From local elite runner to cyclist. How long until the pain goes away?
I'm an elite runner on the local level (16:40 5K, 1:17 half marathon, 2:44 marathon) who just started cycling as cross training and use it for recovery type workouts. But since I'm kind of competitive I'd like to get better on the bike. My problem is that my legs are constantly sore/hurting on the bike while my HR is in practically recovery zone on my rides (my Vo2max is 79 ml/kg/min) . Are riding muscles that much different from running muscles? How long until I build up the muscle base to be decent on the bike? I've only started riding two months ago and so far rode about 1,400 miles. My average pace is pretty slow, I think and I'd like to get it up higher. Are there any other fast runners who started cycling? How long did it take you to match your running performance with equal biking performance?
Reasonably Slow...
If you are in pain, you're doing something wrong.
What hurts? Is the pain from running, or is the cycling causing it?
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
Read up on cadence. Rough numbers, cadence below 85 relies more on leg strength, over 85 taxes more aerobic capability.
And yes they are different muscles.
It's mostly the quads and the anterior tibial muscles. Sometimes the hams burn too. It's a different kind of pain than while running, it's more like burning muscles. The other thing is that my friends I ride with at lunch would have way more explosive power and drop me on hills but just after the crest they would be licking their lactate wounds as I would just zip by them. It seems like they have way more maximum power output but they just can't sustain 200 Watts for any particular length of time while for me that doesn't seem to be a problem, I can ride 19 mph for 60 miles solo.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
The only way I got what I felt was a good effort for years after picking up cycling was a high power, low cadence effort. I wasn't quite as fast as you but close, and even now I can't get my HR up nearly as much cycling unless its a very steep and long climb.
I also used to get sore but not as much as you do. But I could tell cycling uses different muscles because my legs felt rubbery after getting off the bike.
So my advice is get the distance and time on the bike; don't always push it; and enjoy cycling. If you do it for recovery, try high cadence easy gear combos.
just ride
Bikes: '15 Scott Speedster 20
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
when you quit running, the pain will go away.
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
cycling. if you're doing it right, the pain never stops. suffering. that's what it's about. it's not about the bike.
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
Yup, different muscles. You'll need to give your muscular-skeletal system a chance to catchup with your aerobic capacity. 1400miles in 2months is a boatload of miles to be starting with, so it's no wonder that you're sore. You need to build some good riding habits (posture, efficiency, form, handling skills, group riding experience, nutrition etc) prior to really focusing on being competitive IMO. That's not meant as discouraging you, rather that these skills are all equally important as strength and endurance.
BF, in a nutshell
BF, in a nutshell
Quoted: 1186 Post(s)
Liked 289 Times
edit: Lots of ideas for intervals here:https://www.bikeforums.net/showthread...ut-recipe-book
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
You've got an aerobic engine that allows you to push your legs beyond what they're trained for cycling.
It's kinda funny because cyclists that try to run really have this problem.
You could get lost and die.
You could hit a tree and die.
Despite all my rage, I am
Bikes: LeMond Zurich, Colnago C-50
Did you get fitted to the bike? My guess is your seat is too low. Your leg should be almost totally straight when your leg is in the down position without the knee being locked.
absent
Though I never really liked running, I've been reasonably fast. 35'/10km. I've found the two sports complement each other in some ways, not in others. Mental toughness, aerobic: yes. Legs: not so much. When well trained for cycling, I've been 10 -15 lbs heavier than my ideal running weight.
Weights in the off-season, and lots of miles is my advice. Do some intervals as Greg suggested. The speed will come.
Last edited by Ferrous Bueller; 03-22-13 at 10:33 AM. Reason: Had the symbol for seconds instead of minutes, which looked funny when I looked at it
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
200 watts is warming up
Running and cycling muscles do overlap but there are enough differences to make transition difficult. Just ask tri guys.
You have an aerobic base but competitive cycling is all about suffering in the anaerobic and anaerobic recovery.
Make sure your fit is good and then log some real miles. Hint, aim for 1000 mikes a month but don't just attempt the volume without working up to it. Have some respect for the sport. You're a runner. Now you need to learn to be a cyclist.
Good luck and enjoy.
Yeah, that's not going to happen :-).
Have you tried any intervals on the bike? Start with 20min intervals. With your VO2Max you should be able, eventually, to ride at 5+W/kg for an hour.
Yeah, I guess I just have to build up the riding muscles more. I never realized that the two are so drastically different. I'm definitely taken back a bit by how hard riding actually is on me.
Bikes: Arabesque
For me there is more pain in running. At a given time, your entire weight is supported by just one leg/knee, more impact and stress on the joints. Running is like time-trialing. There is no coasting, no drafting.
Too much too soon equals injury. With correct posture, spin easy gears, the big gears will follow later without pain. Thru time the muscles will adapt and I bet you will become a competitive rider. Enjoy riding first.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Same engine...completely different ball game.
OP...I suggest it maybe partly the position on the bike. You maybe recruiting the wrong muscles based upon your position.
Seat height and setback are kind of a big deal...and adequate cockpit reach. Position is big...with properly rotated pelvis.
Your cadence sounds OK. You maybe pushing too much gear though for your level of leg development (for cycling)..maybe not
enough rest/base miles at low effort.
You will likely be real fast with your background if you stick with it because you have the engine.
Friend who "crossed over" from college running career tried a 30-minute beginners' crit (cat 5) during his first year: he was shelled in the first half and got lapped a couple times (humbling experience--but we've all been there!). It took well over a year to start realizing cycling success/equivalent, and that only in fast-paced training rides, not sure about races 'cause he stopped doing them: he got into triathlons.
Yes, as someone else said, the musculature & physiology required are different, and it takes time to adapt. Once they do, your CV system will give you great benefits.
A friend who also used to be a fairly elite level runner (he also did many ultra marathons) has transitioned into a fairly strong cyclist. When I asked him how long it took...he said it was almost three years before his legs really came around and he felt strong on the bike.
Quoted: 6556 Post(s)
Liked 58 Times
