Grip installation
Grip installation
Who has the secret for ease of sliding on new grips I picked new ones up yet today they fought me on installation. Soapy water just made the grips slippery to hold. Who has a better idea?
Thanks,
Tim
Thanks,
Tim
Likes For Rick:
Quoted: 3244 Post(s)
Liked 2,092 Times
Windex or equivalent works as well.
Likes For Steve B.:
Likes For urbanknight:
Compressed air to "float" them in place and adjust.
Likes For clarkbre:
mechanically sound
All good suggestions that work well. I’ll add rubbing alcohol-slippery and then dries fast.
Likes For frankenmike:
Likes For XxHaimBondxX:
Quoted: 3515 Post(s)
Liked 2,929 Times
Hairspray is the shop technique.
Likes For smd4:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
sometimes I soak them in warm water. They slide on easy, shrink to original size when cool and stay put when water dries. Windex works well too. I've also used a grip specific spray that smelled like relabeled hair spray.
Likes For RB1-luvr:
Quoted: 4420 Post(s)
Liked 1,568 Times
Second alcohol.
Likes For Kontact:
Quoted: 604 Post(s)
Liked 1,064 Times
I’ll 3rd isopropyl alcohol, pour some into the grip, shake it around, dump it out, and slide it on. You got plenty of time to get it where you want it, but after it sits overnight, it’s on.
Tim
Tim
Likes For tkamd73:
Clark W. Griswold
Quoted: 4368 Post(s)
Liked 4,008 Times
Another plus whatever we are at for isopropyl alcohol it works well. Though I just recommend using Ergon grips, more comfortable and most of them are lock on, generally I don't need anything for those they slide on and I tighten down with a simple hex wrench and slide into comfort.
Liked 2,929 Times
Apparently Aquanet (our shop’s brand of choice) is collectible now. There’s a $45 dollar can on eBay…
Quoted: 970 Post(s)
Liked 1,632 Times
Shaving Cream, if still to hard to slide on then heat them up in hot water.
Likes For zandoval:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Cheapest hairspray you can find. Contains alcohol and lacquer. Allows it so slide on when wet and the lacquer "glues" it when it dries. You should not use too much, just a short spray in each grip.
Likes For JoeTBM:
Likes For roadfix:
Liked 2,929 Times
Liked 2,929 Times
We used compressed air only to remove grips.
Thanks All !
I shall employ a combined strategy today.
1. Soak in Hot water
2. Alcohol and Hair Spray (dollar store mini can) ready
3. Harley Tool #3 ( Large Hammer)
4. Take hot grip Lube quickly and ram that sucker on.
5. as stated on the Shampoo bottles. Rinse Repeat.
