Short top tube model?
probably looking for a smallest size of 700c bikes, even women's bike is ok.
just looking for toptube is shorter than 500mm,
450mm – 470mm would be perfect, I'm not even sure that could exist.
Quoted: 714 Post(s)
Liked 800 Times
Such a frame would have some serious toe overlap with the front wheel. Also, top tube length is not really a good metric to compare frames. With sloping top tube bikes, the method of measuring top tube length is all over the place between manufacturers. The proper way to compare frames for reach is to use the "reach" measurement, which is the distance between the center of the bottom bracket to the center of the top of the head tube. Most geometry charts now list "stack" and "reach" numbers, as well as the traditional geometry numbers.
Likes For dsaul:
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
https://www.jamisbikes.com/usa/renegadeseries.html
Jamis' steel and aluminum frames come in a size 44 that has an effective top tube of 502mm and uses 650b wheels. Really neat feature is that the fork is designed to the frame sizes so that overall trail is relatively similar across sizes.
This size 44 ia advertised for young teens and would be intended for probably 4'10-5'2 or so(guess based on geometry chart).
What you are looking for many only come in a 24" wheel size. For example, here is an old Kona offering...
https://2016.konaworld.com/jake_24.cfm#spectop
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Agreed, you want a "700c" bike that has been downsized for 650b wheels to keep the same handling (and lack of toe overlap) of the larger frames. The ones above are good options. Canyon Grail does this too. Their specs say 162-166cm height, 516mm top tube (so a little bigger than the bikes above).
1x builds:- https://kidsracing.co.uk/collections...-low-standover
They do up to 54cm, so its more proportions than just kids.
HUP website mentions:- 68mm bb. 1x is 44t max. (can be setup 2x 50/34 max). axle 142 / 100.
Clears a 650b x 42 or 700x38.
44cm mentions a 49cm top tube.
37cm mentions 48cm.
Probably want to contact them to confirm effective top tube lengths / standover on a bike size.
37cm mentions 48cm.
Likes For tangerineowl:
Quoted: 336 Post(s)
Liked 309 Times
Are you set on 700c? If so, what is driving the decision? This will be the biggest challenge. With 650b/27.5 rims now available, most reputable brands now spec smaller wheels on the frame sizes below ~50cm to avoid the trade-offs inherent in 700c/small frame designs.
Likes For aggiegrads:
