Addiction 2021.1
Quoted: 3350 Post(s)
Liked 3,618 Times
While not exactly what I wanted aesthetically, this worked perfectly and I can finally put this issue out of my mind.
Likes For abshipp:
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
smelling the roses
Liked 901 Times
smelling the roses
Liked 901 Times
smelling the roses
Liked 901 Times
datlas
I just typed in the french word for shower and it posted. I quickly deleted it, but it was strange nonetheless. And the four* in bat**** were self typed. I feel like I've entered the twilight zone.
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
datlas
Liked 8,919 Times
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times
Quoted: 20808 Post(s)
Liked 9,450 Times
I made the mistake of doing a search of an acronym in a new member's custom title. Yikes.
Quoted: 9652 Post(s)
Liked 6,364 Times
Well, you have to share.
smelling the roses
Liked 901 Times
smelling the roses
Liked 901 Times
smelling the roses
Liked 901 Times
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,861 Times
Saltwater
EDIT: Some filters catch that one.
Liked 11,861 Times
Two packages arrived today. One contained the Nitto Dynamic - which turns out to have EXACTLY the same height at minimum insertion as the Cinelli 1A. I think I'll keep it, since it's a 110 vs the 130 Cinelli. Also a KMC 8sp chain - I'd been using the old chain, which isn't really worn but is covered in some waxy crud. Also, the Red Black Rubber Nubs. So, with all the bits here, I couldn't NOT finish the bike!!! Only one "Oops!" moment when I discovered I'd cut the front brake housing 1 cm too short, because I didn't jam it all the way into the brake lever when doing the initial sizing.
Yeah, the bar is too high. It turned out to also be to loose, even though I'd tightened the fixing bolt as tight as I could. Pro-tip: If you buy a used stem on Ebay, remember to grease the threads on the fixing bolt!
Here's a look at the Black Rubber Nubs in place. Also, the headset and cover, with the white cables. I went with Cinelli bar tape, since the stem is Cinelli, and it's cheap in case I need to change the stem or something. Also, went with black since the 1989 Circuit came with black tape and saddle. Speaking of which, this is the original Rolls saddle.
Here's the view from behind, showing off the chrome chainstays.
So, after discovering the bar was 1) angled up too much, and 2) loose, I greased the fixing bolt threads and re-set it. This time it was tight! Also angled better. So, with the sun still in the sky, I tossed it in the trunk and headed over to Canada Road, which is really a much safer place for a shakedown cruise. I did a fast 11 miles, but didn't bother with Strava.
Observations:
Observations:
- I didn't feel like I was bending over too much when on the hoods, despite having nearly 2 cm more bar drop. BUT I suspect I'll be using the tops and corners more and the drops less than my other bikes.
- Bar needs just a touch more downturn to make the brakes more reachable from the drops.
- Love KMC chains for a quiet drivetrain!
- The Rolls saddle was pretty comfy. May still need to work on the angle. Possibly raise it by 0.5 cm? 170 cranks vs 175 on all my other bikes.
- Ride felt cushier than any of my other bikes, including the 2 CF bikes with 28mm tires.
- Notwithstanding the cush ride, it still sprinted well out of the saddle.
- 42 x 24 is WAY bigger than 39 x 25. I ran out of gears I could spin easily. So I went up 2 and got out of the saddle.
- The brakes ain't dual pivots. Not bad, mind you. And I haven't spent much time tweaking them, like sanding the pads, etc.
Likes For genejockey:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12740 Post(s)
Liked 7,652 Times
Likes For LesterOfPuppets:
Bikes: everywhere
Liked 7,652 Times
Pretty windy here, and it started raining so I turned around a tad earlier than planned. Sometimes you gotta do that in the desert or risk ending up hiking back through the mud carrying your bike.
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1412 Post(s)
Liked 968 Times
pretty bike genejockey. although left hand front brake just looks wrong to me.
vBulletin: snafu
Likes For gnome:
Liked 11,861 Times
Bikes: everywhere
Liked 7,652 Times
Elgin Baylor passed away yesterday, aged 86. RIP.
Side note: I totally forgot about Pioneer Chicken. We had em here in PHX in the 80s, I reckon this pic is in Los Angeles though.
Liked 8,919 Times
The censor/filter is quirky. I don’t really want to post profanity or offend anyone, but occasionally it might be appropriate to use the term for a French shower or even the technical term for a human, **** sapiens, and the filter is a barrier. Carry on.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,950 Times
It's not as big as I pictured it....
he said member
Bikes: yes please
Liked 1,950 Times
he said member
Bikes: yes please
Liked 1,950 Times
he said member
Bikes: yes please
Liked 1,950 Times
