Tire Bead Jack Required with Third World Tires
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
I've objectively discovered in the last decade that all my NOT MADE IN GERMANY (Third World) tires are impossible to get on the rim by hand. Is it me of are others having similar issues? I have tennis elbow and wrist issues and am simply not interested in wrestling with my tires anymore.
This wonderful extra 100 grams (Kool Stop Tire Bead Jack) is coming along for the ride whenever I'm on Third World tires!
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
This is insulting, maybe a provocation. The usual problems in getting the beads have to do with skills of the operator who may then seek some outside to blame for. My common exercise is to put tires on without the use of any tools or force, just by conscious manipulation of the tire and tube vs the rim. Yes, tools can make it faster, allowing you to take shortcuts, disregarding precision.
Likes For 2_i:
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,600 Times
I, and my bike mechanic friend, have a terrible time installing Continental Grand Prix 5000 (Handmade in Germany) onto my Mavic Open Sport rims. Some combos just are tougher than others. Country of origin has nothing to do with it.
Likes For cb400bill:
Quoted: 2338 Post(s)
Liked 2,824 Times
Source of manufacture has nothing to do with it. It is specific combination of rim, tire and in some cases tubes. I have had it happen with conti gatorskins, on one bike but when I moved them to another bike (with different rims) no problem
Also tubeless specific is a whole different world, don't buy these if you are not doing tubeless
Likes For squirtdad:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
What countries are aligned with the non-existent Soviet Union and then what countries are you buying tires from that would be not aligned with either the Soviet era U.S. or the actual Soviet Union which hasn't existed for a while? Third world is an old Cold War term and the Cold War is long over now. Maybe you have been stuck in a bunker for over 30 years and missed all the news reports?
Country of origin has nothing to do with tire difficulty, I have had plenty of fun times installing Continental tires made in Germany on bikes and the worst happen to be Challenge tires (it is in the name) but those are open tubulars and their origin has nothing to do with the difficulty it is just the construction of the tire any open tubular is tough Vittoria is not a ton different and I am sure Veloflex and Tufo aren't any different either. Some tires are just tough to get on regardless of their affiliation during the Cold War.
Quoted: 1062 Post(s)
Liked 665 Times
I've had tires that needed a bead jack, and some that would blow off the rim if not mounted carefully. The brands were Continental and Schwalbe.
Since I mount my own tires, it would be a rather freak occurrence if I got caught without a bead jack by surprise while on a ride. If the tires are tight when I put them on, I throw a bead jack in the bag. One bike in the family fleet has tires that are so tight, that they're just not serviceable in the field. In general, bikes that are "for experts only" are an impediment to the enjoyment of cycling.
Quoted: 194 Post(s)
Liked 204 Times
The other day I struggled to get a pair of Polish-made Stomil Antilopes, dating from the 1980s, off and back on a 20" wheel, while my others have been no problem. I suspect having spent the last 25 years in a basement had something to do with it
Continuing on the subject of Stomil tires, a bicycle tire brand that sunk without trace in 2005, I had two bikes that had barely moved since then with some of the last stock fitted, but each with different tread patterns. One pair were soft and came off easily, the other pair were like plastic and a nightmare. However, after some riding, the plastic-like ones became easy to remove and refit too.
There are a lot of factors that can affect tire removal and replacement.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Quoted: 4207 Post(s)
Liked 3,872 Times
This issue is an old one. Back in the 1970s when I started my bike shop life we had hard to mount tire/rim combos. These days we still do. I won't be the one to say that any country of origin having no consistent aspect, rim or tire. having said that some brands do seem to be closer to one end or the other end of tolerance range. Conti being one on the tighter fit end of tolerance often. But I've found it's the rim that has the greater design contribution, how deep is the bed. Since rims are made in batches of 10 (or so usually) the same rim model can see drift from intended spec far more readily then the thousands of tires coming out of the same mold.
I have offered customers the chance to mount the various tire offerings we have to find the ones that they can handle WRT the actual rims on their bike. We also try to keep in sock the Kool Stop tire jack, but don't sell many as they're not needed often.
I'm 65 years old and still will come across a really hard to mount combo. But being a guy and a pro wrench it's a matter of shop pride to avoid a tool to mount Andy
AndrewRStewart
AndrewRStewart
Quoted: 581 Post(s)
Liked 921 Times
My first job was in a bike shop that sold Trek bikes. They had their own brand of rim and tires (Matrix), and Matrix tires were an almost impossibly tight fit on Matrix rims.
I also bought a pair of Ritchey WCS tires that were on clearance, I believe because they were borderline defective they were so tight on some WTB rims that other tires fit on fine.
Funnily enough, the bike with Ritchey tires was stolen from my yard, then a friend found it on the roadside in the next town being thrown out with the trash a few years later. There was a cut in one of the tires and I suspect the 'new owner'(thief) gave up trying to get the tire off and just threw the bike out.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
If you don't have a cheap set of tire levers a set of old spoons will make do. The only time I ever had trouble was with a BMX rim where the sidewall was a few mm's too wide. I had to use my friends motorcycle tire lever
Liked 665 Times
Given that I'm not a pro bike mechanic, but a musician, it's a matter of pride to avoid injuring my hands. So I tend to reach for the tools before they're strictly necessary.
Quoted: 840 Post(s)
Liked 336 Times
I used to feel that way, back when I worked in a bike shop. But now that I'm 65 years old with arthritis in both hands (perhaps a result of years of wrestling stubborn tires onto rims with my bare hands?), assistive devices can be necessary, and a bead jack is the safest device with which to mount a stubborn tire.
Quoted: 1944 Post(s)
Liked 2,164 Times
Old fart
Liked 3,400 Times
I have all kinds of rim and tire combinations, including the dreaded Matrix rims and some overfilled with rim tape as well as new studded tires. The most challenging I found the small 16" wheels and yes for these I have studded tires too. The short circumference gives you less wiggle room than long. In each case, though, the patience and thought can win the day - I do not recall a combination that could not be mounted with bare hands only.
Quoted: 2026 Post(s)
Liked 1,096 Times
My common exercise is the same as yours....with most tires and rims. However, I have encountered a few tire/rim combinations that I defy you to install strictly by hand. For these cases, tools weren't a shortcut, they were a necessity and "precision" had nothing to do with it.
Liked 2,164 Times
I always love these tire mounting threads.
I’m going to be 70 this year and I need to remind myself to never say to my grandchildren...
“Hey kids do you want to watch grandpa put a tire on without any tools?”
To which they would reply...
“Why would you want to do that?”
John
John
Likes For 70sSanO:
Quoted: 6195 Post(s)
Liked 4,810 Times
John
John
I have to get in the zone to remove them though. But once you know the trick it is pretty easy. It's the trick that is a little difficult.
Likes For Iride01:
Quoted: 840 Post(s)
Liked 336 Times
John
John
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,900 Times
I COULD NOT mount brand new Conti "Handmade In Germany" tires on my old Fulcrum Racing 5s from 2006 without levers. I used to mount them on another bike with Velocity rims first, run them for a week or two, THEN move the stretched tires to the Fulcrums.
This year I discovered the old Fulcrums developed cracks at most of the spokeholes in the rear wheel. So I got a new set Racing 5s. New Contis go right onto those without an issue, and can even be taken off without levers.
I wish somebody'd told me about the Trek Matrix rims, though. I just bought an old RX100/Matrix wheelset for my 1994 Cannondale, and I had a hell of a time getting tires on them, even with levers.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
Living in a 3rd world country, almost all the local tires are simple to slide on by hand. It is the fancy ones I have a problem with.
Quoted: 569 Post(s)
Liked 582 Times
Quoted: 1572 Post(s)
Liked 643 Times
Back in the olden days when I owned a bike shop and changed a lot of tires, I prided myself in my ability to remove and reinstall bike tires using no tools at all.
I can't do that anymore. On the other hand, tires have gotten a lot better so I get many fewer punctures than I used to.
