Do bike tires go bad with age?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I'm looking at some older Vittoia Rubino3 tires that are new in the original box
for $55 for the pair. Would these tires still be good?
Quoted: 529 Post(s)
Liked 255 Times
I think nobody can tell you with those specific tires.
Rubber and tires do deteriorate with age. They may deteriorate more rapidly when exposed to sunlight. Then not all tires are the same. Many are still good after several years.
I would not pay very much for old tires.
Likes For alo:
Quoted: 1372 Post(s)
Liked 1,751 Times
I installed a NOS set of tires on the bike that I ride in Jamaica. In one season and just into the second season, they failed utterly. Will I ever use old NOS tires again, on a bike I ride? Not a chance.
Taken at the beginning of season two (I ride between three and four thousand kilometers each season, while wintering in Jamaica)...
Taken the day, or two, after the failure. The gumwalls were in a nasty state of repair...
While on the subject, old plastic rim liners are NOT to be trusted, either...
I bought a set of tires in Jamaica and they are darn near bullet proof...
Quoted: 1079 Post(s)
Liked 1,899 Times
I've had some 28 Paselas for ages that steal my beer, act obnoxious and are often aggressive towards me and my wife. I'll say they've gone bad.
Likes For P!N20:
Quoted: 3810 Post(s)
Liked 6,690 Times
Yes.
Likes For nlerner:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Quoted: 677 Post(s)
Liked 459 Times
Strange. I had an 88 Miyata mtn bike that had the original Miyata tires on it. They still looked really nice.
No cracks in the sidewalls and they looked almost new.
Port
Quoted: 983 Post(s)
Liked 1,861 Times
Simple answer is YES.
More complicated answer is that all tires deteriorate, but at differing rates depending on how they were stored, where they were stored, what rubber compound etc...
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
fify
My Bikes
My Bikes
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
How old are we talking about? FWIW, I wouldn't say this is much of a deal if the tires are more than a few years old. If I found them in my garage and needed to use them, I might give it a try.
Quoted: 930 Post(s)
Liked 1,291 Times
Most definitely. Same for brake pads. UV light, oxygen and ozone are the primary culprits. Folks who ride vintage bikes with original tires and pads have a death wish as far as I'm concerned.
Quoted: 1829 Post(s)
Liked 3,375 Times
a bit of a coincidence, but I had an issue with one of my own tires that I had put in storage for a few years.
It was actually a set of wheels with the same tires that I'd been using when I had decided to change to a set of wheels with wider tires.
The old tires were in good shape with little wear. No degradation was obvious, and they were being stored in the same room where I keep all of my spare tires (a spare bedroom).
Well, I was about 18 miles into the ride and on the way home when I felt a bit of a vibration. I had just turned onto a different road, so it might have just been undulations in the road surface, but I pulled over and took a quick look. The bulge in the tire suggested some broken cords, so I let a little air out (to avoid more cords breaking), and headed for the shortest route home.
I got within a mile of home when the tube blew. When I stopped and looked closer, I could see that there were some sections of tread coming off of the cords. Not good, and I thought about it during the walk home. (thank goodness it was a bike with SPD pedals!)
When I had time to pull the tire off and take a closer look, I discovered that it wasn't just the tread delaminating from the cords, the cords had also delaminated from the tire's interior surface! I think the tube must have pushed between the layers of the cords or just pushed around them.
I haven't looked in my records to see if I can figure out when I put these tires on. No idea when they were made... although these are Michelin Pro 3, and I know I've got some Pro 4 tires in a different size, so maybe these were old stock when I got them?
This isn't to suggest that this will happen with other tires, but I suppose that this sort of problem, if it will happen, will be less likely when new (just a guess).
At the other end of the scale, I've got the Vittoria Giro D'Italia tubulars that came with my '74 Raleigh International. The tread is still bonded to the cords and it still holds air. I'm not brave enough to actually ride on them, though!
Steve in Peoria
Steve in Peoria
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
It depends on how they're stored. Exposure to heat, UV light, and/or ozone will accelerate degradation. Cool, dark, dry storage means they can last a long time. Premium tubular tires would be aged prior to sale and use to give the rubber a chance to harden a bit. I have some 30+ year old tubulars that still look new and hold full pressure:
Likes For JohnDThompson:
