For the love of English 3 speeds...
Old 02-25-10, 05:08 PM
  #76
buck mulligan
I'm shovel-ready!
buck mulligan's Avatar
Bikes: Raleigh Sports All-Gold
Originally Posted by AL NZ View Post
A 1938 Sachs Torpedo Dreigang, not a SA, but here's how I did it
I only wish I had a dedicated work area to devote to the task. In the absence of such an area, I just strung all the tricky parts - the washers, spacers, nuts, cones, etc. - from each side of the mechanism onto a wire tied off at both ends. That way, I could throw everything into a plastic bag until I can get back to the project, and rest assured that all the parts will retain their correct order and orientation.
buck mulligan is offline
Old 02-25-10, 05:26 PM
  #77
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 46 Post(s)
I have an SA SW hub that I need to refurbish... more out of interest than actually wanting to put it into regular use.
These were not produced for very long as they suffered from design flaws and were supposed to replace the AW... they were only fitted to bikes for a few years before the AW was put back into production.
I am sure many SW hubs were also replaced and then tossed out so they aren't that common.
The holy grail of three speeds would of course be the ASC which is a 3 speed fixed hub... Sun Race / Sturmey Archer has reintroduced this as the S3X which can also be run as a conventional 3 speed with the use of a single speed freewheel.
A friend of mine has a massive collection of SA hubs, shop manuals, and paraphanelia and every once in a while he parts with his spares... hoping that he finds that he has one too many ASC hubs at some point.
Sixty Fiver is offline
Old 02-25-10, 05:43 PM
  #78
buck mulligan
I'm shovel-ready!
Didn't Sheldon Brown say that "AW" stands for "always works," and "SW" stands for "seldom works?"
Old 02-25-10, 05:52 PM
  #79
Sixty Fiver
Quoted: 46 Post(s)
It is quite possible... the SW was a troublesome hub in that they are beautiful when they work but are not as robust as the venerable AW which never seems to quit.
Old 02-25-10, 06:15 PM
  #80
jamesj
jamesj's Avatar
Bikes: 2015 Specialized AWOL, 2006 Paul Frank Cruiser, 1987 Specialized Street Stomper, 1980 Trek 412, 1979 Raleigh Sport,
Quoted: 61 Post(s)
I think this thread is the Thread of the year!
Nothing but awesomeness in this thread!
jamesj is offline
Old 02-25-10, 06:38 PM
  #81
bikamper
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Other than worn bearings and dryed 3n1 oil, I rarely find anything amiss in an AW hub. At least, until I came across this while rebuilding a friends hub.
http://www.flickr.com/photos/21499296@N08/3430238106/
Other than a cable, the only breakdown I've ever had on one my own hubs was a split clutch slider on my first fixed AW after 600 miles. Replaced it and have almost 4000 trouble-free miles since then.
I use Mobil 1 0-40W to lube my AW, AM, FW and S5 hubs. A bit spendy, but required for Mrs. Bikampers car, so I keep an extra quart around.
Don't be shy about tearing into an AW, they aren't daunting and you won't learn anything if you don't make a few mistakes along the way.
bikamper is offline
Old 02-25-10, 08:13 PM
  #82
noglider
noglider's Avatar
Quoted: 5638 Post(s)
Liked 220 Times in 159 Posts
I agree. It's really great to read.
buck mulligan, I googled that and found this.
Sixty Fiver, what was good about the SW?
The 3-speed fixed gear sounds like fun. The new one is not available separately yet, is it? And I bet it's expensive.
noglider is offline
Old 02-25-10, 08:39 PM
  #83
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 200 Post(s)
Liked 8 Times in 6 Posts
I've never been interested in owning/riding a planetary hub since for me the limited range/large steps and loss of efficiency compared to derailleurs are not acceptable compromises. That said, I find them fascinating technically. My dad was into overhauling them when I was a kid, and there were certainly many bikes around in the neighborhood with the ubiquitous SA three speed hub. I think several bikes in the family had that setup; my dad's, my mom's (not that either of them rode much) and maybe one of my sister's bikes at one point. But I went straight from a coaster brake to a 10 speed.
So, anyway, can you SA planetary hub geeks direct me to a site with detailed design info? I'd be interested to learn details about how the different ratios are effected (I've studied planetary gears in the past, and have a general understanding of the different ways they can be implemented - for instance, lepelletier gearsets; I've even fully overhauled a ZF 4HP18 automatic transmission; so I'm looking for really detailed info, not a general overview or how to.
Geoff
"There is no Fail without Try" - Yoda Simpson
old's'cool is offline
Old 02-25-10, 09:47 PM
  #84
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1773 Post(s)
Liked 106 Times in 79 Posts
I've seen bad planet gears before, but usually on newer (late 1970s) hubs, not a 1950s hub. The 1950s hubs were very well made but by late 70s cheapness had crept in and the innards were noticeably poorer construction than earlier units.
JohnDThompson is offline
Old 02-25-10, 09:49 PM
  #85
bikamper
old's'cool-A lot of detailed technical info here.
http://www.users.globalnet.co.uk/~hadland/gear.html
Won't argue the range or steps with you as far as 3 speed hubs are concerned, but don't believe what you hear about the inefficiency of hub gears. While you are perusing that link, click on the link for hubstripping.com. You might be surprised.
bikamper is offline
Old 02-25-10, 09:50 PM
  #86
noglider
noglider's Avatar
I've seen worn pawls and clutches. These things do see wear, but overall, they are remarkably reliable.
noglider is offline
Old 02-25-10, 09:51 PM
  #87
bikamper
That was quite a surprise. Beautiful bike, too. Wish I had pics of it.
bikamper is offline
Old 02-25-10, 09:56 PM
  #88
Chris_in_Miami
missing in action
Chris_in_Miami's Avatar
Quoted: 13 Post(s)
My '63 Phillips will probably get replaced by my Super Course, but I'm enjoying it until then:
Chris_in_Miami is offline
Old 02-25-10, 10:01 PM
  #89
gna
Count Orlok Member
gna's Avatar
Bikes: Raleigh Sports, Raleigh Twenty, Raleigh Wyoming, Schwinn Le Tour Luxe Frankenbike
Quoted: 29 Post(s)
Here's an article on the SW on Sheldon Brown's site by Brian Hayes: http://sheldonbrown.com/sw.html
It sounds like a near miss--it coulda been a contender.
Oh, and Mark Stonich posts on here as MnHPVA Guy. Very nice man, very helpful, very knowledgeable. I tore apart my first AW hub using his tips and an old copy of Glenn's. It was fun, and I learned a lot.
gna is offline
  #90
Sixty Fiver
Quoted: 46 Post(s)
The SA AW is considered to be one of the most efficient drives of any type with a 97% efficiency... because of cross chaining and their susceptibility to contamination a derailer system can lose efficiency very quickly.
This only speaks to the drive's efficiency... a wider gearing range can make a rider more efficient even if the drive is not.
Old 02-25-10, 10:02 PM
  #91
bikamper
Chris-That fork crown on the Phillips looks similar to a Dunelt.
bikamper is offline
Old 02-25-10, 10:06 PM
  #92
Chris_in_Miami
missing in action
Quoted: 13 Post(s)
Yep, I've seen them on a few Rudges also.
Old 02-25-10, 10:25 PM
  #93
MnHPVA Guy
Quoted: 9 Post(s)
Liked 3 Times in 1 Post
Yes they are fun. In fact the word "fun" seems wholly inadequate.
Your local bike shop can order you one through United Bicycle Supply. I've had mine for 3 weeks now. If your LBS isn't interested in ordering one you can get one through Bike Tools Etc
Nope. MSRP for hub kit with shifter is $225 or less than 1/2 what you would pay for an old ACS w/o a shifter. I think it's safe to assume the new one is much tougher. I had thought I'd prefer the ACS' tighter ratios. But now that I have some miles on the S3X I like the ratios.
MnHPVA Guy is offline
Old 02-25-10, 10:34 PM
  #94
Sixty Fiver
Quoted: 46 Post(s)
I also like the decision that Sun Race made when they decided to give the S3X a wider range as it makes it pretty versatile... have been trying to find out what range of cogs they are offering as these are not interchangeable with anything.
I would not be happy using a 12 or 13 tooth cog unless it was on my folder...
Old 02-25-10, 10:54 PM
  #95
old's'cool
curmudgineer
old's'cool's Avatar
Quoted: 200 Post(s)
Yeah, I figured that would draw some controversy. Needless to say, I am not one to cross-chain or let my chain & sprockets get appreciably contaminated. If I remember my mechanical engineering classes, planetary gears losses (compared to a chain drive) come from sliding action of gears (i.e. when not in direct drive) plus the multiplicity of gears.
bikcamper, great link!, I really enjoyed the tech article by Jim Gill.
Geoff
Old 02-25-10, 11:36 PM
  #96
benajah
One legged rider
Bikes: Kuota Kharma, Surly LHT, CAAD9, Bianchi fg/ss
Beautiful bikes. One thing I miss on BF because I don't look at the vintage section much is just old fashioned, solid, reliable bikes. Nobody made this work in the 20th century quite like the British did. Perhaps the Italians perfected the racing bike, but the British perfected the everyday bike.
benajah is offline
Old 02-25-10, 11:45 PM
  #97
MnHPVA Guy
Quoted: 9 Post(s)
3/32"are available in 12 and 13. 1/8" are available in 12 through 18t. Cogs are inexpensive.
I got 16, 17 and 18t. Currently running 46/17 on the left side of the bike with 145mm cranks.
I think the splines are the same as Shimano Cassette cogs.
Old 02-25-10, 11:57 PM
  #98
Sixty Fiver
Quoted: 46 Post(s)
The new S3x uses a 9 spline pattern (like Shimano cassettes) but have been told it is not compatible with Shimano cassette cogs... thinking that it might use 9 identical splines like the old Uniglide.
I will have to look up those cog specs although one would not want to run a ramped cog with shorter teeth on a fixed drive anyways.
Old 02-26-10, 07:29 AM
  #99
rhm
multimodal commuter
rhm's Avatar
Quoted: 1570 Post(s)
Liked 21 Times in 19 Posts
The new Sturmey Archer 5 speed wide range hub has the same ratios as the AW plus a super low and a super high. The gearing is:
1 ----0.62
2-----0.75
3-----1.00
4-----1.33
5-----1.60
I've ridden this about seven miles so far, so I'm not going to present myself as an exert yet! But my initial reaction is that the gears are too far apart. That is, I really miss the close ratios of my Sturmey Archer 8 speed hubs. I'm sure I'll get used to it, though. Photos to follow!
rhm is offline
Old 02-26-10, 08:18 AM
  #100
MnHPVA Guy
Quoted: 9 Post(s)
I just checked. You have been misinformed.
The advantage is that you can use some of the higher quality cogs, such as Surly, that are designed for SS conversions on cassette hubs. And of course the SA cogs could be used as a lower cost option for SS/Cassette conversions.
I'm fairly certain that Shimano BMX cogs are also compatible. These appear to be the same quality as the Sturmeys but may be more readily available in your area.
