Disc mechanical caliper replacement
Hi all,
I was adjusting my rear caliper pad when I gave it too much force and broke it. Now I need to replace it, so I bought a Shamino BR-M375 disc brake caliper thinking they were universal but it doesn’t appear so.
I attached some pictures of my set up. It’s a CO-OP ard 1.1 from REI. Can I get an adapter to make the M375 work, or should I return it and get a different brake? Are my holes standard? Should I just try to buy a replacement of the same kind? The Decode R brakes are about $80 for a replacement rear.. I think I could do better on price though.
i cannot attach photos until I have 10 posts, but I think I can PM the photos if someone would like to take a look
thank you for any input
Quoted: 18378 Post(s)
Liked 4,512 Times
Liked 4,512 Times
Ok, your CO-OP bike should be pretty new as they changed the name on them a couple of years ago.
About 4 years ago Shimano introduced what they call "Flat Mount" disc brakes. In particular it moves the rear brake to a spot inside the rear triangle.
https://road.cc/content/buyers-guide...ut-disc-brakes
I'd get the correct brake, but I'm not quite sure which one.
Can you see any numbers on the old brake once you have it off?
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,600 Times
Thread moved from General Cycling Discussion to Bike Mechanics.
Yes, you can get an adapter to make the post mount brakes work with a flat mount bike. I have no idea how well they work, but since companies such as Shimano and TRP make the adapters, I'm sure they aren't complete hacks.
You probably want to go to a shop to figure which adapter you need. Maybe it's a simple "flat mount to 160mm rear post," or something, but I honestly don't know.
Edit to add: I'll take your word for it that your caliper is broken. From the pictures, there's nothing obviously wrong with it.
Liked 4,512 Times
Ahhh... so you have the Promax Decode R Flat Mount Brakes.
They actually look very similar to the TRP Spyre brakes.
https://www.ebay.com/itm/Promax-DECO...e/183920235214
So, I think the ARD is a Drop Bar bike, And requires a short-pull ROAD brakes. Thus, your Shimano M375 brakes probably are not appropriate.
So, I'd go back to either the Promax or TRP flat mount ROAD/Cyclocross brakes.
https://www.ebay.com/itm/TRP-Spyre-F...r/303334583797
https://www.ebay.com/itm/TRP-Spyre-F...e/123561973458
One of the more unique brakes that you should also consider are the TRP HY/RD Flat Mount Cable Actuated Hydraulic Brakes.
https://www.ebay.com/itm/TRP-HY-RD-M...k/254389114403
Hi.. I just got my first road bike with Promax Decode R disc brakes. I'm looking for the right tool to adjust pad clearance. Hex keys don't seem to fit. Could anybody help me on this? Thank you.
Quoted: 2026 Post(s)
Liked 1,096 Times
What the OP has is a near twin of the TRP Spyre or Tektro MD-C550 Flat Mount brakes. That F:160 adapter is a TRP/Tektro part. Either of these brakes will be a direct replacement for the broken "Decoder" brake.
