School me on Suntour
#51
Quoted: 3464 Post(s)
Liked 2,830 Times
Got it. I rode a full Superbe Trek 760 for over twenty years. Somewhere along the way, I got the idea that I'd replace the Superbe derailleur with NR. That lasted about two weeks before I switched back.
After getting back into vintage bikes about ten years ago, I mostly wound up with Campagnolo NR/SR-equipped bikes. I built my Griffon with full Superbe though:
The only Campy bits are the headset and the Doppler shifters. I'm not totally enamored with the Dopplers. Based on my short experience, I don't find them any better than Simplex/Huret Retrofriction shifters, so I might swap them out for something else (perhaps Dia-Compe ENE). That will wait until the spring though. I'll fiddle with them some more before completely giving up.
#52
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I like the Suntour stuff.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
#53
Skip over on ibob clued me in to this thread. Most of the Suntour pre-index stuff was from my bike shop days, when I wasn't paying much attention to installation instructions (and to be fair, you kinda didn't have to back then), plus the memory fades. And without a doubt, clean/square casing cuts, ferrules and tight socket fits are more critical when indexing is involved. Compressionless casing didn't exist pre-index, either, so there were fewer problems with wires poking out of the casing ends.
That said, the high-end Suntour rear ders (Cyclone, Superbe) didn't have cable tension adjusters, nor did your standard downtube shifters, so having a tight cable run with no slack caused by casing rocking in the rder socket meant better shifting. IIRC, the stainless casing chunk included with rders were 4mm w/ferrules at both ends. That casing was kinda springy, though.
In the shop we usually squared casing cuts on a bench grinder. I'd bevel the ends a little for the rounded-bottom sockets. Generally didn't use ferrules for brakes.
I can remember, though, seeing rounded-end ferrules, likely for brakes.
I always thought the casing sockets in the Spb brake lever bodies were too shallow. But they worked...
Somebody mentioned the Symmetric shifters, which was a cool idea and did what it was supposed to do. I always had a problem with the left/front lever loosening and ghost shifting, though, and since it didn't have d-ring tenstion bolts, I always rode with a 4mm hex wrench in my jersey pocket so I could tighten the lever on the fly. Might have been a bigger problem if you were shifting a triple front? When I later (good-naturedly) *****ed about this to Suntour engineers, they kinda shrugged and acknowledged it was a problem they never resolved. Also, top-of-downtube aero levers fell out of favor, and that was the only way to make the self trimming feature work.
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
#54
Quoted: 2588 Post(s)
Liked 4,824 Times
Found this Sugino Mighty crankset today and snagged it for the build:
I was originally looking for Suntour Superbe, but nothing in really good condition came up that wasn't (IMHO) crazy-priced. I decided to look for Sugino and found a few of the clunkier early cranksets before stumbling upon this Superbe look-alike. Condition is super and the arms have flutes on the backside, too. I will add beveling to the drillium and really make the rings pop. Oh, and I really like that S under the crown logo
I wonder what kind of seatpost I should look for? I'm going for a certain look, don't quite know exactly what it is, so I still have no idea what to do about a post...
DD
DD
Likes For Drillium Dude:
#55
Liked 4,824 Times
Btw, the cranks are marked M-14, which I was 99.9% sure meant French thread (right?), so I am also looking for a different kind of pedal than my typical Campy because I don't currently have a French threaded pair. There are some good options out there.
DD
DD
#56
Quoted: 4512 Post(s)
Liked 6,385 Times
DD
DD
The "Mighty" Sugino Super/Mighty Competition, my true favorite, every bit as strong, tough, great looking and easily one of if not the best in the business imo.
My first top of the line crank that came on my first good bike and it was bullit proof for 30 yrs until it was stolen with the Raleigh SC it was on.
I had allowed the BB to get washed out before I realized the factory skimped on grease and it took a beating before I got it overhauled, good grease and light preload, regular often revisits kept it going just fine from then on. An amazing piece of manufacture and engineering for me.
#57
Bikes: many
Quoted: 1444 Post(s)
Liked 1,393 Times
Which reminds me of the other Campy part on my Griffon, the Bob Freeman-enhanced two-bolt Record seatpost. He takes a seatpost in bad condition, cuts off the scraped up section, turns down the remnant, then epoxies on a hunk of titanium tubing. 27.2 is the only option.
#58
Liked 4,824 Times
I am waiting until my new(old) camera gets here so I can take some representative photos.
DD
#59
Liked 6,385 Times
DD
DD
A bit crude but works just fine when done with anti-seize, the axle mounted in a vice and a one step forward, two steps back process. I run them in from the back side too.
#60
Liked 4,824 Times
They don't seem to come up very often. Not sure where I got mine. In any case, it's just a badge engineered Sugino anyway, so you can rest easy. Which reminds me of the other Campy part on my Griffon, the Bob Freeman-enhanced two-bolt Record seatpost. He takes a seatpost in bad condition, cuts off the scraped up section, turns down the remnant, then epoxies on a hunk of titanium tubing. 27.2 is the only option.
A local riding buddy of mine has one of Bob's titanium Campy specials. Did yours come out lighter than original? I ask because my buddy claims his is heavier than before, but probably because he had the post built quite long (he rides a 65cm frame). I could do something like that I suppose, but I am trying to take this one bike away from Campy, so...
DD
#61
Liked 4,824 Times
I'm looking at some old Atom 700s currently.
DD
#62
Liked 4,824 Times
Seems I had it all wrong for decades. I just mounted my SunTour derailleurs, found whatever ferrule in my spare parts (or none) that seemed to work best and rode that derailleur until the pivots loosened up beyond acceptable or I crashed it, then replaced it with the next SunTour (or rebuilt with new upper or lower and rode on. Had no idea I was angering the gods or breaking immutable laws. Never, ever had to replace a SunTour because of issues with cable housings. (Occasionally I'd have a ferrule that didn't work. I'd just replace it with better or none.)
I see no mystique re: SunTour derailleurs. They simply work; very well. Idiotically simple to set up. If there are immutable laws that must be honored, I guess they got implanted in my brain or soul from an outside source. I never recall reading instructions. They don't last forever. All the pivots and hinges wear out from shifting. Takes quite a while. Very good design so a lot of slop is acceptable with shifting that works well but eventually ... (Unless you choose not to shift. )
Ben
Ben
Your description above for the derailleur will most likely be my experience as well as I found a perfectly-sized ferrule for the RD, too.
DD
#63
Quoted: 1361 Post(s)
Liked 423 Times
I thought it might be - I prefer that cool Sea-Monkey crown logo on the Sugino, and I like the simpler flutes. The Superbes had those funny bi-level flutes.
A local riding buddy of mine has one of Bob's titanium Campy specials.Did yours come out lighter than original? I ask because my buddy claims his is heavier than before, but probably because he had the post built quite long (he rides a 65cm frame). I could do something like that I suppose, but I am trying to take this one bike away from Campy, so...
DD
DD
Is a Japan version of the Record seat post of interest?
#64
Bikes: many
Liked 1,393 Times
Dunno. Never bothered to weigh anything. (I generally don't.)
As for other options, I'm sure if you find a beat up non-Campy post, your frame takes a 27.2 post you and wanted to pay the piper, you could send it to Bob (assuming he still has some tubing). Lotta ifs there...
#65
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
...That said, the high-end Suntour rear ders (Cyclone, Superbe) didn't have cable tension adjusters, nor did your standard downtube shifters, so having a tight cable run with no slack caused by casing rocking in the rder socket meant better shifting. IIRC, the stainless casing chunk included with rders were 4mm w/ferrules at both ends. That casing was kinda springy, though...
...I can remember, though, seeing rounded-end ferrules, likely for brakes.
And the wild amount of friction that results when modern stainless cable wire is used in such housings!
Ahh, the rounded-end ferrules, found in the Dia-Compe-produced early aero levers. I would often find that these would swivel sufficiently to have the cable wire eventually cut a notch in these ferrules, with friction-plagued brake actuation the whole time! The later such levers featured a fixed-position ferrule inside, which forced all of the cable's exiting path curvature to occur inside of the lined housing for a much smother braking feel with no metal-to-metal contact at all.
I also often wondered why old brake levers had such shallow sockets for the housing. But I only figured it out today after all of these years! It would seem that this prevents the sort of damage to the cable housing that so often results from the cable housing's impact with things, the sort of damage that I so often must nip off with a cutter in order to salvage a bike's original housings. The shallow socket allows the housing to pivot out of the socket, so that the housing doesn't get sharply bent, thus preventing the cable's path from being pinched shut. That's one more thing that was right about the old designs that I never had a clue about. Bikes back than were perhaps ahead of our time(?)!
#66
Liked 6,385 Times
Re-tapping would be the way to go, huh? But I don't trust myself to get it right, and don't know anyone local who might give it a go for a reasonable price. Heck, I don't even know what a reasonable price to re-tap them would be. But since I'm trying to turn this into a Frankenbike of sorts, this is the perfect opportunity to add some Frenchiness
DD
DD
I would be happy to send these to you.
#67
Quoted: 4806 Post(s)
Liked 3,930 Times
DD
DD
I worked in a Fuji shop summer of '77. The Pros were all Superbe. Gorgeous. I raced against a team outfitted with those bikes often. I would have turned green with envy except that my Sugino/SunTour/NItto/Grand Comp bike worked really well. I wasn't giving anything away.
Ben
Likes For 79pmooney:
#68
Liked 4,824 Times
DD
#69
Liked 4,824 Times
DD
#70
Liked 4,824 Times
There is not a huge difference imo at the start of the threads and I have never had a problem doing it, they start ok and once you get it going it goes fine. The rethreaders are key for me, regular taps are too sharp and don't guide themselves well. I have saved badly mangled ones many times. Recently I had a PX-10 that had 9/16's pedals forced in badly. It took stripping the pedals down to the axles then vise and vise grips to get them apart. Then you would be proud, got some French pedals from the co-op, stripped them down and made rethreaders, fixed the holes, put French axles in a pair of Campy SR pedals and now it will stay all French as it should on this.
DD
#72
Liked 6,385 Times
Maybe I'm reading this incorrectly, but this crank is already French threaded. If I were to re-thread them, I'd need rethreaders for 9/16ths. But I'm not looking to do that - at the very least, I wouldn't want to try for the first time on this set. They're much too nice!!
DD
DD
I would also be happy to do it for you if you want to send them to me, it would be gratis for the greater good. You "Mighty" check with Bob, ROS or Dfrost as well.
One more footnote, if these were Campy, I wouldn't advocate this although I wouldn't hesitate for myself, that being said, I would preserve a Campy set for the same reason I rescued the Stronglight set above and made the Campy pedals match it, because, well, Campy.
French Sugino's are fine to correct imo, I have two sets that were cheap for being French and were fixed straight away.
#73
Liked 2,830 Times
Campagnolo DID make French threaded pedals... You need ones marked D, G.
BTW Lyotard made some "Campagnolo" form factor pedals, no "flip" tooth but otherwise All Aluminum and the correct dimensions for cleated shoes.
#74
Liked 4,824 Times
Thank you for that suggestion - I just found and snagged one from Ebay
DD
DD
