App to let me pre-select roads from home?
Quoted: 1163 Post(s)
Liked 442 Times
I thought Map My Ride allowed you to look at a map, click on specific roads which become highlighted, then you click on the save button. Once your partial rout is saved, you can continue until you reach your endpoint. I’m pretty sure our cycling club leader does this and then we can view the route ahead of time.
so I downloaded Map My Ride by Underarmour. I looked at the app and it looks like Endomondo - more of a GPS fitness tracker. Did I download the wrong version 0f Map My Ride? I was under the impression that setting up custom directions for a ride would be fairly straightforward. Am I missing some custom feature of this app? Do I need to purchase the upgraded version?
Any help folks can provide here on how to properly establish routes with Map My Ride to save (for a 4 day mini-tour I am planning later this week) would be much appreciated.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
It's not Map My Ride, but by far the best routing resource I have found is https://brouter.de/brouter-web/. It's incredibly versatile, allowing different profiles through the dropdown menu in the upper left and different maps through the layers option upper right. It takes a little bit of figuring out, but you can create a route and save it as a GPX, KML, GeoJSON or Data CSV. You could download the GPX and upload it to May My Ride if you like.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Liked 442 Times
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12775 Post(s)
Liked 7,693 Times
I don't know of any apps that let you do routing on the phone, just ones that you can plan routes on the website then follow the routes on the phone app.
I know you are looking for help with map my ride but in case you are not aware of other choices, I am sharing this. We use ride with gps. to create the route and download the route to our garmins. That works great for us. You could also use google maps on your phone.
Quoted: 286 Post(s)
Liked 100 Times
The Komoot app was recommended to me by a cycling friend for what you describe, but I haven't tried it. I use RideWithGPS web site, then down load. Komoot lets you do route discovery from the app, but apparently cumbersome to manually edit the route on the app.
AND it seems he has an Android app in the Play Store
Liked 442 Times
thanks for this suggestion. It appears to work with iPad for designing the route then link to my iPhone. RideWithGPS that I also downloaded said it could not promise it would work well with the touch screen of the iPad. Weird thing was, when I played around with making a route, it did work. I will need to practice more though. I use Endomondo , not Strava and I don’t have a Garmin BTW - just my iPhone 8.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Yes, ridewithgps.com is by far the most commonly used route planner for cycling. It's free, just create a login.
To make a route in ridewithgps:
Browse to the starting location on the map. Click the starting point.
Now click farther down a road. It follows the road, and draws a red route line. The elevation chart at the bottom updates as you go.
There's Undo and Redo if you want to change to a different road.
Or just drag the red line over to the new road.
You can drag to select part of the elevation graph, and you get stats on that section of the route -- total elevation, distance, avg and max grade.
When done, click Save, and give the route a name, to store it in your Routes history.
Then you can view the route and Export a "tcx" or "gpx" route file into your GPS bike computer or phone.
Quoted: 286 Post(s)
Liked 100 Times
That does seem like a nice web-based router. Thanks for the link.
Quoted: 974 Post(s)
Liked 512 Times
Strava Route Builder
I also use the Strava Route Builder and the Strava Heat Map if I don't know the area. It uses two years of uploaded strava ride recordings to color code roads by how popular they are with riders. It usually makes a pretty good route, instead of just picking the most direct route between two points. It's also good for avoiding roads that are terrible for cycling -- if a road is way less popular than the nearby roads, I know it's not the best choice.
I reviewed it in this post.
It's free, just make a free strava login to use it.
See the Strava Heat Map. It's color coded, white hot is the most popular, shading down to dim red as least popular, blank if there's essentially no activity on a road.
As you zoom in, it recodes the colors -- rural areas have few riders, so they show dim on a zoomed out view, but zoomed in, the locally popular roads are white.
Click "Show Labels" to see the town and road names. Click the Bicycle icon to see just cycling. You can save the current view as a bookmark/favorite.
Example: the middle of Kentucky. Lots of riding in the scenic Bluegrass region around Frankfort and Lexington!
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
I use Ride with GPS to create routes.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 286 Post(s)
Liked 100 Times
i hate it when people say this, so I hesitate to do so, but you have to be doing something wrong. It follows roads and trails, even if the clicked distance between points is many miles apart. For example, I started a track at the intersection of the Mississippi River Trail and the Katy Trail west of Saint Louis, and then clicked the end of the Katy in Clinton, MO. It laid the track on the Katy Trail the entire way. It does the same thing with roads, and it uses the specifications in the drop down selections from the upper right to create the route according to speed, safety, fewest miles, etc. I've used ridewithgps. This is better.
Quoted: 974 Post(s)
Liked 512 Times
Why do you like it better? Is it the choices list for routing based on fastest or safest, etc? That sounds useful.
It seems okay for routing, but doesn't have much detail on hills. ridewithgps is very good for quickly evaluating climbs. Brouter's Open Cycle Map layer does have a minimalist hill shading, but I check the red elevation chart all the time as I'm drawing routes.
EDIT--
I found the bottom right icon for the elevation chart. It's helpful, but not as useful as the ridewithgps version -- which shows details within the selected climb, and more stats.
How do you save a route? There must be a way, but I can't find it. (I have hundreds of named routes on ridewithgps)
I see this is "version 0.7.0" so it's still considered to be experimental / beta version. I'll check back sometime and see if there's new features added.
Wondering how well these apps compare to plain old google maps. Using bike routes in gmaps I get a bicycle route instead of highways or roads when one exists. And it usually does a good job of staying out of heavy traffic areas when an alternate route exists.
The other thing is that I use Urban Biker on my phone and the map will run as the background with all the ride data overlayed (speed, cadence, time, distance..etc) so there is only one screen to look at during the ride.
Once its planned and running theres no need to stop and switch devices or touch a screen..etc.
-Sean
-Sean
Quoted: 286 Post(s)
Liked 100 Times
It didn't work the first time, but now it does, I don't know why didn't snap to roads when I tried it before. And I couldn't see how to move the map to a different area until I clicked the "search" icon. That worked. And it does snap to roads consistently now. Can you switch to drawing straight lines? I need that occasionally on ridewithgps where there's just a short sidewalk connection between two roads.
Forgot to answer the final question about whether it's Beta. No idea, but since it works that really doesn't matter to me.
EDIT--
EDIT--
You can also modify any of the existing one by using the pane beneath that dropdown. I also like that you can use different source maps under the "layers" icon upper right. For example, to see good topo elevation I use OpenTopoMap and then select the Cylcing (Waymarked Trails) box, which gives a very good sense of elevation and overlays everything with cycling trails.
Not sure what rwgps uses for a source map, but I like the "open" maps, as I've found the crowd sourcing information tends to be helpful for routing.
I don't see that you can "save" maps online. That doesn't matter to me, as I just create tracks and upload them to my Garmin Etrex 20x. You could also just keep the downloaded gpx files on your pc and use a gpx viewer to open them when you need to view them. Not sure how that would really differ from or be less convenient than saving maps on rwgps.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Really folks. ridewithgps.com is the standard now. Works like a charm. Great selection of maps. I even use it for hiking. They also have a phone app so you can take it with you on your phone and watch progress and get turn-by-turn directions. Rather than use a phone for that, I upload to my Garmin Edge 800. I mapped our two week tour of the Czech Republic using it before we even left, 440 miles and over 600 turns. To check things out more closely, I snooped along the route for food, restaurants, etc. with Google Earth. Pretty amazing. I have over 200 local routes on it for planning group rides, etc. On tour if you carry a tablet, you can plan as you go, uploading the routes to your Garmin or phone.
Results matter
Results matter
Quoted: 4806 Post(s)
Liked 3,929 Times
I traced my regular ride using the BRoute of the second or third post. Looks like I've been under-estimating my distances and elevations by quite a bit (for the past 45 years - could be some big numbers!) I've been using 70.9 miles and 700 feet climbed for the rideout to and around Hagg Lake. BRoute says 79.1 miles and 2425 feet. I always knew my elevation numbers represented basically just the big climbs. I never cared about the minor upgrades and small bumps. Good to see my Thomas Guide estimates of distance are quite low. So my celebration of rolling over both odometers oon the same day two years ago, while done late, still was real. (Odometers: fixed and with a freewheel mechanism.)
Ben
Ben
In Real Life
Bikes: Lots
Liked 596 Times
Ride with GPS is better than Google Maps.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 974 Post(s)
Liked 512 Times
Google Bicycling routing
Google Maps with the Bicycling setting picks a direct route, which often is the worst option for cycling. I only use it for a quick estimate of distance between two points.
This Bicycling map is very useful for locating bike trails -- they show in green -- zoom way in, and the name of the trail is repeated down the green line.
The route it made doesn't show any hills or other info, either. It's not very useful.
Here's a test of Google, BRouter, and Strava Route Builder.
For a test, I picked the Cincinnati Ohio riverfront to Williamsburg Ohio, since there's some busy main roads on the way that should be avoided. I just clicked the starting and ending points and let the app pick the route. (Of course, any of these allow the route to be dragged over to different roads.)
Google Bicycling Map
33.5 miles
Not the best route. It's okay for the first half, then it routes on US50 to Owensville. Riders avoid that if possible, it's very busy.
It did avoid RT 32, which is a multi-lane, very busy road -- that's the shortest route, but would be miserable on a bike.
BRouter
58.9 km (36.6 miles)
This is better. It took the bike trail to Milford. But then routed to US50--not a good choice at all. The rest of the route looks good.
40.3 miles
This picks the most popular roads from uploaded Strava ride recordings.
It's hillier and longer than the other methods!
It climbs up the east side hill at mile 5 instead of going around the hill -- this climb is a more interesting route.
Takes the bike path to Milford, then follows "the usual" roads that most cyclists take to go SE from there.
Finally, it routes on quiet roads to East Fork Park -- a hillier route, but quiet and scenic.
This strava route is way different than the other routes. Many of these roads wouldn't be picked by a computer without knowing their popularity.
Strava Route Builder will often have a lot of turns -- which would be annoying to ride with just a cue sheet, but no problem with a GPS device.
Strava Route Builder -- minimize hills option
40.0 miles
This "minimize hills" route skips the climb at mile 5, and skips the bike trail, following the river road instead.
A reasonable route. I'd ride the standard route above, unless I wanted to get there faster and avoid climbing.
The Strava Heat Map that the routing is based on. This area map link.
White hot is the most popular, dim red the least popular.
ridewithgps
I never make a ridewithgps route by just clicking the end points. It only finds the most direct route that avoids limited access highways.
Instead, I'm zooming in, checking the route as I go, and often trying alternatives as I plot the route.
Here's the route it picked -- essentially the same as Google Map's route.
33.5 miles
BRouter
40.3 miles
40.0 miles
ridewithgps
Quoted: 286 Post(s)
Liked 100 Times
33.5 miles
BRouter
40.3 miles
40.0 miles
ridewithgps
33.5 miles
BRouter
40.3 miles
40.0 miles
ridewithgps
Not an app, but a website https://cycle.travel/map started in the UK and is expanding around the world.
It uses OSM maps, and is very simple to use. You can save your routes online, download them in a variety of formats, use Google streetview (where appropriate) to see specific points and it will show accommodation of different types if required.
It's very useful.
It's very useful.
Quoted: 286 Post(s)
Liked 100 Times
I like it
It's very useful.
It's very useful.
