Fuji Del Rey 12 speed conversion to 2x7 speed STI?
Old 06-28-20, 06:15 PM
rickpaulos
Quoted: 121 Post(s)
Liked 150 Times in 89 Posts
Got a friend who wants me to convert a vintage Fuji Del Rey 12 speed with Fuji branded Suntour VX rear der and Suntour front der to STI shifting.
here is the plan:
Shimano Tourney STI lever set 2x7.
7 speed freewheel and chain
longer rear axle & spacer.
respace frame from 125mm to 130mm (done many frame respacings).
Will the Tourney 7 speed sti shifters work with the Suntour derailleurs?
The bike is in pretty good condition and it seems to have more sentimental value so it's worth it to the friend to do this. The bike appears to have very few miles on it. Probably from 1978-1982.
rickpaulos is offline
Old 06-28-20, 07:46 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
For 7 speed you won’t need to go to 130mm. 7 speed is 126mm.
You’ll need to change the derailleurs to Shimano. I’ve heard folklore of people being able to use a Suntour FD on a 2x, but buy a Shimano FD.
You’ll need to get new cables and housings.
You’ll need downtube boss cable stops.
Use a Hyperglide or Sach Aris freewheel.
John
70sSanO is offline
Old 06-28-20, 08:18 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
John
+1, you will save a lot of headaches for little expense by going with Shimano (or compatible, like Microshift) derailleurs. You can use up to 9-speed or road 10-peed with your levers.
dsbrantjr is offline
Old 06-28-20, 08:29 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
If you "have to" spend the $ for shifters & DER's, you might as well go to 9/10 speed with a new FH rear wheel.
Of course, if you already have the parts and are doing it at minimal $, that makes sense too.
It's kind of a - if one more cog costs $XX.XX, how much more is 3-4 cogs?
Since you know how to cold set, which still isn't a bad idea even for 7 speed. Makes a much stronger wheel.
Bill Kapaun is offline
Old 06-29-20, 06:30 AM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
Maybe on the front, but not on the rear. The pull ratio on the Suntour RD isn’t quite right to work with Shimano index spacing. You can get 3, maybe 4 gears to work, but not more. Which is a shame, because the Vx is a nice piece of hardware, and yours appears to be in good shape.
I have a V-Gt that I run with a modern Shimano FW (6-speed) and an 8-speed KMC chain. The modern chain and cog profiles do so much to improve shifting compared to the flat-sided 1970s OE, I don’t miss the indexing.
If if your friend just wants on-the-hoods shifting, you could explore using a Gevenalle style shifter, along with a modern FW and chain, would give good performance out of the original hardware.
Ironfish653 is offline
Old 06-29-20, 08:02 AM
rickpaulos
Quoted: 121 Post(s)
Gevenalle style shifter ???
Can say I've never heard of that.
Old 06-29-20, 10:20 AM
Ironfish653
Dirty Heathen
Quoted: 889 Post(s)
Gevenalle is one of the brands, RetroShift is another, of a style of shift mount that lets you mount a DT or bar-end style shifter on a traditional brake lever. Similar in operation to a brifter, but without the ratchety bits. Developed for CX, because they’re simple and rugged, also with Adventure tourers, because you can use a friction lever to run MTB derailleurs that aren’t compatible with road shifters.
[img]blob:https://www.bikeforums.net/cb1c71ec-d04a-48d9-8d6a-8b1a0f16ef64[/img]
Old 06-29-20, 10:37 AM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
Liked 92 Times in 75 Posts
Has your friend tried Tourney STI? From what I remember, some of that cheap Shimano STI stuff can be pretty lousy to use. But that was years ago and my memory may be off.
How heavy is your friend? 7-speed freewheels are almost a guarantee for bent axles unless the rider is very light and careful, or the hub is specifically designed for such use (yours isn't). I'd recommend going all the way to an 8/9/10 speed rear cassette wheel which opens up a lot of options.
FastJake is offline
