What tool to tighten/center this brake?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
This is the front brake on a Specialized Allez Sport Triple, and it's dragging the right pad. What is the tool/wrench that is designed to get into that tiny space and tighten that nut so it will stay centered?
Quoted: 702 Post(s)
Liked 671 Times
maybe this, it will engage the flats on the front while you tighten the nut on the rear
https://www.parktool.com/product/off...e-wrench-obw-4
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Also, I notice from that picture how diagonal that front arm is, that's from my attempt (and failure) to take the brake apart to get to the centering bolt. The rubbing was there before that
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Quoted: 702 Post(s)
Liked 671 Times
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Before you pick up a screwdriver, however, check to see that the wheel is square in the dropouts.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,201 Times
Stuart Black
Stuart Black
Quoted: 4194 Post(s)
Liked 3,837 Times
This caliper, like many we see, would benefit from a take apart and reassembly with cleaning and lubing. The arm pivots can be adjusted (usually for the better) for slop/friction balance. This is simple stuff although patience and focus are abilities used Careful examining of the pivots and any locking nuts and set screws is a must first. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1079 Post(s)
Liked 1,017 Times
If the nut on the back of the brake is loose, just hold the brake near center and tighten it. You should be able to keep it centered well enough. Then use a screw driver on the screw on top (red arrow in the picture below) to fine tune the centering. If the caliper isn’t loose, you should be able to just adjust the centering screw.
However the pivot bolt just to the left of that screw is clearly loose and unadjusted. You'll need to tighten that up which I find easier to do without the cable installed in the caliper. You'll need to loosen the nut slightly, and start tightening the bolt. As you tighten squeeze the pads to the rim and make sure they snap back open, at the point they don't back off 1/4-1/2 a turn and tighten up the nut. After tightening the nut double check the pads snap back open, sometimes tightening that up tightens the pivots and you may have to back the bolt off a touch more. Reinstall the cable and center. With old school single pivots you had to use tools but with duals they just pull to the side you want and you can easily futz with them.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
OK the futzing screw was too good to be true. Screwed all the way in or all the way out, doesn't help. Screwed all the way in may be marginally better, but the whole brake wants to be rotated over to the side. It can be easily rotated by hand, but immediately rotates back. The rear brake cannot be rotated by hand. I think the answer must be in that locking nut.
I found the 5mm hex bolt in the back of the fork, it was already tight.
I got the front arm off, seems the reason it was all askew was from the previous time I halfway got it off, I wasn't able to get it back on right because of the protruding bottom of the futzing screw. With the screw backed out I could get the arm back on (with a little lube on the pivot).
When the arm was off, I could see a 5mm bolt on the front, that was also already tight.
So again, it seems like that locknut in the tight area has to be tightened down good, yes?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You don't really need a tool to center a dual pivot brakes, tighten down the nut that holds it to the frame so its snug, don't over tighten. Grab the pad of the side that's rubbing and pull it away from the rim. That's it. The little screw being pointed to is something that virtually never needs to be touched. I've spent way more time adjusting that screw from someone else playing with it then I ever did actually using it.
Liked 4,201 Times
Stuart Black
Stuart Black
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
^All of this^. If you hadn't tried to take the brake apart all you would have had to do was make sure the nut on back was snug, center the caliper by hand, and then tighten the nut. Now you've got a little more work to do. The adjuster screw is probably ignored by 99.999% of people w/ tools.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
Tried to get in there with 13mm cone wrench, it almost seemed like it was grabbing, but then mushed off
Quoted: 702 Post(s)
Liked 671 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
The caliper should not be able to rotate back and forth by hand, should it? The rear one is quite firmly in place
Quoted: 702 Post(s)
Liked 671 Times
That is correct. You'll need to snug up the bolt that holds the arms. This is independent of the nut that holds the caliper to the bike. Removing the caliper from the bike may help you to figure out how to do it.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
It sounds like you're talking about the bolt that holds two arms down. When I had the outside arm off, I checked that and it was quite tight.
So the only thing left would be the bolt behind the 3 arms, betwee the serrated thing and the spring. That I can't grab, so I guess I have to buy that Park OBW-4 to get at it.
Blamester
You have to now remove the brake to adjust it correctly. A set of allen keys is nessecary. It's not difficult. There are likely grub screws and ball bearings in there so be careful..
Likes For blamester:
Quoted: 254 Post(s)
Liked 182 Times
I don’t know exactly what model that is, but here’s a diagram of a dura-ace caliper that’s probably similar. Might be helpful if you take it apart:
https://www.flickr.com/photos/stronglight/4042079326
Liked 1,017 Times
Finding a screwdriver on my repair stand is harder then just grab a side and pull over. The rest of that is due to the fact his brake caliper is visibly falling apart. You mentioned having him check his wheel was straight in the drops but its noticeably obvious that it is straight to the main body of the brake, the outer pivot arm is coming unbolted, hence the other directions.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
When I started this whole thing, the arm was not all akimbo like that, it just looked normal like the back brake, but the whole thing was loose and the right pad riding the rim.
Now I'm back to nominal assembly, I just haven't posted another picture.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
FYI this is the bike, I don't know if 'Light Dual Pivot brakes' means off-brand or not
https://www.specialized.com/us/en/al...Text=9000-7949
Quoted: 6173 Post(s)
Liked 4,791 Times
The little screw to help you center the brake pads on the rim only controls movement in one direction. So you have to balance that with the adjustment from the barrel adjuster. If you've gotten the screw too loose or too tight, then you might need to turn the screw to put it in the middle of it's adjustment range, then put the barrel adjuster in the middle of it's adjustment range and then assess if you need to put the cable in a different position in the hold fast.
