Alex, I'll take "Foods that don't have to be cooked"
#126
Quoted: 3459 Post(s)
Liked 1,465 Times
Since carbohydrates are about 4 calories per gram, you can see that most of the foods that plotted to the right of the 400 calories/100 grams line are foods that have some fats since fats are about 9 calories per gram. But to the left of the 400 line, those foods are mostly carbs without much fat.
In the real world, you would have to add some weight for the ziplock bags or other packaging that came with the food, pushing weight up some small percentage.
Sodium content on Ramen, I think almost all of the sodium is in the powered flavor packet, so the user could tailor their sodium intake if the wished to. One of my tours, the former co-worker that I was traveling with did not want to lose weight (although he was overweight), he wanted to replenish 100 percent of his calories every day. We mostly had one pot suppers. And on most days we threw a brick of ramen into the pot but did not add the powered flavor packet, the ramen was used solely as an extra calorie booster.
#127
Quoted: 170 Post(s)
Liked 156 Times
I've spent a few minutes getting basic data on some food items. Turned out to be an interesting exercise. (1) Nutritional values (calories/proteins per 100g) vary quite a bit across sources. I'll double check before making conclusions as to what's best in my case; (2) Quite a few surprises. In particular, instant noodles look like the best starch, despite lots of negative comments about ramen on the www, wrt their high caloric and sodium content, which could be seen as a plus for tourers. Other revelations include banana chips (I was found of them, but didn't realise how caloric they are) and coconut powder (great on ramens). Disappointed by the relatively low score for raisins. I'll explore alternative dried fruits, hoping to come up with a GRxP where x beats raisins
All Per 100gms
Chia seeds:
Calories 486
Protein 16.5gms
Carbs 42.1 gms
Flax Seeds:
Calories 534
Protein 1.9gms
Carbs 3 gms
Hemp seed:
Calories 566
Protein 38 gms
Carbs 6.6 gms
Almonds:
Calories 579
Protein 21 gms
Carbs 21.5 gms
Cashews:
Calories 553
Protein 18.2 gms
Carbs 30.2 gms
Walnuts:
Calories 654
Protein 15.2 gms
Carbs 13.7 gms
#128
Bikes: Custom built LHT & Troll
Quoted: 845 Post(s)
Liked 149 Times
you make nutritious smoothies (see updated chart below).
I'll explore a bit. First impression was to get on with the walnuts. But then, there is the cost (3x peanuts) and perhaps density -- same punch might require a larger bag (quick search and I stumbled across this -- unfortunately just a ranking rather than hard density metric. Almonds, perhaps? Fun research ahead
#129
Quoted: 598 Post(s)
Liked 283 Times
I'm wondering where a fried chocolate pie would be located on your chart ? Actually, don't tell me, I'll enjoy it even more here shortly if I don't know.
#130
Quoted: 170 Post(s)
Liked 156 Times
Density will be based on this equation I believe. Fat being the dense part of it. More fat = more dense....I think
Fried chocolate cake....with ice cream hopefully FTW
Likes For balto charlie:
#131
Quoted: 2236 Post(s)
Liked 1,314 Times
You've got refried beans pegged at around 350calories/100grams. It's really 145. Couscous at nearly 400 when its about 112.
Where are you getting these facts from?
https://www.fatsecret.com/calories-n...amount=100.000
#132
Quoted: 845 Post(s)
Liked 149 Times
Actually, by density I was simply referring to the nutritional value per volume unit (say, a litre).
Walnuts are one of the more nutritious nuts (20% more calories per gram compared to peanuts). However, if you purchase walnuts sold in halves, you'll probably get only half the weight of peanuts in a given volume, so peanuts are a better choice if storage space is a consideration. (crushed walnuts should do better than halves). WRT starches, at first glance ramen look like a better choice in comparison with couscous (10% more calories per gram) but since a ramen cake is perhaps twice the volume of an equivalent couscous by weight, you'd be better off carrying couscous.
Eventually, I'll try to get nutritional values per volume unit for key food items.
#133
Liked 1,314 Times
Another no cook food source to consider: Hardtack ? The Ultimate Survival Food - Score Survival
#134
Quoted: 845 Post(s)
Liked 149 Times
#136
Liked 1,465 Times
One more thought came to mind.
Not sure if any stores in Canada sell anything like this:
https://www.fleetfarm.com/detail/fle.../0000000068786
I have bought that and split it into small zip locks when at home to take on trips, one baggie per day for snacks during the day.
It looks heavy and when you feel the weight of the package, it is (package almost a kg). But, that is misleading because at over 5 calories per gram that probably has more calories per gram than you will average when you add up the rest of your food. And it is quite dense (low volume), plus a bit of protein, suddenly that starts to look like a pretty good food to bring along. And M&Ms are the best way to carry chocolate in hot weather.
#137
Quoted: 845 Post(s)
Liked 149 Times
This is basically "enhanced GORP". What is interesting, though, is that it is priced very competitively compared to the "designer trail mixes" that are frequent in our grocery and specialty stores. Unfortunately, not available in Canada from what I can see. But, yeah, source of inspiration
#138
Liked 1,314 Times
The values you refer to are for cooked food, i.e. including water. I took the nutritional values from the label on the packages. Found very close figure here
Ps. Not saying you have to do anything personally perse, just using "you" in a general way and bouncing ideas around. I think the graph thing is a good step in making decisions
Likes For phughes:
#140
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Nice graph. I don't like to eat by the numbers, but there are times when packing that you need to. For instance, I always bring something fresh for at least the first three or four days, like a carrot, apple, celery, pepper. Pretty much useless numerically, but it makes me think I'm eating healthier. Carrying fresh fruit and veg is more a volume concern than a weight concern for me.
Re: Walnuts, I pack walnuts for muesli but prefer cashews for snacking. I just found out that walnuts have higher fat, but cashews have higher protein. It's probably not a bad idea to carry both. And walnuts aren't bad on salads in lieu of dressing. Dried olives, too, if you can find them.
Raisins and cashews are my perfect snacks. Raisins for a quick sugar boost mid-day, cashews at the end of the day for fat and protein.
#141
Liked 1,314 Times
Yes. We are all bots
Just eating only works if you have food sources readily available and no expectations or demands on physical output. Once you have to preplan or desire a specific outcome you wind up thinking about it. Or fall prey to every fad or miracle product that comes along.
Most easily prepared base expedition grade diets can be made from simple cheap ingredients with a little forethought and pre-planning.
#142
Liked 1,465 Times
If the "serving size" used in Canada is the same as used in USA, that has nothing to do with nutrition, it was deemed an average size actually eaten in a meal decades ago by some committee. And a lot of those numbers were created in the era before a lot of people became obese. Some of the numbers have changed recently as people started to look at them and realize how stupid some of the numbers were.
#143
Liked 1,465 Times
#144
Liked 1,314 Times
Taking oatmeal for example. You can look at the calories for 1/2 cup or 2 1/2 cups. Very different numbers. Which value do you use? 1/2 cup raw makes nearly 2 1/2 cups cooked.
However, 1/2 cup almonds is still 1/2 cup almonds - raw and serving size.
You should account for the difference between raw and serving size. If I want to calculate how many calories in my morning oatmeal by volume do I do that raw or cooked. There's quite a difference in calorie count between 1/2 and 2 1/2 cups. That's why I question some numbers for foods like oatmeal, rice, couscous etc...
#145
Liked 1,465 Times
Not what I'm talking about.
I rarely think in volume measurements, I have a good weight scale that often use. For example, at home I know how many ounces of pasta noodles I want, how many ounces (by weight) of sauce I want on it, etc. When I bbq, I know that I want my hamburger patties to be about 5 ounces, etc. But, I am an engineer by training, we often think in terms of absurdly excessive precision for things that do not warrant it.
Likes For Tourist in MSN:
#146
Liked 1,314 Times
Got it.
#147
Quoted: 845 Post(s)
Liked 149 Times
WRT portions -- my understanding is that you should work backwards, i.e. first getting an estimate of the amount of food (fuel) you'll need to burn. My estimate is 3 000 - 3 500 calories/day. I also know that I need close to a week of complete autonomy. The back of the envelope estimate is 2 pounds per day (900g). What is not clear to me is how large a container is required. (2 x 7 -> 14 pounds of Cheetos would require a fairly large bag). Important to me because I'll travel in a bear/minibear country such that my food should fit inside my 11L Ursack. My understanding (from reading Ursack's marketing blurb) is that 11L will hold enough food for 5 days x person -- one day short. I might be able to squeeze 6 days (the seventh doesn't have to be stored because it is eaten before bears can get to it), but that won't happen without some planning. Which is why I am googling nutrition facts
#148
Liked 1,314 Times
You are right about working backwards. Part of my food experiments design is to eat a certain food and see how my body reacts while performing daily physical tasks. The bean challenge was interesting in the sense that I felt no drop in energy over the whole month. In contrast my egg challenge created a steady decrease to the point that my body went into energy conservation mode similar to that faced by slowly starving people.
The other part is what you can stomach (pun intended) to eat for a sustained period. In one sense a complete nutrient and calorie dense meal bar would be best, as it would contain everything in the smallest packet size, but one may balk at eating them repeatedly. I get that way a bit with cliff bars.
Also, what keeps you satiated for a long enough period. This point is one reason I tend to avoid sugar/refined carbs in my diet.
#149
Liked 1,465 Times
But I was fortunate, did not need to worry about bears on past solo bike trips.
And my trips where I did need to worry about bears were areas where usually there were good trees for hanging food. I previously mentioned that I bought an Ursack but have not yet used it. Most of my trips where bears were a concern were canoe trips, and both weight and volume were much less important on those trips.
You might have to roll the dice on your first day out, one dry bag in addition to the Ursack and hope that nothing goes wrong. For example, if you had some canned food, that should be free of scent so perhaps that could be outside the Ursack.
Do you have any friends that can loan you a second Ursack?
#150
Quoted: 845 Post(s)
Liked 149 Times
No, unfortunately, no UrsFriends. However, since the family "might" be traveling in bear country later this Summer, I could rationalize the purchase of another. But then, that's a lot of stuff and I'd rather have everything stuffed in one bag. I "think" this is doable. Will update.
