Do patched up inner tubes slow you down?
So i wanted to save some money and just repair inner tubes with a patch kit. I was wondering if this would increase my rolling resistance?
Quoted: 18415 Post(s)
Liked 15,545 Times
Nothing slows me down except myself.
Likes For indyfabz:
Quoted: 4806 Post(s)
Liked 3,928 Times
Probably if you can find equipment accurate enough and can eliminate every other factor. (Most people would call this obsessive.)
Real life - I've patched many tubes many times and the only time I notice the patches is when I pull the tube out. My norm at tube replacement is 5 patches. Now, 5 patches does add some weight but not a lot. A small REMA patch kit weighs maybe an half an ounce. That (edit) half ounce includes 6 patches, one of which is large, a tube, a casing patch and sandpaper. The box itself weighs probably 1/'3 the total. If my guesses are close, the rest weighs 10g. So maybe 5 grams for 5 patches and glue used. On a 70 gram tire. ON a 1000g wheel. On a 7000g bike. Ridden by a 70,000g rider. I would expect the additional rolling resistance to play out about the same.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Unless you patch them incorrectly and they lose air... no.
Likes For ridelikeaturtle:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Personally, my race day wheelset is either tubular or tubeless. When I was racing on tubes, my race day wheelset had an unpatched latex tube. But I wouldn't (and haven't) hesitate(d) to use my backup wheelset with a patched tube in a race, and will train on patched tubes all day long.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
Only if the patch fails and you have to do it again.
Likes For delbiker1:
Quoted: 696 Post(s)
Liked 910 Times
Won’t the wheel be out of balance?
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Patched tubes are faster than no tubes (unless you have tubeless tires, then it's a moot point).
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
I've been wondering this for a while. I asked Josh Poertner on his Marginal Gains podcast about it: he thought it would but he hadn't tested it either. OTOH, Tom Anhalt thinks it won't. If you know these two guys you'll recognize that they rarely disagree, so I'll take it that the question is currently unresolved. I'll probably test it at some point but I haven't yet had a chance.
Likes For RChung:
Quoted: 605 Post(s)
Liked 480 Times
Seriously, if anyone can successfully measure a statistically significant difference, *and replicate it*, then that research should be published. You'll win an Ig Nobel prize.
Advocatus Diaboli
Liked 1,532 Times
The real question is.. does a patched tube use less additional watts than carrying the additional weight of a spare fresh tube in your back pocket or saddlebag?
But giving Tom and Josh their due respect, I would be hesitant to rely solely on what is essentially a hand waving argument by analogy.
Quoted: 1814 Post(s)
Liked 923 Times
Huh.
So if the patch is about .75" it would be about 1/112 of the wheel circumference and about 1/4 of the tube circumference.
The thickness of a patch is similar to the difference in thickness between a standard tube, and a lighter tube.
The difference in rolling resistance between those tubes is about 1 watt for pair of tires at 45kph,
so a patch could theoretically require about .0022 watts at 45kph.
https://www.aero-coach.co.uk/inner-t...ing-resistance
Then, if I have the math right, they suggest a 4 second difference in a 40k TT for 1 watt of RR,
so a tube patch could cost you .0088 of a second over a 40k time trial at 45kph.
Likes For woodcraft:
Bikes: 70's frame, newer parts
Quoted: 92 Post(s)
Liked 38 Times
This is what I call the "standing on a sheet of paper argument". In theory if you are taller you can see farther. So does standing on a sheet of paper enable you to see farther?
There are many things like this that in theory should matter but the effect is so small as to be impossible to measure.
Likes For ChrisAlbertson:
Liked 923 Times
Sez you!
Quoted: 3952 Post(s)
Liked 7,297 Times
Likes For tomato coupe:
Likes For FeltF2Tarmac:
Quoted: 874 Post(s)
Liked 2,288 Times
I have quite a few bikes in my stable that are rotated frequently. I can’t remember which ones have patched tubes so I really don’t know. Each bike has a seat pack or handlebar bag with a spare tube and a patch kit. I always end up patching over replacing the tube . I am not a racer so I really don’t care about speed as much as comfort and feel of the bike itself. I have noticed a difference in tires for sure ,but tubes?
Quoted: 1109 Post(s)
Liked 1,200 Times
Huh.
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
If patched tubes slowed me down, I would soon be cycling in reverse!
Likes For Digger Goreman:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I bought smaller patches so they won’t slow me down.
Likes For biker128pedal:
Likes For eduskator:
