Go Back  Bike Forums > Bike Forums > Utility Cycling
What wheels do I need for a cargo bike?
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 06-16-18, 11:28 PM
CosmicCycling
Building a cargo bike, front load with two wheels on the front. I would like to use smaller wheels, as it gives more room to use in the cargo area, rather than having two large wheels sticking to far up. I plan on using 20 inch wheels on the cargo area.
Main question, what is stronger? Getting two kids bikes wheels, or using bike trailer wheels?
I want to make sure that the wheels will be able to hold and last in the cargo area, up to 200 lbs. I feel like kids wheels are better, since trailer wheels are generally thinner and meant for lighter loads.
CosmicCycling is offline
Old 06-18-18, 11:59 PM
Gareth
Gareth's Avatar
Bikes: 2006 Falcon Explorer Hybrid, 2008 Landrover Visalia Crossover, 2010 Cargo Cycles Senton, 2010 Cargo Cycles Capability, and a 2001 AVD quad pedi-van, 1980 Peugeot Carbolite 10sp racer
Quoted: 21 Post(s)
Liked 24 Times in 7 Posts
Neither.
What you need is double walled 20" BMX wheels with 36 spokes and 14mm (9/16ths) axles.
This will give you all the strength you need along with a wider selection of tyres to choose from.
Alternatively you can follow my lead and use 36 hole hubs with 14mm axles and have them built with Moped rims, which is a much stronger and better option all round in my opinion and is what I use when building cargo bikes and delta mule trikes, For the tadpole trikes and quads I use 36 hole 1/2" stub axle Sturmey Archer drum brake hubs with moped rims.
Gareth is offline
Old 06-19-18, 10:36 PM
CosmicCycling
Okay, but I can not be spending hundreds on just two front wheels. I do want support and strength.
So would getting BMX tires be a better option? I can find them online for a decent print per wheel.
Old 06-20-18, 11:01 AM
Gareth
Gareth's Avatar
Quoted: 21 Post(s)
You can buy alloy double walled 36 spoke 14mm axle BMX front wheels ready made from about $45.00 apiece from ebay and amazon.
However, if you are supporting the axle on both sides of the wheel as many of the these commercially made mule delta trikes are, then a 3/8th axle will suffice, and these can be purchased for around $30.00 each.
Don't skimp or penny-pinch on the wheels …………. they are what makes a cargo bike happen!
Gareth is offline
Old 06-20-18, 01:47 PM
CosmicCycling
Me, in Canada, it is hundreds. While I can find the wheels on ebay, they are much more pricey, or does not ship to Canada.
Buying parts in Canada is a huge pain.
Old 06-24-18, 11:08 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,354 Times in 861 Posts
Must fabricate a steering system using 2 forks,
or you have to budget for single side mounted hubs and build font end around those.
Christiania trikes, build box and wheels as a unit with handle bar on the back of the box ,
steering, head tube angle, near vertical of course..
fietsbob is offline
Old 06-25-18, 05:22 PM
CosmicCycling
Yes, the two fork style is what I am planning on building into it. Much more strength than just the regular bike handlebar with the one pole. The design I found is from an another bicycle company that makes their own cargo style bike. Theirs is built like a tank, huge tires and frame, it looks awesome. But way to much for what I need, haha. But the style of the handlebar and frame for it is much better, so will be making something similar.
That single side mount is very interesting, and would look a lot cleaner. I will add this to my list of options, thank you
italktocats
Bicycle Mechanics
9
05-09-18 05:23 PM
PdalPowr
Living Car Free
12
03-01-18 09:25 PM
santinuro
Commuting
20
06-30-15 12:26 PM
Doug5150
BMX
1
11-26-12 10:42 PM
nashnut55
1
08-08-10 02:21 PM
