Quiet Hubs: Onyx, Alto, Phil Wood, Shimano, Project 321 quiet pawl
Looking for quiet hubs for some custom wheels. It seems Onyx are nearly silent and Shimano are very quiet. Any experience with Alto, Phil Wool or Project 321's quiet version? Or, other suggestions?
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
What, you don't want a hub that sounds like a swarm of angry murder hornets? This seems to be the fashion ATM.
Likes For Korina:
Definitely want to avoid the angry hornets! To each his or her own, but I don't understand the desire for loud hubs. I love being able to silently move through the world; it is one of the best characteristics of riding a bike. Unfortunately for people who want quiet hubs, you seem to be right that loud is in.
Likes For A2Doug:
Liked 2,979 Times
i was briefly looking for a rear wheel assembly & could not find those other brands you mentioned to have a non early 90s honda civic @ 8,000 RPM with a limp rod bearing noise. The for sure thing is to stick with the tried & true Onyz.
-Oh Hey!
-Oh Hey!
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Uh, Onyx are as silent as hubs get. They are not lightweight, but it isn't physically possible for a hub to get much more silent--as there is no ratchet at all.
I should have said, this is for road wheels with disc brakes
Quoted: 6196 Post(s)
Liked 4,811 Times
Don't coast.
Likes For Iride01:
Liked 406 Times
I do love my set, had them laced to Light Bicycle rims.
Rim or disc brake? For rim brakes you can find older Shimano silent clutch hubs, pretty sure they never did disc brake versions.
The most common was the LX level, but you can newer Nexave hubs sometimes. I built one into a custom wheel for a 26" mountain bike.
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
Some hubs are loud some are not. If it's too loud you're too old.
Or something.
Or something.
Likes For aplcr0331:
Likes For bOsscO:
Liked 4,811 Times
Interestingly enough I have loud hubs because they work so well on my commute. I have about 10 miles of my commute on a MUP and in the past saying "On your left" produced some interesting results (moving to their left was a good one, lol) and ringing the bell usually resulted in only the tilting of their head. But I had some robust wheels built up around a DT Swiss 350 hub and that thing buzzes. I added a 54t ratchet and it now sounds like a swarm of murder hornets. EVERYONE turns around when I backpedal behind them. It's such an unnatural sound that in my experience it works way better than calling out and a bell. I'll keep these wheels for commuting as long as possible.
Shimano hubs are quiet. I had a pair of 105 hubs on some wheels that came with my first road bike and they were silent but still seemed to work pretty well. Low maintenance as well.
My weekend road warrior wheels are still a bit buzzy cause they're just cheap shop branded wheels so I'm still part of the baseball card in your spokes cool guy crowd.
Those that do stupid stuff to your announcement are noobs that will later learn what to do. Noobs will always be among us. As are the people that show up in the spring for their one or two walks a year on the MUP that will be forever noobs. <grin>
Any how, that is my opinion and I'm sticking to it.
Randomhead
Liked 3,699 Times
on the second day of a 600km brevet, I was so sick of listening to my Hope hub that I pedaled on downhills.
When I was buying hubs for my gravel bike recently, I considered getting an Onyx. One of the other mechanics told me he had trouble with the reliability of his Onyx hub, so I went with another Hope. If I get another hub for my mountain bike, I probably would go with Onyx. They will engrave a custom graphic for you.
Quoted: 1461 Post(s)
Liked 1,486 Times
I think this trend of loud hubs came about because of of the popularity of Chris King hubs, which off-roaders love because of the super fast engagement. To get that fast engagement, they have more teeth which makes more noise as the pawls click over them.
The reason Shimano hubs are quiet is because they have relatively small number of engagement points, which makes for slower engaging hub but also a lot less drag and noise.
Engagement probably doesn't matter to most road riders. It's really only a factor if you're ratcheting over technical off-road terrain and find 20 degrees of pedaling before the hub engages to be problematic. Regardless, Chris King hubs are quality stuff and many road riders use them, and may other high end hub manufacturers have similar high-engagement designs, so the noise is now associated with high-end hubs.
Those Onyx hubs look like a really cool alternative. Instant engagement and no noise, but the trade off is a bit more weight and I've heard that they can feel a bit squishy on acceleration.
Quoted: 850 Post(s)
Liked 344 Times
P321 has a tandem option with 6 pawls. I'd talk to them and see if you're light enough to ride with 3. The regular version has unnecessarily high engagement IMO. It also only engages 2/6 pawls so I bet that running 3 pawls in the tandem version will be just fine.
standard version has 1.7 deg engagement
tandem has 2.5 deg engagement
tandem/2 is 5 deg.
DT 36T is 10 deg. And that's considered fast
DT 18T is 20deg. I have no issues with mine.
tandem/2 is 5 deg.
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
My 2006 Bianchi had a Fulcrum Racing 5 wheelset with THE LOUDEST freehub. I used to use it in place of calling 'On your left'. Well last spring I discovered cracks on the rear rim around nearly all the spoke holes, so I bought some NEW Fulcrum Racing 5s and they are SILENT. No longer does coasting down a fast descent sound like a marlin just took the bait and ran. I like it better, honestly.
Quoted: 1572 Post(s)
Liked 643 Times
I've had some vintage Shimano LX level hubs that had a silent clutch. They were noticeably heavier than the standard LX hubs of the era (1995 - 2000). The target market for those hubs was police bikes. I don't know if they are available anymore or not.
Liked 406 Times
Still you better say "on your left", "passing left", "bike back" or ring that bell when you get near me. When I'm walking with my wife, you might get clothelined when I point at something across the way.
Thanks all for the helpful replies. I ended up ordering wheels with DT Swiss 350 hubs with the 18 teeth. I have heard and read that you can keep these reasonably quiet by greasing the pawls instead of just oil. If they annoy me, I may have the rear wheel rebuilt with an Onyx hub. The conclusion seems to be that Onyx is silent, Shimano is nearly so, and the others range from somewhat noisy to very noisy. I would still like to know how the quiet version of the 321 sounds, as well as Alto and Phil Wood. Thanks again
A DT Swiss 350 hub has a start ratchet, not pawls. Adding grease between the ratchets help quiet them.
