Thru-Axle help needed for a beginner!
Hello there,
I have recently purchased a Cannondale Road Bike set from eBay, with everything included other than wheels, cassette and disc brake rotors. I have bought a Shimano 9 speed cassette, but I am finding problems with the wheels. As a beginner, I am not sure where else to turn!
I have purchased a Prime Stagiaire Disc wheelset from Wiggle, which is Thru-Axle. My frame is the standard dropouts I think so I am assuming I cannot use thru-axle? What do I need to buy/do to be able to attach the wheels to the frame?
The front is 12 x 100mm and rear 12 x 142mm. I have struggled to find adapters of these sizes. I am pretty beginner so something you could recommend which is simple but not too pricey would be greatly appreciated!
Many thanks
Many thanks
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
Thru axle and standard drop outs are not compatible. Sorry.
Quoted: 126 Post(s)
Liked 55 Times
If there is an adapter, I have never seen one. Quick release dropouts are open on the bottom, thru axle not. Return the wheels for some that will be compatible with your frame. If you can't return them, sell them and go to step B.
Quoted: 20810 Post(s)
Liked 9,456 Times
Assuming that the bike is a disc brake frame (if it's a rim brake frame, there's absolutely nothing that you can do), you'd have to find QR (quick release) end caps for your hubs. Some disc wheelsets come with multiple end caps (QR, 10mm TA, 15mm TA), but that's become less common as 10mm TAs have essentially become the standard. To be clear, you need adapters from your wheel manufacturer - assuming that they make them - as others will not fit properly.
edit: guy - they've got a link for the end caps right on the wiggle product page - https://www.wiggle.co.uk/prime-stagiaire-qr-end-cap/
Likes For WhyFi:
Okay, what wheels would you recommend as I'm struggling to find a disc wheelset that is not thru-axle? Budget build so ideally max £200 for the set.
Liked 9,456 Times
And yeah I know, I am pretty beginner so made a few mistakes
Quoted: 1851 Post(s)
Liked 678 Times
Hello there,
Many thanks
Many thanks
DT Swiss wheels generally come with an adapter to convert it to quick release. I have a set of E1800s, and my rear wheel is quick release, front thru axle. You will struggle to get them new for £200, and if you buy used, may not have the adapters you need
Canondale Frame
Canondale Forks
FSA Headset
Bottom bracket (BB30)
FSA Gossamer BB30 Cranks
Pedals
Seatpost
Boardman Saddle
Seatpost Clamp
Boardman Stem
Carbon Headset Spacers
Boardman Bars
New handle bar tape
New KMC X9 Chain
Shimano Sora Levers
Shimano Tiagra Derailleurs (new jockey wheels)
Tektro Novela CS Disc Brake Calipers
Shimano Rear Brake Mount Converter
Cables and Housings (routed internally)
Expired Member
Quoted: 3660 Post(s)
Liked 5,405 Times
Check Fulcrum wheels. They often come with a variety of end caps.
I would send the wheels back and look for a different product. Two brands that I personally have good experiences with that have multiple pricepoints AND have different adapters available are Hunt and Rol.
