Tubeless Tire Blew Off The Rim
Quoted: 167 Post(s)
Liked 11 Times
I was installing a tire after I got a flat yesterday (sealant was dried up). Anyway when I was airing up the tire it blew off the rim so, I installed a new tire and seated it and now it appears as though the rim is bent.
I was wondering if blowing a tire off the rim would result in a bent rim?
The bent rim may well be why I got the flat in the first place because, the flat right after I hit a deep rut. I couldn't find any leaks so, I aired the tire up and rode a few more miles only to have it go flat again which is when I discovered the sealant was dried up (I was experimenting with a new sealant which clearly doesn't last as long as Orange Seal).
Any thoughts?
Any thoughts?
Quoted: 714 Post(s)
Liked 800 Times
I have never blown a tubeless tire off a rim, so I can't say for certain what would happen. I can tell you from experience that the most likely sequence of events for your bent rim was this:
Hitting the deep rut compressed the tire all the way to the rim, allowing the rim to contact the ground and bend. This also could have pinch flatted the tire(cut the tire by pinching it between the rim and a hard surface) or just unseated the bead and allowed the air to escape from the tire.
Most of my rims have several bends that occurred in a similar fashion. Its the price you pay for trying to find just the right air pressure to absorb bumps without smashing rims. I am usually able to straighten the edge of the rim with an adjustable wrench. It will never look like new, but the tire seats fine.
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
Here is my story of compounding stupid choices. I had not ridden the bike in months and when I retrieved it from the basement the front tire was flat. GravelKing 42. I decided it was a good time to add some sealant but it was cold in the garage. I added sealant, pumped to the 60psi max and set the wheel near a heating vent in the kitchen, thinking to spin it occasionally to distribute the sealant. Fortunately I was in another room when it exploded. The wheel was on one side of the room, the tire on the other and Orange Seal was everywhere. The rim was bent and the tire bead was ruined. Yes, they can explode....
Quoted: 1873 Post(s)
Liked 692 Times
Yeah a tire blowing off the rim can bend the rim. Done it with a road tire and tube once before.
2019 Salsa Warbird
2019 Salsa Warbird
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I still have sealant on the ceiling in my garage. It blew off at night and dried before it could be cleaned.
Surprisingly, it stained the white paint on my Subaru and took a little while to get the discoloration to go away.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Wow, sounds crazy.
I like to seat my tire before putting sealant in it. I pump it high, let it pop onto the bead, and check to see that it is evenly seated before going further. Sometimes they have a difficult time seating correctly all the way around.
(of course skinny strippers make it easy to get a good air seal and harder to blow off when initially installing the tire, blah, blah, blah...).
Be safe out there. At least the blow offs always seem to be on initial install. That could put one in the hospital if you were on the road.
Expired Member
Liked 5,448 Times
It cleaned up pretty easily from the hard surfaces- floor, cabinets, table, chairs, window sills, etc. It did stain the painted drywall. Repaint is pending but for now there are patches of different colors to ponder.
- Soli Deo Gloria -
Liked 736 Times
Thanks for the tip about not leaving cold tires in front of the heat vents!
-Tim-
Likes For TimothyH:
Expired Member
Liked 5,448 Times
I don't know about well adjusted but I confess I'd rather be out riding than doing home maintenance. I have a long list of stuff I probably ought to do, but putting up with cosmetic deficiencies seems to get easier each year! At least at my age, anything I actually get done won't have to be done again....
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Quoted: 6975 Post(s)
Liked 10,975 Times
The bent rim probably came first, the tire blow-off second. Even at that, the one may not have necessarily caused the other.
