Best Cleaning Product(s)
Hello Forum Members:
I intend to clean a bunch of oil, dirt and crud out of my Sachs Aris Freewheel on a Mountain Bike that I own. Will a new bottle of mineral spirits do the job or do I need to go with a more expensive product like WD-40 Bike Degreaser? Please help!
Quoted: 6199 Post(s)
Liked 4,816 Times
You doing it on the bike or off the bike? If off the bike, then it's hard to beat mineral spirits. On the bike mineral spirits will work too if you have a way to get it in there and not make a mess. But typically I just used WD-40. Not the de-greaser formula. More expensive than mineral spirits, but easier on my hands as I developed a sensitivity to straight mineral spirits. Breaks me out like poison ivy. Probably from years and years of using it. If you are just cleaning the outside of the cogs, then many of the spray on degreasers for automobile engines will work well if you have somewhere for the mess to drip.
Make sure to protect your brake pads and brake surfaces whether disc or rim. Also, when I was using de-greaser once and let it drip all over my rims, I think some went into the spoke holes and started working on the adhesive of my rim tape. So you might watch for stuff running down the spokes.
Best is subjective for most anything though. Depends entirely on the individual.
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
You can leave it on the bike. Take the chain off. 1st, use small brass brush to loosen crud. Maybe some degreaser. 2nd, use nylon brush & degreaser to clean more. 3rd, rinse w/water. 4th, dry/final clean using rags/Q tips.
I only use degreaser to clean my bike- wd 40 is for rusty/corroded fasteners.
YMMV- everybody has their own method!
Likes For Dolphin North:
Sr Member on Sr bikes
Recently I discovered that Dawn Platinum Powerwash dishwashing spray is a pretty good degreaser. I’ve used it to clean a couple of my bikes/gear set recently. You can get it at the grocery store. The various citrus degreaser are good too. I use the Home Depot brand. — Dan
Likes For _ForceD_:
Dish soap, WD-40, mineral spirits. Use whatever is the cheapest you can find. I use some no name brand penetrating lubricant (same as WD-40) from the hardware store.
senior member
Quoted: 506 Post(s)
Liked 639 Times
Not specifically true. The solvent in WD-40 does dissolve whatever is there, but if you let WD-40 evaporate you will have a lightweight oil left over. It's not a great lube but it is a lube.
Likes For KerryIrons:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
All I use is non citrus Dawn for Dishes, mixed in hot water, a scrub brush that will fit between the gears and chain rollers, and get at it, it takes the crud off just as good as all the solvents will but Dawn is a lot cheaper. Scrub the gears, rinse with water, either air blow it dry, or wipe the gears and chain down with a rag, and let it set overnight to evaporate any remaining water, then relube. Dawn citrus version contains acids, not good for chains and gears. You can also use Dawn for cleaning the bike, in fact when I do a major cleaning of the bike I do the chain and gears at the same time.
Likes For rekmeyata:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
WD-40 stands for Water Displacement, 40th formula. WD-40 stands for Water Displacement, 40th formula. That's the name straight out of the lab book used by the chemist who developed the product. The first company to use WD-40 Multi-Use Product commercially was Convair, an aerospace contractor, to protect the outer skin of the Atlas Missile from rust and corrosion..
Quoted: 5224 Post(s)
Liked 3,585 Times
drinking straw brush, for between chain links & inside tight derailer spaces. more rigid than pipe cleaners
Likes For rumrunn6:
Liked 253 Times
Sorry, but you did not research the WD40 site far enough, had you done that you would found this: https://www.wd40.com/myths-legends-fun-facts/
Where it states: Myth: WD-40 Multi-Use Product is not really a lubricant.
Fact: While the “W-D” in WD-40 stands for Water Displacement, WD-40 Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Quoted: 970 Post(s)
Liked 1,632 Times
OK... Just gotta put this in... Don't forget Diesel Fuel is an excellent cleaner...
Diesel Fuel = 5 USD/usgal
Charcoal Lighter Fluid = 12 USD/usgal
Mineral Spirits = 16 USD/usgal
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
But I missed that, so what part of what I said, did you have issue with??
Nothing I said was incorrect.
Liked 253 Times
That wd40 is a water displacement and not a lube, if you were not trying to say that then why did you copy that statement from WD40 if you were not arguing against it being a lube? Was it a simple case of failure to communicate?
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
What you were alluding to when you quoted this: From WD-40's site
Back off and pick your fights elsewhere.
Likes For Schweinhund:
Quoted: 454 Post(s)
Liked 104 Times
The OP asked about WD-40 Bike Degreaser not WD-40, WD-40 is a brand/whole line of products today, yet people, as most above still seem to think that it is a single (the original) product. Foaming Bike Chain Degreaser | WD-40 Bike Degreaser | WD-40 (wd40.com)
For bike cleaning products, it can often be a case of you pay for what you get, and the more expensive will do a better job, but there is no reason you can't look at automotive versions which are often cheaper and do exactly the same job (although some may be more concentrated than the bike version, so test/be aware).
For using things like diesel, you may want to look at the disposal implications in your area, and the cost vs just buying a safer/more environmentally friendly product
Liked 253 Times
I wasn't picking a fight, settle down, life isn't about fighting, Just because I'm stating facts doesn't mean I'm fighting, grow up, and like you I will SAY what I mean!
For the chain, I take it off and throw it in the ultrasonic cleaner with acetone. Simple green works good too, but I find it takes the luster off some chains and takes a few washes to get fully clean. Acetone works faster.
Everything else, I like the citrus cleaners because they're cheaper, smell good, and doesn't dry my hands out. I take the back wheel off and spray the cassette and use a stiff paint brush to get the muck off it. The rest of the bike, I spray it on a rag and wipe off things as needed.
I have Muc-Off brush kit for cleaning. It does not have the cleaning / degreaser / lubricant stuff. I have Goof Off and Mineral Spirits - will start there and get the freewheel clean (i.e., put newspaper between freewheel and spokes thanks for your message
I like your Mathematics is that Calculus ? I have Muc-Off brush kit for cleaning. It does not have the cleaning / degreaser / lubricant stuff. I have Mineral Spirits and Goof Off - will start there and get the freewheel clean (i.e., put newspaper between freewheel and spokes thanks for your message
Most ultrasonic cleaners (especially homeowner-types) are not explosion-proof.
