Addiction 2021.1
#1976
VFL For Life
Bikes: Velo Volmobile
Quoted: 28614 Post(s)
Liked 1,857 Times
#1977
Silver Comet Fred
Bikes: 1
Quoted: 8835 Post(s)
Liked 2,986 Times
#1978
Quoted: 8280 Post(s)
Liked 9,041 Times
Yeah my friend said it was a blast. You really have to think about what you're doing to avoid crashing. One of the magazine guys did it a few years ago and he broke his chain early on but was able to fix it. He said hammering to try and catch up was very challenging.
#1979
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Likes For datlas:
#1980
VFL For Life
Liked 1,857 Times
Come on down Velo Vol and watch some quality basketball.
#1981
Silver Comet Fred
Bikes: 1
Liked 2,986 Times
#1982
VFL For Life
Liked 1,857 Times
#1983
Quoted: 3359 Post(s)
Liked 3,638 Times
It's why I'm leery of riding fixed gear brakeless, despite how great the bikes look
Likes For abshipp:
#1984
Liked 3,638 Times
They're just spacers, really.
#1985
Quoted: 20810 Post(s)
Liked 9,456 Times
Hub end caps are often swappable. Sometimes they screw on/off and sometimes they just push/pull on/off. They should have wrench flats if they're threaded, but finger-tight should be fine.
#1986
Quoted: 10236 Post(s)
Liked 5,184 Times
put cassette on with out washer and tightened the lock til it was finger tight. Cassette seemed to have a lot of play. Removed the cassette, added the washer and now the lock ring doesn’t reach the threads.
Datlas wins a gold star.
#1987
VFL For Life
Liked 1,857 Times
#1988
Liked 5,184 Times
Everything is mounted and looks good. All I need is my LBS to torque everything down and I should be set.
Two questions:
1. I bought a chain to just run with these wheels. The cassette is 28t so will the chain length need to be different from my current chain. I believe current cassette is 34t
2. I put the front wheel on just to see how it looked and to make sure the hub wasn’t weird, (whyfi and abshipp had not responded yet. Wheel fit like a dream and no play so I am happy. Brakes are rubbing and I am assuming if I put my rear wheel on they would rub as well. What do I need to do about that? I am assuming it’s a simple fix. Super stoked!
IMO they look really clean, well made for 400 dollars. If they look this well, I can only imagine what reputable wheels look like.
#1989
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,898 Times
Two questions:
Two questions:
#1990
Liked 11,898 Times
Dang! That was close!
#1991
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,529 Times
#1992
Mostly Harmless
Liked 4,529 Times
#1993
Mostly Harmless
Liked 4,529 Times
#1994
Mostly Harmless
Liked 4,529 Times
#1995
Mostly Harmless
Liked 4,529 Times
#1996
Liked 11,898 Times
#1997
Liked 5,184 Times
Was hanging my bike back up and noticed this. I’m assuming it happened when I crashed but I never noticed until now. Wheel is straight, and the spokes all feel tensioned.
#1998
Liked 5,184 Times
I don't think so. It already works with a cog around that size, right? So there's a little more chain than you need, but if you're still using the other wheel with the 34t, I wouldn't bother changing the chain.
If you have flat mount calipers, loosen the mounting bolts till the calipers float, squeeze the brake lever, and with the lever held tight, tighten the bolts. That's supposed to re-center the caliper. It would be a pain to have to do that every time you swap the wheels, though.
Thanks.
I plan on using my old wheels for gravel, but doubt I will be switching back forth on a weekly basis.
#1999
Mostly Harmless
Liked 4,529 Times
#2000
Administrator
Quoted: 11969 Post(s)
Liked 6,646 Times
Builds character.
