Road Test/Bike Review (1984) Best Buys for Triathletes
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 436 Post(s)
Liked 3,479 Times
There were no "triathlete bikes" in 1984, but there were bicycle manufacturers eager to tap into the growing market of a nascent sport.
The article was prescient of the key change to come -- introduction of the Quintana Roo Superform in 1989, and the subsequent acceptance of steep seat tube angle (76 degrees and greater) as the key feature of "tri-specific" frame geometry.
Enough already.
The affordable, tight, short-wheelbase racing bikes reviewed in this article are CENTURION Comp TA, PANASONIC Team, PINARELLO Triathlon G.S.,
AUSTRO-DAIMLER SLE, and SCHWINN Peloton.
Enough already.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Sunshine
Quoted: 10970 Post(s)
Liked 7,498 Times
The gearing range even for entry level comp road bikes was crazy back then.
What I found interesting were the size of the frames used by "athletes" in this article. Is this what would be referred to as "French Fit" ?
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
Interesting that none of the bikes were equipped with either Shimano Dura Ace AX of 600 AX, introduced in 1982, and were touted for their aerodynamic properties which would increase overall speed and reduce time.
I suppose triathletes in the early 1980s were not concerned about achieving better finish times?
Bob
Bob
Quoted: 4560 Post(s)
Liked 2,802 Times
Regarding aero bike design, I suspect that then, as now, cyclists knew their own bodies were the main aerodynamic drag. Almost nothing on a road bike creates significant enough drag to worry about, compared with the cyclist's own body position and snug kit.
I noticed the Centurion Ironman bikes tended to incorporate Shimano and Suntour groups that were sorta-aero for that era. The Suntour GPX group has flowing lines in the crank spider, brakes, the usual aero brake hoods, even the downtube shifters are a bit more streamlined than some from that era.
Some users report the Dura Ace AX setup was a PITA, including cable routing for the rear derailleur. I'm sure plenty of wind tunnel tests have been done to check the gains made by internal cable routing, etc., but it's probably still all marginal compared with aero bars of any kind, getting low and a skinsuit or snug kit and reasonably aero helmet.
And some aero components of the era before single purpose TT bikes seemed like a bit of a stretch, such as aero seat posts. Hard to imagine how that could make enough difference to justify the cost on bikes before aero bars were in common use. As uncomfortable as the early Scott bars were, that single addition probably made more practical difference than the shape of any component.
