School me on Suntour
No idea, but most likely SunTour's intended setup. In my experience, most brakes are designed to be used without ferrules. I haven't found this to be a problem: Shimano's modern dual-pivot calipers are widely regarded to be some of the nicest-feeling calipers out there, and they're not intended to use ferrules. The T610 v-brakes on my gravel bike have a ton of mechanical advantage, and I have to set them fairly close to the rims by necessity. They lack ferrules, but in dry weather, in power and modulation they feel about as good as the hydro discs on my MTB:
(I also set these up without a barrel adjuster, although that's not necessarily a choice I'd recommend!)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 227 Post(s)
Liked 390 Times
I have an original matching 1st gen superbe groupo on my Paino including inner and outer cables and they dont use ferrules cable end crimps. Original outer cables are slightly fatter, .2 of a mm? Makes a difference still. Inner cables are thicker with soldered ends.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
This - the Sprint stuff should not be overlooked. My Faggin was equipped with Sprint. Both the indexed shifting and the brakes worked very well. I was especially surprised by the brake performance - it was a world better than the previous generation Superbe stuff I had.
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
After getting back into vintage bikes about ten years ago, I mostly wound up with Campagnolo NR/SR-equipped bikes. I built my Griffon with full Superbe though:
The only Campy bits are the headset and the Doppler shifters. I'm not totally enamored with the Dopplers. Based on my short experience, I don't find them any better than Simplex/Huret Retrofriction shifters, so I might swap them out for something else (perhaps Dia-Compe ENE). That will wait until the spring though. I'll fiddle with them some more before completely giving up.
Quoted: 1361 Post(s)
Liked 423 Times
Scroll down the page at this site to Suntour catalogs in Japan.
The catalogs of Japanese vintage bicycle
Quoted: 2588 Post(s)
Liked 4,824 Times
I've been perusing old Suntour cable sets on Ebay and guess what? They have ferrules in them!
You know, the more I think about it, the more I realize that most cable sets I see have some sort of ferrule at the transition - even if they are only plastic/nylon, there always seems to be something. So, I will stick with my bias (or whatever you want to call it) and will build this up using ferrules at both ends of the housing. I get that some of you don't, and the braking works for you and that's cool - but have you ever stopped to think if you might see an improvement in braking feel if you were to add the missing pieces?
Off to the bike shop for some housing and ferrules
DD
DD
Bikes: many
Liked 1,392 Times
I haven't been paying close attention to this thread. My take on ferrules is that if the port was intended to take a ferrule, the cable fit in the port (lever or caliper) will be sloppy without one. If a ferrule fits, I use one. If not, then I go without. I've never considered the issue of beveled or flat bottom, but will pay closer attention in the future.
Likes For smontanaro:
Cool - but does is this brakeset one of those designed to work without ferrules? I don't know - I haven't used Superbe brakes since the mid-80s.
Bias? If you mean my habit using ferrules at each end of the housing when installing Campy brakes, well, that's not bias - it's textbook installation.
Quoted: 1142 Post(s)
Liked 1,739 Times
Suntour sure has a lot of variety, I must have 10 different types of shifters, 4 friction, Power levers, stem ratchet levers, and two sets of barend ratchet, and 3 types of index sets. I even still have a couple of the braided cables and coil outers.
Quoted: 1303 Post(s)
Liked 1,910 Times
DD,
The missing part of this discussion is the size of the cable housing. Three different sizes, and three different ferrule sizes. 4mm is a standard size for housing in Shimano indexing system. 5mm is a standard size for both Shimano index shift cables using the radial inner wires, and some brake cables that use bias wound cables. And lastly 6mm bias wound cables used for brake cables. The 5mm cable when used as a replacement for brakes need a ferrule to keep the cable centered in both the lever and the caliper.
The pics of a Superbe cable above is of a 6mm cable housing that fits snugly in the barrel adjuster. I have enclosed a pic of the Campy lever and the size of the cable receptor. And pics of the ferrules for a 5mm housing. The steel ones are the ones needed for brakes and the plastic ones are used for shift cable where the reinforcement of the cable end is not needed. Smiles, MH
Liked 4,824 Times
DD,
Wasn't able to find anything today but I did get a good deal on a bulk purchase of derailleur and brake cable inners. I love Recycled Cycles
DD
Liked 4,824 Times
DD
Liked 4,824 Times
Right? That's part of the problem it seems. Btw, I like this black/silver version of their shift levers. Is this one of the pairs you are willing to let go?
DD
DD
Liked 4,824 Times
DD
Liked 4,824 Times
I don't remember what the tech manual for Superbe brakes said, but it would have been standard good practice to use ferrules at both ends that time. Yeah, it makes them feel more solid and precise. It would have been weird to buy a very expensive top end brakeset and then take shortcuts in set up. Superbe were essentially campy copies, so it's hard to believe the factory recommendation would have been any different than campy. It is possible, but I think unlikely. If anyone still has the tech sheet, please share... There are partly stepped down ferrules that should work for this particular application. If i had to guess I'd say that's what was used.
A partly stepped down ferrule would be perfect!
DD
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
There are also metal versions for the ends of the rear derailer housing loop, but always with a plastic seating washer inside.
Liked 1,739 Times
I read above that you have Campy mix in the make. That stuff is a drug hard to get off once you start. For your build I recommend Cyclone hubs on Campy Victory rims, something like that would be golden on you build. The hubs are like Specialized sealed set freewheel.
But the rims may not be of your likes, tubular.
Bikes: Cervelo S5, Cannondale AL1 Lefty MTB, Trek X01, Trek Farley 7,1951 Raleigh Sport, 57&60 Raleigh Tourist, 70 Raleigh Super Course, 80's Soma Prestiege,72 Raleigh Grand Sports, 85 Club Fuji, 76 Raleigh Competition, 85 Panasonic,70's Peugot u08. & more
Quoted: 39 Post(s)
Liked 25 Times
Personally I love the Cyclone stuff. Works awesome. The price point is usually not bad either.
Quoted: 4806 Post(s)
Liked 3,928 Times
Seems I had it all wrong for decades. I just mounted my SunTour derailleurs, found whatever ferrule in my spare parts (or none) that seemed to work best and rode that derailleur until the pivots loosened up beyond acceptable or I crashed it, then replaced it with the next SunTour (or rebuilt with new upper or lower and rode on. Had no idea I was angering the gods or breaking immutable laws. Never, ever had to replace a SunTour because of issues with cable housings. (Occasionally I'd have a ferrule that didn't work. I'd just replace it with better or none.)
I see no mystique re: SunTour derailleurs. They simply work; very well. Idiotically simple to set up. If there are immutable laws that must be honored, I guess they got implanted in my brain or soul from an outside source. I never recall reading instructions. They don't last forever. All the pivots and hinges wear out from shifting. Takes quite a while. Very good design so a lot of slop is acceptable with shifting that works well but eventually ... (Unless you choose not to shift. )
Ben
Ben
Liked 3,928 Times
Ben
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
The only time I've ever seen sloppy cable performance from "missing" ferrules is when using shift/index housing with a friction rear derailleur. I won't ever do that again.
Liked 1,295 Times
Yet I have also had good luck with running naked 4mm derailer housing into a Simplex Prestige, seems that if the cable housing loop is nice and short that it exits straighter from the port in the derailer, so stays seated better. Also, the original housing back then was slender 4mm stuff having a textured vinyl covering, so the cable port is too small for a modern ferrule.
I also never "slam" the lever toward the largest cog, which greatly reduces the maximum tension stress that the cabling sees, and with the housing strands embedding in the plastic of the derailer knuckle it seems to be ok this way.
Likes For dddd:
