, 63 Hercules 3-spd, '81 Vitus 979, 2 Kabuki Submariners, 2 C. Itoh Submariners, Gary Fisher Big Sur, Skyway 3-spd, Robin Hood w/ S-A IGH 5 speed.
Quoted: 623 Post(s)
Liked 397 Times
