This is why titanium sucks.
Old 05-25-11, 06:03 PM
ilovecycling
Bikes: LOOK 595 & Cannondale CAAD9
So earlier today my 3T bars and stem showed up at my front door. I just tried installing them a few minutes ago to get an idea of how the new bike will look when I'm done with the build. While tightening the top bolt on the steerer clamp, I heard a loud "DING" and the bolt was easy to turn all of a sudden. First thing I'm thinking at this point is OMFG did I just crush my new bike's fork steerer? Turns out the titanium bolt in the clamp snapped in half. I immediately removed the tension from the bottom bolt and now I'm sitting here scratching my head. Titanium pedal spindles? No thanks.
I used a Ritchey Carbon 5 Nm torque tool too. Funny thing is, the bolt snapped right as I was expecting the Ritchey tool to click over.
At least it looks good.
ilovecycling is offline
Old 05-25-11, 06:07 PM
Palomar01
SpeedFreak
Bikes: Motobecane Le Champ Ti
Of course. Everyone knows steel, aluminum, and CF parts do not break, ever, especially when they are made into bolts.
Palomar01 is offline
Old 05-25-11, 06:13 PM
giantdefy
The "Mechanic"
giantdefy's Avatar
Bikes: 2013 Tarmac SL4 Pro; 2011 Lynskey Cooper, 2015 BH Quartz Disc, 2014 Yeti SB75
If only they made carbon fiber bolts, they would be far superior!
Seriously though, did you tighten the two bolts evenly or did you just torque down one bolt first then go to the next?
giantdefy is offline
AltheCyclist
AltheCyclist's Avatar
Bikes: Many
Quoted: 7 Post(s)
Bolt was new, I assume? Also, were you load-balancing - i.e. was the bottom bolt pretty tight when you attempted to screw the top bolt?
AltheCyclist is offline
Andy Somnifac
Andy Somnifac's Avatar
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times in 86 Posts
Definitely never broken something like a wheel stud on a car, which is far more burly and probably made of steel. Never twisted one right off while removing a lug nut. Really. Ti is the only metal that can break. Really.
Andy Somnifac is offline
Old 05-25-11, 06:20 PM
ilovecycling
No, I am not dumb enough to do this. I did tighten the bolts evenly. I also tightened the 4 bar clamp bolts evenly and in a cross pattern. I've been working on bikes since I was a kid, so there was no mistake made here.
Yes, the stem and bolts were brand new and in the package.
I didn't mean to upset the materials geeks. I'm aware that anything can break, regardless of material. But at only 5 Nm? I didn't trust titanium for bicycles before, and I certainly don't now.
Old 05-25-11, 06:23 PM
Bob Dopolina
Mr. Dopolina
Bob Dopolina's Avatar
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times in 41 Posts
I get the grumpy post after just having sheared a Ti bolt. As others pointed out it happens.
The real issue is whether you can get the remaining bit of bolt out of the threaded section of the stem or not. Good luck.
BTW, from what I can see it should be a sharp looking build.
BDop Cycling Company Ltd.: bdopcycling.com, facebook, instagram
Bob Dopolina is offline
Dean V
Quoted: 1067 Post(s)
Liked 259 Times in 153 Posts
It wouldn't matter if he was or not. Tension on one bolt will not add on to the other bolt in that situation.
Also titanium is weaker than a high grade steel so it will be more likely to break.
Dean V is offline
Old 05-25-11, 06:27 PM
AltheCyclist
Bikes: Many
Quoted: 7 Post(s)
I was thinking the "crookedness" of the bolt at (slightly) lopsided angle contributed to failure.
Old 05-25-11, 06:34 PM
ilovecycling
To be honest, I'm not grumpy at all. I didn't mean to come off that way, but I suppose it's easy to assume one would be grumpy when a new part fails. Stuff happens and I'm fully aware of that. I just wanted to share with everyone, that's all. Maybe this will help someone out if they are considering a stem with titanium bolts but really don't need them. I know I didn't need them. I only bought the Team version of this stem because it matched the bike and handlebars.
Old 05-25-11, 06:40 PM
mikeetow
mikeetow's Avatar
did the bolt screw in easy? get cross threaded? seems unlikely to just snap with little force of that tool... seeing it broke off further down the bolt looks like it got jammed up
mikeetow is offline
Old 05-25-11, 06:45 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
This is why you don't spend an extra $40 for a red stripe of paint and 6 titanium bolts.
Elvo is offline
Old 05-25-11, 06:50 PM
RoadHooligan
Are you going to cut that steerer tube or did you take all the spacers out before the picture? That could be deadly sticking up like that. Also, did you put the blue thread locker on the bolt or was it on there when you bought it?
RoadHooligan is offline
Old 05-25-11, 06:51 PM
learnmedia
Go, Dog. Go!
learnmedia's Avatar
Bikes: '09 Fuji Team; '11 PedalForce QS3
No sh*t. On the positive side, that sheared Ti bolt is a small annoyance relative to what is gonna be a helluva build that should be an endless joy to ride.
learnmedia is offline
Old 05-25-11, 06:54 PM
I_like_cereal
Fail Boat crewman
Bikes: Reynolds 853 Jamis Quest 1990s
I have never know a steel screw or bolt to break. Strip yes, shear no. Especially at 5nm. Sounds like the screw was not heat treated properly and developed a weak spot in the lattice structure. It could have also been over heated in the threading process. Its a clean break so go get a steel alternative and deal with the extra .1 grams.
I_like_cereal is offline
Old 05-25-11, 07:05 PM
canam73
Quoted: 13 Post(s)
Liked 10 Times in 6 Posts
I had the clamp screw that came with a shimano FD snap. I assume it was steel.
canam73 is offline
Old 05-25-11, 07:08 PM
mvnsnd
mvnsnd's Avatar
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times in 78 Posts
You just got a bad bolt. It happens. Get another one and don't quite give up on Ti just yet.
mvnsnd is offline
Old 05-25-11, 07:16 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
yup, gotta find some way to turn it backwards. Steel would be easier.
Doesn't look like's going to be any exposed in the slit that could be grabbed.
Maybe drill into the original end a bit, then jam an old phillips head in there to try to get it to turn back out.
Or superglue something to the end, then turn it back out.
Homebrew01 is offline
Old 05-25-11, 07:22 PM
Bob Dopolina
Mr. Dopolina
Quoted: 149 Post(s)
If you are lucky and can see the end of the sheared bolt I'd dremmel a slot in it and use a screwrdier to turn it out. That may be a best case scenario.
patentcad
Peloton Shelter Dog
patentcad's Avatar
Bikes: 2017 Scott Foil, 2016 Scott Addict SL, 2018 Santa Cruz Blur CC MTB
Quoted: 1142 Post(s)
Liked 28 Times in 22 Posts
All this bike crap sucks.
https://www.cotsiscad.com
patentcad is offline
Old 05-25-11, 07:44 PM
Gluteus
Maximus
Bummer.
I wouldn't be surprised if you end up having to replace the stem.
Gluteus is offline
Old 05-25-11, 07:48 PM
rangerdavid
rangerdavid's Avatar
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
I've had two of em snap on my 3T stem. LBS gave me some replacements. Not titanium.
rangerdavid is offline
Old 05-25-11, 08:40 PM
JayhawKen
Knocking off the rust
JayhawKen's Avatar
Bikes: LeMond Tourmalet, Specialized Tarmac
It's called an EZ-out. Nice bike BTW.
JayhawKen is offline
Old 05-25-11, 08:52 PM
Silvercivic27
Silvercivic27's Avatar
Bikes: Colnago, Cervelo, Scott
Quoted: 191 Post(s)
They do make carbon fiber bolts! I've got the CrMo spindles on my Keo blades. . .
Silvercivic27 is offline
Old 05-25-11, 08:53 PM
Commodus
Liked 3 Times in 3 Posts
Originally Posted by Gluteus
Bummer.
Nah just find a cycling machinist like me. I'd have it out for you in minutes if you were close by.
Commodus is offline
