Retro ebike conversion
Here is my almost complete conversion to a 1973/74 Raleigh. Aim is to have a cheap 25kph cruiser/commuter bike. Total spend is around £200.
Likes For spinnanz:
Quoted: 340 Post(s)
Liked 275 Times
I wanted to avoid a modern throttle and wires up front so the original 3 speed gear leaver was removed (new rear hub is single speed) and a 1980s era Shimano grip shift fitted. The grip shift pulls a cable which is routed to an electronic throttle on the pannier bag
The battery is included in the price however it was free faulty battery which was 72v 10ah which I repacked to make a 36v 20ah.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
I wouldn't suggest it. I do not see any front brakes. The front is where most braking occurs and with the higher speeds, improved braking is essential.
You could retain the lines by installing drum brakes in the front. Drum brakes are also an easy, home mechanic, install.
That is the biggest issue that stands out. Of course, a full servicing, particularly headset bearing would be essential. The back breaks don't look great. However, so little braking force is in the rear, it is a non-issue.
If those were addressed, it will be a good looking bike. I am not sure if the forks and geometry are ideal if not, the drive and battery parts are easily swappable. I do see it is a fun project.
The brakes are the original calipers, with modern pads, now gripping onto modern alloy rims. As much and a front drum or disk would have better stopping power, they are not suitable for these forks as drums/disks place torque on the end of a single fork leg, this WILL bend it. The original caliper placement will only put force just below the headstock.
"Speed" shouldnt be an issue, This was a 3 speed bike (rear hub gears). With being converted to electric rear hub, its a single speed bike now. As such, the motor geared to max out at around 25kph/15mph. This is pretty close to the achievable top speed of the bike in original form, so really no extra braking is required.
Looks real nice! I am refurbing my DW 70's Moosburg 3 speed. Amazing how a little brushing can shine the calipers! I am keeping the rims, but new tubes and tires, new brake pads, and breaking down, clean and lube everything, including cables. When I get done, she will probably want an e bike like mine!
Quoted: 363 Post(s)
Liked 66 Times
Too late, I've done it! Pictures were takes earlier in the build so they are pre-sorting of the brakes.
Great build!
That is an excellent job. I'm looking to do the same with a single speed cruiser and want to keep the look. I want to go with a rear hub motor, what did you use?
Average speed of my 18-22km commute is 30kph.
I like the vintage shifter converted to throttle. I feel inspired for my own build.
Likes For BattMan:
I took a decent ride this weekend, 18km of road riding and a few km of trails. Couldn't be happier with how the bike goes!
