Newbie seeking advice on second wheelset
Quoted: 8 Post(s)
Liked 10 Times
Greetings! I have a Cannondale Topstone and am thinking about getting a second wheel set, primarily because the rear gravel tire is very loud on my trainer and want something with a slick I could swap on or off. I've been riding a few years, but know nothing about buying wheels. Can anybody point me in the direction of a nice affordable replacement? Thank you!
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 419 Times
If you just want something for the trainer, buy the cheapest rear wheel you can find and put an old road tire on it. If you're buying a wheelset, look for something that has capabilities your current wheelset doesn't.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Edit: But yes, Shoota's advice on what to buy if you want to get another wheel is good.
Which model Topstone do you have? I believe the carbon model uses a rear wheel with a special dish.
Quoted: 1463 Post(s)
Liked 1,487 Times
If you just want a trainer wheel, I'd go ultra-cheap, but if you use this as an excuse to buy a nice second wheelset... it's fun to play around on prowheelbuilder.com to get an idea of what is out there and what things cost. You might want to consider a 650b set to have something different than the stock wheels?
As the poster above mentioned, the carbon Toptstone model has an asymmetric frame that requires a special rear wheel dish, so off-the shelf wheelsets won't fit properly. The good news is that most LBS's can re-dish a wheel for you for minimal cost.
Liked 1,487 Times
Another option here might be to just upgrade to a direct-drive trainer instead of a second wheel / wheelset.
Apparently I like to find reasons to buy new stuff.
