Help with frame pump?
Old 01-08-23, 05:09 AM
Milepost105
Bikes: Vintage to Electric
Quoted: 21 Post(s)
Liked 52 Times in 17 Posts
I keep a little Peugeot folding bike in my office for short errands downtown. The frame pump doesn’t pump air, is missing the piston seal. Any ideas on finding suitable parts to get it going? Thanks
Folding bike
Pump
Pump
Milepost105 is offline
Old 01-08-23, 06:47 AM
JulesCW
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times in 319 Posts
Your best bet might be to fabricate one from an old belt or similar piece of leather. Cut to size, punch hole in center to mount, apply a liberal amount of grease, and you just might be in business! If you do not have suitable old belt lying around one can be procured for a buck or two at your local thrift store.
JulesCW is offline
Likes For JulesCW:
Old 01-08-23, 07:26 AM
juvela
juvela's Avatar
Quoted: 3814 Post(s)
Liked 3,345 Times in 2,182 Posts
it "looks" like the seal may be a snap fit which goes over the white nylon barb crimped into the end of the shaft
in such cases the seal is plastic item the outside and inside diameters of which are most critical
at first glance thought your pump might be one of the Poutrait-Morin marques such as AFA or Ventolux but it appears to be from a maker unfamiliar to me
this Poutrait-Morin catalogue of 1974 illustrates the type of seal am speaking of
Poutrait-Morin catalog (02-1974)
on this page is shown a seal of the type mentioned
it is described as "elastomere spare washer" and is item Nr. 22PE
am unfamiliar with the OKE brand of frame pumps; you might be able to search online to see if you can source some information regarding them
one source sometimes helpful for small parts from French makers is Mel Pinto Imports
juvela is offline
Likes For juvela:
Old 01-08-23, 08:30 AM
1989Pre
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times in 490 Posts
I have found "leather bicycle pump washer" online in N.O.S. You can measure-out your plastic piece and see if you can get one in that diameter.
1989Pre is offline
Old 01-08-23, 09:02 AM
SJX426
SJX426's Avatar
Quoted: 1609 Post(s)
Liked 2,216 Times in 1,103 Posts
Can't help with the pump.
Can help with the bike, Peugeot D-40. Likely has a 2 speed rear hub.
P6191882 on Flickr
P6191894 on Flickr
SJX426 is offline
Old 01-08-23, 09:09 AM
fliplap
Quoted: 97 Post(s)
Liked 328 Times in 105 Posts
Sure looks like the inside of a regular ol' Zefal/AFA pump to me. And the pump itself looks like a Solibloc by any other name. Angle of the photo makes it hard to tell, and measurements would've been useful. But I'd guess it's this part: https://www.zefal.com/en/spare-parts...sher-18mm.html
Inside of Zefal HPX for reference:
fliplap is offline
Likes For fliplap:
Old 01-08-23, 11:52 AM
juvela
juvela's Avatar
catalogue page of 1957 -
example presently on ebay.fr -
1989Pre
thanks for the suggestion
do not think leather pump cup could work with barb type mount
it would not be able to seal tightly enough around the barb
would be likely to come free with a bit of use
these plastic discs/washers are quite rigid and have a stiffening seal ring at their perimeter and edge of inner hole
they have the downside that they can become embrittled and crack
inherited a small AFA pump with this arrangement from me mum
when discovered it was not sealing opened it up to reveal a cracked disc, same model seal shown in Poutrait-Morin catalogue page posted above
juvela is offline
Likes For juvela:
Old 01-08-23, 12:43 PM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
I would assume the washer is still inside the pump body, down at the bottom.
Bad Lag is offline
Likes For Bad Lag:
Old 01-08-23, 04:22 PM
Milepost105
Quoted: 21 Post(s)
I checked but nothing there.
Thanks for all the suggestions, you guys are great.
Yes it is a two speed, here’s the whole thing
Old 01-08-23, 05:04 PM
juvela
juvela's Avatar
tip -
if you should order from Zefal as suggested above it should be easy to get a seal of the correct outside diameter, they go by barrel size rather than seal size
the critical dimension will be the hole size for the barb. it may be that OKE employs a different barb neck diameter for your size of barrel than does Poutrait-Morin. you should ask for this dimension prior to ordering. if hole size in seal too large it will not seal; if hole size too small you run risk of breaking seal when attempting to slip it over barb.
best o' luck with it.
juvela is offline
Old 01-08-23, 06:46 PM
francophile
PM me your cotters
francophile's Avatar
Quoted: 1137 Post(s)
Liked 590 Times in 422 Posts
Reminds me ... I have one of those flat plastic translucent compartmentalized boxes full of misc vintage pump parts, seals, cork diaphragms etc. I eventually need to offload. I don't foresee myself rebuilding pumps any time soon. I also have a wild grab bag of about 20, 30, maybe 40 misc pump tubes in various colours.
Anyway, I'm not sure about the OKE pumps, but I know that the Ventolux pumps on similar era Peugeot bikes used a cup-shaped cork diagphgram fixed to the end of the shaft. @juvela is on-point, measure the inner diameter / "ID" to find out what size you need.
I think the first thing you need to do before anything else is separate the steel parts of the pump and give them an oxalic acid bath overnight. Once that's done, soak it in ATF, marvel mystery oil, or similar thin oil so it won't corrode so easily again. Clearly it had water stuck inside.
francophile is offline
Old 01-08-23, 08:27 PM
juvela
juvela's Avatar
sounds like you are looking at the images of the example from ebay.fr posted by me above rather than the original poster's pump
juvela is offline
Old 01-08-23, 09:00 PM
francophile
PM me your cotters
Oh crap. You're right.
Old 01-08-23, 09:33 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
Worst case someone could cut off the nub, drill a small hole, & attach a cup with a screw and washer
dedhed is offline
