Did my fit really change that much...
or was it wrong to begin with?
Been riding a size 56 2007 Specialized Tricross comp for the last 10 years (bought used). Came with a 110mm stem that I replaced a few years ago with a lower angle 110mm stem. Fit always seemed ok to me.
Last year I really started having issues with saddle comfort and went through a few, then a few more this year. This year in particular I was experiencing a lot of hamstring pain and soreness especially in my left leg.
So a few days ago I swapped my 110mm stem for an 80mm stem that I had lying around. Not sure why, but it seemed like the reach had become too much for me...and turns out the 80mm stem seems to have helped all around. I feel more comfortable on the bike, the hamstring pain seems to have diminished, and the saddle I was riding felt a little more comfortable (although I did swap it for another new one yesterday). In terms of position I feel good on the bike - pretty close to KOPS from a casual check. I feel maybe a bit scrunched so might go to a 90mm stem after a few more tweaks.
I'm closing in on 53 years in a few months. Did my fit change? Was it wrong to begin with? Or maybe both? My fitness level is the same as the last few years, no weight gain or anything like that.
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Can't see how a shorter stem would affect the hamstrings, but a different saddle position probably would.
Formulas never seemed to work for me. I stumbled onto my best fit proportions quite by accident with my old 56cm Basso. The ergonomics were so good I copied all the dimensions to my other bikes, even the 54cm frames. Course, I failed to write it all down. Good thing I kept a bike or two!
Regarding physical changes, there are a couple of threads discussing the need for smaller frames as our bodies change. I think most of us need less saddle to bar drop as we get older. Enjoy your age while you can. I just turned 60, and it's beginning to show.
Quoted: 936 Post(s)
Liked 1,331 Times
That seems backwards to me. Less saddle to bar drop requires a larger frame, not smaller.
climber has-been
Quoted: 3546 Post(s)
Liked 3,698 Times
Just a shot in the dark here, but it could be caused by a hip flexibility issue.
If your hip joints are less flexible, you aren't able to stretch out your back to reach the longer stem position, so you compensate by bending (rounding) your back. That in turn could put more strain on your lower back and hamstrings.
Can you touch your toes while standing with straight knees?
Likes For terrymorse:
I became a convert to professional fitting when I bought a new road bike a few years ago at age 60 that came with a discounted Retul fitting. The fitter moved my cleats all the way back on my shoes and raised my seat about .5 inches, from settings I'd arrived at myself by tinkering over the years. Made huge differences, I was surprised.
He also echoed terrymorse's comments - said my hip flexors were very tight, that can increase with age or just be a natural issue. I've been doing hip flexor stretches since then. Now on longer, hillier rides I don't even feel it the next day. Not sure which contributed more, the fit changes or the stretching - I tend the credit the fit changes since I saw immediate benefit, but I think both were positive changes.
jpescatore - interesting about mving the cleats because I recently did that on my own, mostly due to a hotspot on my left foot.
I'll work on flexibility and see what happens, then possibly go for a fitting. The closest shop that is known for fittings is a couple hours from me though.
Terrymorse is on the right track. You are tight, my friend. Everyday stretching is needed. I know from experience it will solve some issues and prevent others.
Likes For TiHabanero:
Quoted: 4560 Post(s)
Liked 2,804 Times
My bike fit changes with my age and conditioning. After two months in physical therapy this spring/early summer working on my injured shoulder and neck, I retweaked a fit that used to be comfortable to better suit my new me.
Regarding reach, to better suit my neck injuries (permanent C1 and C2 damage), I've had to go from a 125mm stem to 80 or 90mm. Much better. I'm more upright, comfortable and better balanced, yet can comfortably get aero by using the hoods and keeping my forearms more parallel with the ground, or using the drops. Couldn't do that comfortably with the longer stem, or before physical therapy.
And I'll need to do the same soon with my other road bike -- I'm way too stretched out on the 140mm stem, even though it's a slightly smaller frame (56cm vs 58cm on the other bike).
And I can feel other minor differences between the bikes. Different saddles (Selle Italia solid saddle on one, Bontrager with pressure relief cutout on the other), shoes (Scott and Fizik), pedals/cleats (Look Delta on one, Shimano SPD-SL on the other). It's just enough that one bike is comfortable for 50-60 mile rides, while the other begins to wear on me after about 30 miles.
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
I recently rediscovered the Road forum’s fit thread from 2011, and that has me questioning my setup. I’m willing to tinker a little, especially if it will help with neck and shoulder issues I’ve experienced now that I’m older.
'm 66 and HAVE noticed that my preferred stem length has shortened over time from 110-120mm down to 90-100mm depending on the bike I've chosen. It must be my backs just not as limber as it once was!!
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
fit
I had triceps pain on my last 2 rides. Sunday, it was like hitting a wall, one minute fine, 2-3 minutes of feeling a little fatigue, next 10 minutes get off the bike and walk type pain. Except that I don't. The pain became so intense I would have stopped, except I was so close to home (1.5 mi to go) and just wanted it over with in the 90° + sun. The "only" thing that was different, I spent probably 20% of the 20 mile ride in the drops. I ride almost exclusively on my hoods, even when trying to ride fast (forearms parallel to ground).
Reading the posts above, touching my toes, seems the same as the last time, (probably a year ago) not palm flat, but ok.
The biggest surprise to me was that changing position, did not solve the problem. Sitting up straight no hands, yes. Riding one handed with the other at my side or behind my back, yes. Out of the saddle dancing on the pedals, on a little hill, ok. But any weight at all, even upright on the tops of the bars, excruciating. Very strange feeling to have pushed a single (right and left equally) muscle into such distress with such rapid onset, and with almost no sense of recovery after changing positions. (My forearms started to hurt a lot also as tried to compensate.)
Obviously my body was not ready to handle the change in position, but I never imagined the difference would be so pronounced, or sudden. I' m going to go out now before it gets toohot amd go for a 10 mile ride to see how it all feels. This ain't for sissies, but beats the alternative.
climber has-been
Liked 3,698 Times
I've had triceps pain on and off for years. According to my chiropractor ride buddy, pain in your triceps comes from your neck. She gave me neck exercises to do, and they help a lot.
I do the forward tilt exercise when waiting for a traffic light to change, and the rest of them when off the bike.
WebMD: How to Stretch Your Neck
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I think riding in the drops (which I really don't do since I started riding again) may have pushed my already extended position, which I am accustomed to, and like, into one that may put too much weight on my hands.
Veteran, Pacifist
Quoted: 3920 Post(s)
Liked 4,895 Times
I've lowered saddles a bit in the last couple of years. Maybe they were a bit too high to begin with - because I have not shrunk in overall height. Some minor knee pain for a short time made me consider the downward adjustment and I've stayed with the lower height.
just another gosling
Quoted: 3917 Post(s)
Liked 1,971 Times
I do push-ups for triceps pain, one set to exhaustion about every 3rd day. Works well.
Results matter
Results matter
Liked 1,971 Times
The whole idea here is that one is allowed to get older, but not to age. We can really, really slow aging through exercise, stretching, and diet. When something starts to hurt, it's not because you've become older, it's that in becoming older you've lost some of the innate resilience you have when younger. You have to replace that with conscious choices.
My motto is that age doesn't make you change your fit, weakness does. Don't change fit, get fit. But it's your choice.
Your reach is correct when, hands on hoods, forearms horizontal, your upper arms form a right angle with your straight torso. That angle mostly remains the same throughout the range of elbow bend, but is most easily seen when all the way down.
Results matter
Results matter
Liked 1,971 Times
Thx, I didn't mention, (I forgot), at the very end, neck hurt like heck too. Will check into exercises... ugh.
For neck pain, see: https://www.bikeforums.net/road-cycl...discovery.html
Results matter
Results matter
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
I recently found out the hospital I use and prefer, and associated clinics, offer a Bike Fit as part of a PT program. I have asked my doc for a referral. Now I'm left with the question of, which bike do I take for the fitting? I've never had a true fitting before. But as prone to injury as I seem to be lately, it makes sense to do now. Espcially if it is only the cost of a co-pay... I try my best to get all my bikes to match crank axle to seat rail, seat to handlebar reach and such. Best as I can...
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Quoted: 1778 Post(s)
Liked 1,314 Times
I haven't read all the posts so I don't know if this has been answered but have you lost height and, if so, is it upper body? When I started riding it was around 1982. I was 36 at the time and I was 5'10 1/2" with a 32.5" inseam. I rode a 54 frame with a 100mm stem and it fit me perfectly. Since then, thanks to aging and a fusion of C1 & C2 thanks to a cycling accident, I have lost almost 3" in height although my inseam is unchanged. I currently have two road bikes. A 55 Guru steel w/100mm stem and a 52 CAAD 12 that actually measures out to a 54 frame with a 100 mm stem. Totally comfortable on both of them. Why nothing has changed I have no idea. Kind of curious if others have had fit change as a result of aging bodies.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Far too many variables at play for any of us to really give an informed opinion. I think you should consider paying for a bike fit or at a minimum have someone with bike fitting experience observe how you fit on your bike and offer suggestions.
Turns out that with swapping saddles (tried and ISM Road saddle and didnt' like it) I had moved some things around and didn't record my fit prior to the swap. I have it dialed in very nicely now, with no plans to move or change anything!
Likes For billyymc:
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Now, make sure you write everything down.
Likes For horatio:
