Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Any Cateye CS1000 trainer experts out there?
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 02-18-14, 10:55 AM
Mikey58
Bikes: '68 Schwinn Racer 3-spd, '74 Paris Sport, '84 Specialized Stumpjumper XT, '01 Trek Fuel 90, '12 Felt TK2
Our track team has a *fleet* of about 20 Cateye CS1000 Cyclosimulators (aka the Psycho-Stimulator). They all seem to have their own issues. I'd like to restore as many of them, if possible, to their original functionality.
I've downloaded the manual. Looks as though spare parts are few and far between. Also, FWIW, I consider myself to have better than average mechanical skills and any tools that may be required.
So, does anybody out there have any maintenance/repair experience with these?
First issue to address is a flaky %grade display - does not step through 1 -10% - just displays 4%, 3%, 3%, then 4%.
Any suggestion as to where to start in the troubleshooting process?
Also, any recommended PM procedures, generally speaking?
Just looking to cut some time off of the learning curve - any help greatly appreciated!
Mike
Mikey58 is offline
Old 02-18-14, 12:47 PM
Mikey58
xengravity - I got your PM but the system won't let me respond with a PM (I have less the 50 postings). So, to answer your question, we are also looking for those small plastic inserts that engage the skewers - not a single one has survived!
Mikey58 is offline
Old 02-18-14, 02:02 PM
carleton
Elitist
carleton's Avatar
Quoted: 1221 Post(s)
Liked 5 Times in 5 Posts
I used one for a few years then gave it to a good friend.
- I would totally disregard the power readings on the display. I had a track bike with an SRM attached, and the numbers rarely coincided (300W on my SRM head unit wasn't 300W on the Cateye display). I never turned the unit on.
- If you do use the numbers, use them as relative measures for each individual machine. This is because the resistance is made by the cable adjusting how close the Eddy Current Resistance Unit thingy was to the other thingy (scientific term). Anyway, 1 cable could be a bit more stretched than the other. The lever is indexed, so if it's not calibrated, then it could be off. Think of an uncalibrated rear derailleur.
- If you want numbers maybe try the Kurt Kinetic Road Machine. They have published a power band that is directly related to the speed you turn the trainer. Basically Xmph = Ypower. They even sell a speedometer that displays power.
- I would remove the wind resistance unit (the fan blades). It just makes a lot of noise and doesn't really provide much resistance. Maybe it cools the other side, but I don't think so. Mine worked fine after I removed mine.
- I would only use them for Sprint type efforts (standing starts, short efforts with negative splits (flip the lever for more resistance), etc...). For longer efforts a normal fluid trainer would be better, especially when using a road bike that way you can dial in the right cadence and torque combination.
- Sprinters love the fact that the resistance unit is so strong and the fork stand is so steady. I haven't seen a modern mag trainer that can provide nearly as much resistance. I'm talking: It can handle over 2,000w. Most other commercial fluid or mag trainers can't handle much over 1,000w.
- If you use a road bike on it, it will feel awful with the really light flywheel and the linear, notched resistance. It doesn't feel natural in any way.
- Cateye probably doesn't have much stock of replacement parts...if any.
- You can engage track nuts without using the plastic inserts. I didn't have any on mine.
Sprinters would buy them from you.
I would't bother scavenging parts from other machines to make a 100% perfect machine. If the resistance unit works and the copper disk isn't warped, it's useful.
carleton is offline
Old 02-19-14, 12:04 PM
Mikey58
Agreed - one of my teammates has an SRM on her Dolan. Looks like the Cateye is optimistic to the tune of 100 - 150W at a full load of approx. 1200W.
Thanks - sounds like at least checking the copper disc for runout and proper clearance would be worth the time.
Our team actually took delivery of a Wattbike about three weeks ago. Everybody sorta is getting a feel for it right now but it should be a good source of reliable data. Unfortunately, we only have one, so seat time for every team member is limited.
Our training on these is virtually all sprint efforts, so we're good-to-go in that respect.
Yes, if Sir Chris Hoy can't break one, I'm not sure anybody can
Yes!
Duly noted!
Thanks again, carleton, for your input - greatly appreciated!
Mike
Mikey58 is offline
Old 04-17-14, 07:41 AM
JMCX
Mike
I can help walk you through fixing the grade % on the displays. If you're still interested, just email me at jcalabrasi@gmail.com
JMCX is offline
Old 04-18-14, 01:57 PM
Mikey58
Email sent, thanks!
Mike
Mikey58 is offline
Old 07-11-14, 12:50 PM
kiwibykr
Bikes: Guerciotti something- '79-'84?; 2011 sl2 roubaix; 2008 avanti giro permanently mounted on a cateye cs1000
Gidday, does anyone know- does the ring that passes through the slot of the speed sensor pickup need to be "complete" for the sensor to pick up the signal? My speedo and therefore distance functions have stopped registering and it appears the ringwhich has slots cut in it (i guess it is an optical sensor rather than a magnetic one) has bits missing off it but i didnt see any bits lying anywhere, cant figure out how it may have got damaged.
Any advice greatly appreciated.
kiwibykr is offline
Old 03-30-19, 09:30 AM
azaref
Cateye CS 1000
Mikey58
I have a Cateye Cyclesimulator CS 1000. Great condition for parts. All works except for the electronic device which was cracked in a recent move.
Free to you, an enthusiast, if you want to pick it up.
I see that it is not easy to find parts.......
azaref is offline
Old 04-01-19, 02:28 AM
ruudlaff
Quoted: 73 Post(s)
If anyone out there wanted to dispose of one let me know.... UK
ruudlaff is offline
Poguemahone
Classic & Vintage
5
07-04-12 03:18 PM
corwin1968
13
12-16-11 09:40 PM
sanfranguy06
Road Cycling
2
06-27-11 07:32 PM
jaxgtr
25
04-09-07 06:30 AM
cs1
Bicycle Mechanics
2
07-07-05 10:55 AM
