Carry a Spare Skewer?
Old 05-12-11, 01:45 PM
nameless
Bikes: Custom Gunnar Roadie
The skewer is probably an overlooked item to carry as a spare on tour but without one, a broken skewer on a lonely road could be pretty debilitating.
Anyone tour with a skewer as part of their spares/tool kit?
Is there a quick fix for a broken skewer that doesn't necessarily require a spare?
What would be a light and cheap option for a front wheel spare skewer?
nameless is offline
Old 05-12-11, 02:29 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6907 Post(s)
Liked 240 Times in 198 Posts
For cooking Kabobs?
the sort that screw on, allen bolt, are easy to stow, if the desire to carry 1 arises.
fietsbob is offline
Old 05-12-11, 02:42 PM
WalksOn2Wheels
Vain, But Lacking Talent
WalksOn2Wheels's Avatar
Bikes: Trek Domane 5.9 DA 9000, Trek Crockett Pink Frosting w/105 5700
Quoted: 1307 Post(s)
I must say, I don't think I've ever heard of a skewer failing. I tend to take the minimalist approach, but it seems like if you're ready for that to fail, you might as well carry an extra rim as well, just in case yours cracks in half, right? And don't forget the extra brake assembly. Oh, and a set of bars in case one side snaps off.
At best, I would see the need for an extra rear skewer on bikes with more inboard mounted bearing on the rear wheel. You know, the freewheel types where the bearing re closer to the hub of the wheel. That would be a situation where I could see one coming in handy. But for most bikes, I don't forsee that being a problem.
As for a quick fix, I would check out the local hardware store. I imagine you could cobble some sort of makeshift skewer together with a bit of allthread, nuts and washers.
WalksOn2Wheels is offline
Old 05-12-11, 03:28 PM
fuzz2050
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 16 Post(s)
I don't think I've ever broken a quick release skewer, and I've broken a lot of bike bits.
fuzz2050 is offline
Old 05-12-11, 03:34 PM
Bacciagalupe
Professional Fuss-Budget
Bacciagalupe's Avatar
Quoted: 20 Post(s)
I would imagine that if something happened that actually damaged your skewer, it's going to take out your entire wheel and/or fork. In which case, replacing the skewer is probably the least of your worries....
Bacciagalupe is offline
Old 05-12-11, 04:07 PM
manapua_man
Quoted: 222 Post(s)
I've only had a skewer break on me once, and then I later noticed that the axle had bent, so i would up having to change that too.
manapua_man is offline
Old 05-12-11, 04:44 PM
KDC1956
KDC1956's Avatar
Bikes: Surly LHT 52cm Nice Bicycle I think.
Yes I have a set of them.You never know what can and will happen.I have strip one before so I was glad to have one.And that did it for me I have them on hand they don't cost much and damn sure don't weight much either.I really don't care if people likes it or not I,m the one on my bicycle and if the part needs to be replace so be it.My 2 cents lol
KDC1956 is offline
Old 05-12-11, 05:36 PM
Chris Pringle
Chris Pringle's Avatar
Bikes: '12 Rodriguez UTB Custom, '83 Miyata 610, '83 Nishiki Century Mixte (Work of Art), '06 Specialized Epic Marathon MTB
Quoted: 20 Post(s)
Have never broken my wheel quick release skewer. I've managed, however, to brake the seatpost quick release before on an actual ride. Luckily, I wasn't too far away from my destination. My LBS said this happens more often than one may think. I do carry an extra one now as those may be more difficult to find depending on your seatpost size or if you're traveling in remote or third world countries.
Chris Pringle is offline
Old 05-12-11, 06:20 PM
spinnaker
Every day a winding road
spinnaker's Avatar
Quoted: 3388 Post(s)
Liked 59 Times in 42 Posts
If you carried a spare for everything that could go wrong, you wouldn't be able to carry any other gear.
What about a wheel? More likely you would break one of those.
spinnaker is offline
Old 05-12-11, 06:38 PM
mev
bicycle tourist
Bikes: Trek 520, Lightfoot Ranger, Trek 4500
Quoted: 209 Post(s)
Liked 9 Times in 8 Posts
Like this? http://www.mvermeulen.com/canada/fotox/jul12_04.jpg
mev is offline
Old 05-12-11, 06:40 PM
Cyclebum
Cyclebum's Avatar
Bikes: Tour Easy, Linear USS, Lightening Thunderbolt, custom DF, Raleigh hybrid, Felt time trial
The only skewer issue I've ever had was when fixing a flat, I lost the nut in a forest of leaves. Made it to a hardware store in the next town, sans skewer, and found a replacement nut that sufficed until I got to a bike shop a couple days later.
Discovered that a skewer is not absolutely required, as long as the road is smooth and you ride very carefully. It's only purpose is to tension the fork against the hub to keep the wheel from coming off when you hit a bump.
Point: Don't lose the skewer nut.
Cyclebum is offline
Old 05-12-11, 06:45 PM
Chris Pringle
Quoted: 20 Post(s)
I am sure the O.P. is smart enought to draw the line somewhere. He's simply trying to gather info if this spare part makes sense... if it's an important little thing that could save him in the middle of nowhere. Just like one wouldn't leave without spare tubes, extra spokes, brakes pads, and things of that nature. If one is new to touring, it makes sense to ask other fellow tourists what their experience has been.
Old 05-12-11, 06:52 PM
spinnaker
spinnaker's Avatar
Originally Posted by mev View Post
I have seen others doing this! Do you carry a front and rear?
Old 05-12-11, 07:22 PM
nancy sv
family on bikes
nancy sv's Avatar
Bikes: which one?
I think it was Sonya and Aaldrick at http://www.tour.tk/ who broke a skewer. They ended up finding wire on the side of the road and finagling it til they got to a town. Not the best solution, but the likelihood of a skewer breaking is pretty slim...
nancy sv is offline
Old 05-12-11, 07:46 PM
gubaguba
Bikes: Bob Jackson, Daccordi, Trek 2300
Carry a spare
Technically no weight is carried on the skewer. I guess one could break but not any more likely than any other bolt. In 35 years of cycling I never broke one. I have wore out several sets of bearings, wheels, freewheels never a skewer.
gubaguba is offline
Old 05-13-11, 12:16 AM
Camel
Caffeinated.
Camel's Avatar
Bikes: Waterford 1900, Quintana Roo Borrego, Trek 8700zx, Bianchi Pista Concept
I took a spare rear skewer on my year tour. It's the allen head bolt on type, so no big deal to have in my tool bag.
I also now carry a spare seat tube binder bolt on most rides (not just touring), because I've broken a whole bunch of them.
Camel is offline
Old 05-13-11, 02:23 AM
MichaelW
Quoted: 17 Post(s)
Skewers are critical if your bike has horizontal dropouts. For vertical dropouts, you can use a lashup of anything to get you to the next town, ie some brake cable, doubled up and tensioned like a tourniquet.
I bent my skewer at the base of the threads when using a cassette remover (NBT2). It held up for the rest of the long tour but has been weakened.
MichaelW is offline
Old 05-13-11, 04:23 AM
Rowan
Quoted: 1434 Post(s)
Liked 24 Times in 16 Posts
I haven't broken a skewer on any bike, but I have broken a rear horizonal dropout just before a 400kim randonnee, but didn't realise it (bike fell over on the right side during a big wind gust).
I rode the randonnee, but wondered why the shifting into the big cogs was off, and why the chain shifted off the biggest into the spokes a couple of times. I didn't find the break until I got home from the event. It goes to show how the skewers can keep things together.
The other skewer-related problem was a groove worn into the dropout on the same bike. This was before a 1200 randonnee and the wheel wouldn't stay straight, no matter how tight I did up the skewer. I bought a new one from the only MTB shop in town. I eventually understood the problem, and smoothed down the dropouts when I repaired the broken one.
So... based on my experience, no, a pair of skewers would not be on my list of spares.
Rowan is offline
Old 05-13-11, 07:11 AM
tarwheel
tarwheel's Avatar
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 194 Post(s)
In 35+ plus years of cycling over 80,000 miles on 10+ different bikes, I have never broken a skewer. Anything is possible, but I don't see the need to plan for every contingency. Besides, a skewer should be available at virtually any bike shop. Why not just haul a whole trailer full of spare bike parts?
tarwheel is offline
Old 05-13-11, 07:21 AM
staehpj1
staehpj1's Avatar
Quoted: 237 Post(s)
Liked 19 Times in 16 Posts
It sounds like one of the least likely parts to need. In 50 years of cycling I never broke one. If touring in a first world country worst case you would have to hitch a ride to a bike shop.
http://www.crazyguyonabike.com/staehpj1
staehpj1 is offline
Old 05-13-11, 07:31 AM
bike_boy
Lula Mae = 15 lbs.
bike_boy's Avatar
Bikes: 2011 Trek Madone 6.5 w/SRAM Red
In lieu of spare skewers, carry a couple of spare conical springs that go on skewers. I have inadvertently removed skewer nut from skewer when loosening to remove wheel; conical spring fell off and bounced away.
bike_boy is offline
Old 05-13-11, 07:51 AM
KDC1956
KDC1956's Avatar
Good Idea would you do it for us???
KDC1956 is offline
Old 05-13-11, 08:41 AM
Dan The Man
If I ever broke a skewer, I would probably just run some 3mm cord through the axle and tie nuts, or sticks, or knots or something on the ends to hold it together. I've replaced a broken drive side spoke with some nylon cord, it's great stuff to have around.
That gives me another idea, if you have a spare spoke, just stick that through the axle and then tighten it by wrapping it around the bottom of the fork dropouts. Gotta be tight enough that the fork can't flex open and drop your wheel.
Either way, it's an unlikely fix. Might as well bring a spare frame with you, "just in case"
Dan The Man is offline
Old 05-13-11, 10:10 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
With a vertical rear dropout on your frame, neither skewer has to be very tight...
the load is of course supported by the axle, not the Qr skewer..
fietsbob is offline
Old 05-13-11, 11:45 AM
CCrew
Older than dirt
CCrew's Avatar
Bikes: Too darn many.. latest count is 11
Actually I do carry a spare rear skewer.
That said, it's only because I pull a BOB trailer and it's not unheard of to thrash one.
CCrew is offline
