Very loud freewheel on brand new Giant TCR2 Advanced, normal?
Very loud freehub on brand new Giant TCR2 Advanced, normal?
As the title says, I just got a brand new TCR2 Advanced at the LBS. It's the 2020 model in red. It turns very smoothly but I can't help but notice how loud the freehub is.
Is this normal? My friend has the Giant Contend SL1 which was cheaper but is almost completely silent when running. Found this strange. Any reason behind it?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
'Freehub' not 'freewheel'. Your friends bike obviously has a different freehub that run quietly. Some are not so quiet.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I hate loud freehubs and that is why I love Shimano hubs. Standard Ulterga and now only 105 hubs of 32 holes. My road bike is a silent joy I just hate buzzing freehubs. I will take a well built silent rear wheel over any fancy wonder that sounds like loud noise.
Quoted: 9653 Post(s)
Liked 6,365 Times
Red is louder.
Likes For Mojo31:
Is this definitely the case, and wouldn't be to do with assembly? As I said, I found it strange that his both is a little lower spec but almost silent. Both are Giant road bikes with 105 groupsets.
Bikes: lots
Liked 2,932 Times
What wheels does your bike have and what wheels does his have?
They're both Giant's own-brand wheels that come as standard.
This is his bike: https://road.cc/content/review/22106...t-contend-sl-1
This is mine: https://www.giant-bicycles.com/ie/tcr-advanced-2
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
If it really bothers you that much, pop off the freehub and apply some grease to the pawls and ratchet. This will quiet it down significantly.
Likes For mvnsnd:
In the wind
Often a new hub will be loud but get quieter after a bit of riding, probably the grease migrating into the pawls.
Liked 6,365 Times
Quoted: 479 Post(s)
Liked 277 Times
There was a time when guys judged how good a hub was by how loud it was - with louder being better. I never got on that bandwagon. I find loud freehubs annoying.
The only time a loud freehub is useful is when the guy pulling won't pull off... the chorus of angry bees behind him can often be that cue that he's done.
Likes For Zaskar:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
I don't have a bell on my bike (who does?) so when I am passing pedestrians or other cyclists and it's tight (MUPs for instance), I stop pedaling 20-30ft before so they can hear me coming instead of yelling or whistling.
Likes For eduskator:
Quoted: 6196 Post(s)
Liked 4,810 Times
Makes noise all the time?
If it's only when you coast, then consider it motivation not to coast. I don't care for the noisy hubs either. But some actually do. It's not enough for me to worry about but it'll be a consideration when I need another wheelset. Though not so much that I'd pass on a good deal.
Reason behind it...... different design and materials.
Quoted: 365 Post(s)
Liked 122 Times
I'm, not sure what GT85 is, but nearly any standard grease will work. There are special hub greases but they are not absolutely required.
It should be a straightforward process. Remove the cassette and usually an end plate from the hub and gently pull apart. There are some Youtube videos that show the general process.
Liked 4,810 Times
I thought the comment on filling it with grease was more in jest. Grease can silence the pawls by not letting them engage. So the cassette will happily spin freely in either direction and the bike won't move unless you use it like the early draisine of bicycle history. https://en.wikipedia.org/wiki/Dandy_horse
Some mfrs. use a light grease, other's don't. So tinkerer beware. Consider that it is working as the manufacturer intended it. Noise and all.
Likes For Iride01:
Quoted: 365 Post(s)
Liked 122 Times
https://www.amazon.com/Shimano-Freeh..._df_B002P8IAHA
There are others also. And yes, all it needs is a light coating, not completely filled.
Campy hubs have the same issue. It doesn't take much grease to prevent wear, but that small amount can result in a loud ratchet. It's guess work to figure out how much is enough to reduce the noise. When more is added, it's likely to result in a big noise reduction at first, with more noise coming back after 50 miles. Too much grease can prevent the pawls from engaging and creates more friction when coasting.
Quoted: 10237 Post(s)
Liked 5,185 Times
my wheels are silent, what do your wheels weigh? depending on the answer I will trade you.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
I'm not even joking, some people actually think the louder the better quality it must be, so they go searching for loud hubs:
https://www.pinkbike.com/forum/listc...3101&pagenum=1
https://www.pinkbike.com/forum/listc...hreadid=165985
https://www.google.com/search?client...UTF-8&oe=UTF-8
Which, of course, leads manufacturers to produce hubs that makes a lot of noise to make those people buy their hubs.
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
I remember when I worked p/t at my LBS many moons ago, we had some "elite" customers that were very proud of how loud their hubs were.
Has this trend now changed?
Likes For WorldIRC:
