Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Incorrect fit causing hand pain?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 07-17-18, 07:08 PM
bicyclepost
Bikes: 2022 Kona Rove, 1991 Bianchi Ibex drop-bar conversion, 1974 Peugeot AE8 singlespeed
Quoted: 36 Post(s)
Liked 5 Times in 2 Posts
Unhappy Incorrect fit causing hand pain?
Hello, I'm new to the forum and drop bars and any kind of bikes using them and picked up my first such bike, a used Motobecane Grand Touring, for $275 a few weeks ago. I've noticed it is not the most comfortable bike and I initially thought it was something I had to get used to but haven't yet. I get pain in the palms of my hands when using the same position for just a couple minutes. It was particularly bad when riding the hoods because my hands would slide down into the brakes and cause pain between my thumb and index finger. It was also kind of difficult to squeeze my brakes from there. I talked to someone at a bike shop today and he suggested rotating the bar back so there is a flatter surface leading up to the hoods but this puts the drops in an awkward position. The guy said it's difficult to fix that problem with old bikes because of how the hoods were designed to be pointy and less ergonomic but there must be some way to fix this rather than just buying a newer bike! I also have foam grips on my bars, could this be contributing to the problem? When I go over bumps and cracks in the road there are certain pressure points on my palm that get pain and numbness shooting up them. Another piece of info I might add, the frame is 59 cm I believe and fits just under my crotch, so maybe a bit too big for me. Any help would be much appreciated! I tried to add pictures but apparently I can't until I post more.
bicyclepost is offline
Old 07-17-18, 08:18 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
Yes. Switch out your current brake levers for a set of Tektro brake levers: https://www.worldwidecyclery.com/pro...et-black-black
You can buy them many places, this was just the first on google.
As you can see, they are modern and inexpensive, though they are a good product. I have a pair on one of my bikes which has bar-end shifters.
Bar shape also makes a difference because the brake hoods need to blend with the bar to some extent.
More reading:
https://www.bikeforums.net/road-cycl...l#post12953035
https://www.bikeforums.net/bicycle-m...bar-setup.html
Drop Bar Hand Positions: an Introduction
Another problem can be too much weight on the hands which can be caused by the saddle being too far forward. In which case, moving it back can help. Moving the saddle back also increases reach which many people aren't used to. But see the photos in the Numb Hands post. As long as you don't have more reach than that, you're OK.
Results matter
Carbonfiberboy is offline
Old 07-18-18, 03:38 PM
Clem von Jones
Quoted: 151 Post(s)
Liked 23 Times in 16 Posts
Numb heads are typically caused by a combination of excessive reach and stack (height). If your current vintage handlebars are probably 25.4 dia with 100mm (they might even be 110 or 120) reach you can try these modern-style compact bars by Uno that measure 25.4* x 70mm. They'll decrease your reach at least by 3cm. Then you might lower your quill stem all the way and try that position with these compact bars. https://www.ebay.com/itm/UNO-alu-Roa...-EK_R5hFzoB6Rw
The vintage brake hoods are also pretty narrow and uncomfortable too, as Carbonfiberboy indicates. Compact bars and new brake levers to modernize your cockpit might be good idea. Think shorter reach and lower bars. Vintage bikes have enormously tall head tubes which easily creates excessive stack. On my vintage bike I ended up getting a quill stem 1-1/8" adapter with a -25 degree stem in combination with 31.8 dia compact style bars. You could also accomplish the same thing with a Nitto Jaguar (track) stem using the 25.4 Uno bars.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311.R2.TR2.TRC0.A0.H0.Xnitto+jag.TRS0&_nkw=nitto+jaguar+ste m&_sacat=0
Here's a good stem calculator you can use to contemplate different stem and handlebar combinations https://www.yojimg.net/bike/web_tools/stem.php
What is your height? 59cm vintage frames would fit someone 6ft / 183cm-ish.
EDIT: *It's come to my attention these bars are 26mm diameter, not 25.4 as erroneously described by the ebay seller.
Clem von Jones is offline
Old 07-19-18, 09:14 AM
bicyclepost
Quoted: 36 Post(s)
Unhappy
Thanks for the info but I went in to the local community bike shop yesterday and they told me it was simply too big. I'm a bit taller than 5'10" so apparently I should be looking for a 54-56 cm frame.
Old 07-19-18, 02:50 PM
Brian25
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times in 15 Posts
The frame size has absolutely 100% no chance of having anything remotely to do with serious hand pain. The number one culprit of creating hand pressure/ hand pain, by a huge margin is having the seat tilted down. Having the seat down is a serious hand killer.
Brian25 is offline
Old 07-19-18, 02:53 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
^^ yes. I'm 5' 8" and ride 54-56cm. Maybe 59 not too large for you. Try moving your saddle back to rear more...
trailangel is offline
Old 07-19-18, 07:41 PM
philbob57
Quoted: 715 Post(s)
Liked 613 Times in 377 Posts
BITD, the recommendation was 9"-10" less than your leg length, measured by, for example, jamming a book into your crotch while standing with a wall behind you - mark the top of the book, and that mark to the floor is your leg length. The 1"-2" was for prevention of pain and injury incase you had to stop very short and came down hard on the TT.
I'm 5' 7", with legs slightly shorter than average, and I could easily ride a 56. I rode a 58 for a while, and I dumped it only because I came down on the TT hard - but at least some people here scoff at that possibility.
I suspect the 59 is OK for you, though perhaps slightly big. Sizing now has people on bikes that seem very small to me for a given body size.
What have you been riding? If you haven't been riding, is carpal tunnel syndrome a possibility?.
philbob57 is offline
Old 07-20-18, 01:26 PM
athrowawaynic
Bikes: 2015 Niner RLT9, 1987 Atala
Quoted: 252 Post(s)
My first guess would be the saddle is too far forward and/or not level. Setting it back a couple millimeters should help shift your weight more rearward to take pressure off your hands.
athrowawaynic is offline
Old 09-05-18, 12:56 PM
DGP9999
Bikes: Trek SL5 Domane
I am 6' tall, 190lbs and have an inseam of 34". Have the leg length of a guy that would be 6-2 but with a shorter upper body than most 6 footers. Currently riding a Trek Domane SL5 58cm frame. The bike fits me so much better than any other I have owned in the last 40 years but I still get nerve pain in my left hand (I am right handed if it matters). I get numbness along the side of my hand where my pinky is and I get a numb pinky after about 15 miles on the road. I change hand positions frequently but still end up with pain and numbness eventually. Sometimes on longer rides like 50 miles plus I will also get soreness in the muscles that go from my neck to my shoulder but only on the right side.
I can't really afford a $275 fitting right now but was wondering if there are any clues in my description that might indicate what the root cause is. I do feel too stretched out when I am fully on the hoods or on the drop. Most comfortable riding position is above the hoods with my hands on the curved section but this is where the numbness gets me if I stay there any length of time. Everything else is perfect, no saddle issues etc. Just wish I could solve this one last issue. Have a century coming up and I don't want to finish with my left hand feeling like a dead club....
Thanks,
Dave
DGP9999 is offline
Likes For DGP9999:
Old 09-05-18, 03:26 PM
Clem von Jones
Quoted: 151 Post(s)
Dave, I think you're riding position is too high. You're getting the jack-hammer effect that travels up your arms into your shoulders and neck. The solution is lowering the bars. By lowering the bars and decreasing reach you can resolve both the hand numbness and sore shoulder and neck muscles. I think you're frame is a bit on the large side so I would consider decreasing the reach about 30mm and putting the bars as low as you can get them. Flip the stem to the negative side and slam it. Consider negative rise stems like the Syntace Flatforce, FSA SL-K -20, or something similar if your headtube is too high.
Old 09-07-18, 07:43 PM
Brofessor
Brofessor's Avatar
Bikes: Schwinn Circuit 89'
Quoted: 51 Post(s)
DO NOT rotate the bars back if you are happy with the drop position. If you want to change your on-the-hoods position, only change the position of the brakes. If you rotate the bar back to change hood position, you will mess up your drop position. Always set the bar rotation first, then set the brakes later for a good, flat on-the-hoods position.
Brofessor is offline
Old 09-07-18, 10:11 PM
Dave Cutter
Dave Cutter's Avatar
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times in 9 Posts
Hand pain/numbness is most likely caused by too much pressure on the hands. The solution is almost always correcting your position on the bicycle. Ride with weight distributed between pedals, saddle, and hands. Elbows should always be bent. If the bike is too big... you'll be unlikely to get a decent fit.
Dave Cutter is offline
Old 09-08-18, 01:10 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Question
A tall frame is also long, consider; a shorter stem ..
higher up (up angle type, or stem raiser & different length)
helps shift weight onto your saddle/backside..
your ' Motobecane ' French made ? that means parts need be French standard..
Brand name has sold off, now the newer " Motobecane " is only a name,
Bike it's applied to, is coming from Asia.. so component part switches, simpler..
fietsbob is offline
Old 09-19-18, 01:01 PM
DGP9999
Went to a shorter stem and that helped but still isn't completely solved. Less hand pressure now but then my muscles that go from my neck to shoulders started getting sore. For now I am just riding it the way it is to see if the shoulder soreness is temporary or a real problem. Next step may be to lower the stem some and then hopefully save up some coin to get a pro bike fitting done. I have a Century ride this weekend though so we will see how it all goes....
Thanks,
Dave
DGP9999 is offline
Old 09-24-18, 01:37 PM
McMitchell
Bikes: Focus Mares CX, Rocky Moutain Sherpa
Quoted: 76 Post(s)
I am 5’7”-5’8” in 5/10 bike shoes. I can damage myself trying to stand over my 54cm bike frame. Someone early on said I needed a 52cm frame, maybe? Unfortunately there is little consistency in how bike companies measure their bikes.
There is even less consistency in human anatomy. Bike fitting is more of an art, even though there is valid science involved. Flexability, injuries, nerve issues.....all can play a part in all sorts of combinations.
I am finding the ultimate solution is in experimentation. The only thing I know for sure is herniating all but one cervical vertebra does not make it easier & definitely increases hand numbness.
McMitchell is offline
Old 09-24-18, 11:40 PM
oldbear63
Bikes: Fuji road bike, Trek mountain bike
Quoted: 15 Post(s)
Liked 7 Times in 3 Posts
I rode a 2004 Lemond road bike for about 12 years until it wore out and I just replaced it with a new Fuji. My new bike has 31.8 mm handlebars that are flattened on the top and I noticed that I have had significantly less hand pain with the new bars. When I reconditioned my old bike and tried riding it I found that the old 26 mm handlebars are much too painful. When I replaced them with a modern handlebar (and a shorter stem) I found my old bike was also quite comfortable. The modern brake / shifters are also much more ergonomic and comfortable on long rides.
oldbear63 is offline
Old 09-24-18, 11:54 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
+1 Then go for a ride with the wrench(es) to move the brake levers and no handlebar tape, just electric tape to hold the cables in place (if you have modern aero bars like the recommended Tekros). Wrenches plural becasue you will need a long 5mm allen wrench to reset the brake lever position and a small crescent wrench to grip the "L" of the allen wrench. Don't tape teh bars untl you really like where the levers are. When you do, tape them with cloth handlebar tape from the end plug to the stem. This means you get another chance to move the levers since cloth tape can be unwrapped, the leers moved and the bars rewrapped with the same tape.
This is one of the most important adjustments on the bike. Don't put permanent, good expensive tape on until you KNOW the handlebars, rotation and lever positions are right. (I just put new levers on a bike I've had while just ot get the fit better.)
Edit: I do not like the modern ergo bars. All of my bikes have old school bars and Tektro levers (or Cane Creek - basically high end Tektros) My setups look old. I ride with my seats relatively far forward and with some tilt down and I put real weight on my hands. But dialed in right, I can put very long days on my bikes with no hand issues at all, riding with unpadded gloves.
Ben
79pmooney is offline
Old 09-26-18, 10:40 AM
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
31.8mm and 26mm are the diameter where the stem clamps the handlebar, not the diameter of the handlebar where you hold it. Nearly all road drop handlebars, vintage and modern, use a 23.8mm diameter for the areas with circular cross-section everywhere except the stem clamp.
HTupolev is online now
Old 09-26-18, 09:16 PM
Brofessor
Brofessor's Avatar
Quoted: 51 Post(s)
I think he was making a comparison between older style handlebars and newer, shallower drop handlebars with a flatter transition on the hoods. Hence the 31.8mm vs. 26mm (26.4 for pre-90 Cinelli) argument. That was my take.
Old 09-27-18, 12:09 AM
oldbear63
Quoted: 15 Post(s)
Old style handlebars
My old bike has 26 mm handle bars and I only realized how thin they were when I got my new bike. I was constantly shifting hand positions and numbness was a regular part of riding. With 31.8 mm flat or aereo bars I can ride in one position for miles without numbness. The old shifters are also much less ergonomic and I now find them uncomfortable too.
Old 09-28-18, 07:56 PM
TiHabanero
Quoted: 1745 Post(s)
Liked 1,370 Times in 719 Posts
Got pictures of the bike and of you on the bike?
TiHabanero is offline
Old 11-14-18, 03:28 AM
rdrsonthstrm
rdrsonthstrm's Avatar
Bikes: Argon18 Nitrogen
So lately I've had a lot of time to draw and have been doing so daily. This used to never be a problem but I used to only draw for 2hrs a day, often less. Now I'm drawing anywhere from 3-6hrs a day and have been getting sharp, severe pain in my drawing hand because of it. I've noticed it's only when I'm doing detail work, such as painting scales or fur, not when I'm drawing basic forms or adding color. Taking breaks and doing stretches on the afflicted hand hasn't helped much. Once it starts, any form of drawing will make it worse and I'll have to quit for the day.
Anyone else deal with this? Anything I can do beyond limiting my drawing time?
And since I know someone is going to mention this, I'm already going to the doctor soon for an unrelated issue and plan to bring this up. I'm just wondering if anyone else has experienced this and found a way to treat it.
rdrsonthstrm is offline
Old 11-14-18, 08:00 AM
Dave Cutter
Originally Posted by rdrsonthstrm
……... severe pain in my drawing hand ........Once it starts, any form of drawing will make it worse and I'll have to quit for the day.
Anyone else deal with this? Anything I can do beyond limiting my drawing time?.
My wife had several carpal tunnel surgery's.... and now her daughter is having carpal tunnel surgery as well. Your doctor (and your search engine) should have more info.
Old 11-14-18, 01:39 PM
Carbonfiberboy
Have you tried these exercises?: Carpal Tunnel Syndrome Exercises
When I was having trouble, I did these several times a day and the problem went away. I also started sleeping with my hands flat and underneath my pillow. That helped, too.
Results matter
Luke147
Classic & Vintage
10
03-14-19 02:25 PM
TurboJ
Fitting Your Bike
9
08-03-13 03:31 AM
Tulok
Classic & Vintage
2
05-03-13 11:49 AM
Violet
General Cycling Discussion
4
11-06-12 10:15 AM
SurlyLaika
Commuting
23
09-19-11 09:06 AM
