An I friction shifting wrong
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 676 Post(s)
Liked 447 Times
When I shift from the large ring to the small ring my shifts are very smooth. Shifting from the small to large ring, not so much.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
my money is on a worn large chain ring....and/or stretched chain
Quoted: 676 Post(s)
Liked 447 Times
Bikes: Indeed!
Quoted: 1504 Post(s)
Liked 3,443 Times
Quoted: 1820 Post(s)
Liked 3,330 Times
a wise philosopher is reported to have said "The secret to happiness is low expectations".
Since I'm very accustomed to my vintage bikes, I expect that shifting to the big ring will be a bit slower and more tentative than shifting to the small ring.
My bikes don't have chainrings with pins and ramps that make modern hardware shift quicker and easier. The poor derailleur has to just shove the chain against the big ring and pray that it ends up on the ring's teeth (and doesn't go past).
Of course, technique does make a difference. As with most shifting, things work better if you don't pedal hard during the shift. How much experience do you have with friction shifting?
There might also be issues with the position or orientation of the front derailleur. Photos would certainly help!
Steve in Peoria
Steve in Peoria
Quoted: 981 Post(s)
Liked 1,838 Times
I've never had a friction shifting setup where I felt the upshift to be as smooth as the downshift... To go to the small ring you're literally knocking off and dropping the chain in front while simultaneously releasing tension on the rear derailleur spring lower spring. To upshift you're forcefully pushing the chain up into position with the the front derailleur cage and creating tension on the rear derailleur when the chain tightens up. I can't imagine how out why it should be as smooth in the one direction as the other. Maybe that's a poor assumption, though!
-Gregory
-Gregory
Likes For Kilroy1988:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
-Gregory
-Gregory
Quoted: 676 Post(s)
Liked 447 Times
I'm sorry I didn't state my original post right. It's not the chainring is is the rear freewheel
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
what kind of freewheel? what's the gearing on it? how long have you had this? how long has the shifting been poor? need pics and/or details to help at all
Quoted: 1601 Post(s)
Liked 2,187 Times
robertj298 Take a picture of the RD on the smallest and largest sprocket. There are a number of variables that can contribute to the problem.
Habitual User
Quoted: 4836 Post(s)
Liked 7,827 Times
Although the factors aren't as great as on the front, the points made earlier about working with or against gravity and spring tension still apply. Shifting to a smaller cog with tend to be easier/smoother. That said, with parts in good condition, well lubricated, and properly adjusted, it shouldn't be a battle going either way.
Likes For Eric F:
I’m a little Surly
Quoted: 698 Post(s)
Liked 1,292 Times
No ramps and pins means no modern smooth transition
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
Quoted: 4559 Post(s)
Liked 2,798 Times
The trick to friction shifting from a smaller rear cog to larger cog is to ease off pedaling pressure for just a moment while shifting. Feel for the slight resistance as the chain encounters the side of the larger cog. Resume pedaling pressure and nudge the lever very slightly to complete the shift. Trim as needed.
Practice very deliberately at first. Stop pedaling and coast, shift up from smaller to larger cog. Feel for the resistance. Resuming pedaling gently to complete the shift.
After a little practice it'll become intuitive. You won't need to stop pedaling. It's comparable to learning how to use a clutch with a manual transmission.
The shorter the cable, the better the feel. I find my bike with bar end shifters a bit finicky in friction mode, and mostly I rely on muscle memory of the shift lever throw. On my bike with downtube shifters the feel is more palpable.
Quoted: 981 Post(s)
Liked 1,838 Times
I just have to apologize for the typos in my previous post, which was already quoted. I wrote it in a drive thru during my break. Ha.
I think in the case of a rear derailleur most of the same logic still applies, as mentioned above by others!
-Gregory
-Gregory
