Mystery Nervex-lugged old bike
Hi
A friend of mine bought this old bike, and we'd love to know who made it. I'll quote his assessment of it:
So - it's got path ends, but I think it was designed for time trialling rather than pure track racing, as the angles are pretty relaxed and there's even provision for attaching mudguards. Also, there are no braze-ons, either for gears or a rear brake, but the seat-stay bridge has been drilled for one. Two distinguishing features: (a) the front drop-outs: I've never seen this design before, but it's very elegant; & (b) it's got 'Nervex' decorated lugs, presumably imported from France - there's a website dedicated to these lugs, but I haven't yet got round to looking it up. Finally, the frame was evidently hand-built using Reynolds 531 d/b throughout - the chamfering at the top of the seat-stays (a dead giveaway) is exquisitely done.
The frame number is virtually indecipherable because of the nasty paint job, but as far as we can tell it's: 59-306-d222*536.
*this is a lower-case (small) 2! I'm afraid this number isn't guaranteed, & is probably not entirely accurate.
Pictures:
https://dl.dropbox.com/u/91815060/my...e/IMG_0308.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0309.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0310.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0311.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0312.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0313.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0314.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0315.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0316.jpg
https://dl.dropbox.com/u/91815060/my...e/IMG_0319.jpg
Thanks so much for any ideas!
Pictures:
Quoted: 17 Post(s)
Liked 39 Times
bump.
That's an impressive bike, banjax, whoever made it. I'm pretty sure it's French but that doesn't narrow the field of possibilities much.
- Auchen
- Auchen
Decrepit Member
The way to tell if the frame is French is to measure the tubing diameters. Older French frames are metric and will have a 26.0mm top tube and 28.0mm seat tube and down tube. If the top tube diameter is 25.4mm (1") and the seat tube and down tube are 28.6mm (1 1/8"), it uses English dimensioned tubing and most likely is not a French frame.
EDIT - I should probably add that the primer and paint can add several tenths of a millimeter, so if you use a caliper to measure the tubing diameter you'll need to take that into consideration.
echo victor
Classic & Vintage
15
06-07-16 05:45 AM
jmagruder10
12
10-03-11 11:42 PM
