1972 Motobecane Grand Record - before and after
as picked up-
rusty
had to rattle can this one.. paint was beyond bad
still needs some work- cable clips, etc.. remove stuck reflector. etc
Took it out for its maiden voyage ( after broke the original chain 5 min in..)and she rides nicely.. chain skating a bit on some cogs... b screw adjustment?
Likes For vegasbike:
feros ferio
Quoted: 1397 Post(s)
Liked 1,336 Times
Looks great to me. I like the look of that Nervar crank. Does it have a 128mm BCD like my Nervar Star, which would make that inner ring probably about a 40T?
Likes For John E:
Quoted: 5891 Post(s)
Liked 3,475 Times
That looks like a 50.4 bcd Nervar crank. For the chain skipping, a twist tooth freewheel will likely help. So will dumping that campy RD for something decent like a suntour. That's what I did to my '73 Motobecane Grand Record I'm also running a 50.4 bcd Nervar crank (model 631 I think?) with 50/36 rings and a 14-28 5 speed freewheel. You can fit some righteously fat tires on these bikes.
In order to make n-record RD to work on 28T, you will need to move your wheel backward to the end of drop out. Your setup is too forward. This is the setup of my paramount
Likes For ryanl092:
yes i did paint it. im content with it.
thx for the tip on the rear wheel dropout being too forward. Ill try it
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 765 Post(s)
Liked 1,603 Times
Get a paint pen & line those lugs- show off the lovely Nervex shorelines!
Likes For ehcoplex:
Quoted: 3464 Post(s)
Liked 2,834 Times
A skating chain can be a fresh chain and an “experienced” freewheel.
the freewheel you have also has a v channel at the top of the teeth, Regina did that and so did Atom with the Regina compatible freewheels.
meh performers.
‘Shimano probably has the best tooth profile. (Do not like admitting that)
lower probability would be a slightly bent derailleur tang.
loose derailleur body.
meh performers.
Likes For repechage:
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
Beautiful motobecane, but that's redundant. All motos are beautiful!
Likes For 52telecaster:
