Removing Rust
Quoted: 201 Post(s)
Liked 66 Times
Removing Rust
I just found a bit of rust on my front derailleur cage. Ultegra 9 speed Triple. Since I have everything shifting so good, I don't want to remove it and soak it. Would a bit of vinegar take it off and not attack the paint?
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Sure, that should be fine. Clean it off afterward and spray it with a water displacer.
Quoted: 857 Post(s)
Liked 1,090 Times
Any vinegar that stays on long enough to remove rust could harm some paints too. Vinegar should also be rinsed off pretty well as it can eat through chrome if left on long enough. Not a great risk but if it gets into some little crevice's and left there you'll find the damage later. Just hose it down with water afterwards.
Quoted: 6315 Post(s)
Liked 4,905 Times
I'd just wipe it off as best you can and maybe use a drop of some sort of oil on your rag to help discourage further rust. I wouldn't want to use an acid on it if you aren't going to take it off. You might get some on the chain and other parts that will have their finish messed up and then they'll start getting surface rust too.
But maybe not. It's sort of a toss up.
Old fart
Quoted: 3615 Post(s)
Liked 3,446 Times
Naval jelly will remove the rust. Clean it off completely afterward and put some oil or grease on the affected area to inhibit the rust returning.
Coca Cola.
