650 b wheels same as 26 inch?
Old 05-18-22, 07:13 AM
jdogg111
Quoted: 137 Post(s)
Liked 51 Times in 31 Posts
hello folks. i have lots of confusion with wheels, tires. are 650b tires the same size as 26 inch. i see lots of folks on here that have converted 700 wheel sets on their bikes to 650 b and wondered what would be involved in doing this. i have both 26 inch rims laying about and some new 650 b tires i ordered by mistake and never got around to sending back. thanks for any help.
jdogg111 is offline
Old 05-18-22, 07:35 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,221 Times in 2,367 Posts
Depends on which 26” wheels you are talking about. There are 7 different sizes that are called “twenty six inch” in our goofy tire sizing system. 26” mountain bike rims (mostly) have a 559mm bead diameter. 650B is an old French designation for a 584mm bead diameter. The 650B will not fit on a 559mm rim.You’ve got both the wheel and the tire sitting around so it should be trivial to see that the tire won’t fit on the rim.
For the conversion from 700 to 650B, you need new wheels (and something to use as a brake)
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 05-18-22, 07:49 AM
5teve
Quoted: 69 Post(s)
Liked 65 Times in 29 Posts
Can you hold the rims and tires you have up against each other and see if they fit together?
5teve is offline
Old 05-18-22, 08:03 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
Some of your rims might have the ISO/ETRTO size printed or stamped into them. Usually, as they do on tires they put it in the tiniest print size possible. It will be written as nnn x nn or sometimes nn x nnn. Don't know for certain, but when they write it backwards I wonder if that is a sign that they don't comply fully with ISO standards. Though ISO is a voluntary standard so they certainly don't have to abide by ISO standards.
When you find the ISO size of your rim, then the three digit number will be the BSD or bead seat diameter. Knowing that, you'll know what size tire you can put on it since the ISO size will almost always be found somewhere on your tires. It too usually in the tiniest possible print embossed or stamped on the sidewall.
The two digit number in the ISO size of the rim is your internal rim width from the bead seat on one side to the other. On the tire it is the nominal width of the tire. Both in millimeters.
If any of your rims have a tire on them, then just look at the tire. Find the ISO size of the tire and you know the BSD of both.
Iride01 is offline
Likes For Iride01:
Old 05-19-22, 11:56 AM
Jrasero
Bikes: Scott Foil RC, Specialized Aethos
Quoted: 228 Post(s)
Liked 135 Times in 89 Posts
No 650B are equal to 27.5
Jrasero is offline
Old 05-19-22, 12:42 PM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,292 Times in 744 Posts
Here is everything you didn't want to know about tire sizes, but very informative. https://www.sheldonbrown.com/tire-sizing.html
phughes is offline
Old 05-19-22, 12:58 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
I’m no expert on vintage tire sizes, but here is how I understand it.
26” refers to the outside diameter of the tire. The actual beam/rim diameter can be anywhere from 22” to 23-1/2” (559mm to 597mm)
27” tires also refer to the outside diameter of the tire. I believe the standard beam/rim diameter was around 24-3/4” or 630mm.
In the British Empire and it’s former colony across the pond, the Imperial system of inches flourished for many years. It is so ingrained that people ride 29ers with the same bead diameter as a European road bike (622mm).
Meanwhile the French, and I suppose other countries, have a size called 650. It’s diameter was 650mm outside diameter or 25-1/2”. There is an alphabet soup of bead diameters that ranged from 22-1/2” to 23-7/16 (571mm to 590mm).
So yes 650b is historically a 26” tire, except for mountain bikers. No one will buy a 26+ mtb, so the logic is a bigger modern mountain bike tire is 27.5” in diameter. Likewise a 29” outside diameter tire can’t be called a 700mm outside diameter because it is so much beefier. But we won’t talk about 700c X 40 tires.
Such is life.
John
Edit Added: 700mm tires have been referred to as 28” tires using the rounding system from 27-1/2”. In retrospect 28” might be more accurate these days than 700mm.
70sSanO is offline
Old 05-19-22, 01:34 PM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
some very thorough and technically correct responses here, but I found the way they were presented to be a bit confusing.
WHAT YOU NEED TO KNOW
26" as was the common size on mountain bikes for many years is NOT the same as 650B. 650B rim has a bead seat diameter (the dimension that mates with the tire) of 584mm, while a 26" mountain bike wheel has a bead seat diameter of 559mm. A 650B tire will be too big to fit on a 26" rim.
The Sheldon Brown article linked above is the best resource if you want to learn about this.
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 05-19-22, 02:25 PM
70sSanO
70sSanO's Avatar
While this is a bit OT, if 26” is 559mm bead diameter and 650b is 584mm bead diameter, that is a difference of 25mm (1”) in diameter.
How did the industry get to 27.5?
I’m pretty sure it is just marketing to fairly uninformed consumers that wanted a size right in the middle of 26” and 29”.
John
70sSanO is offline
Old 05-19-22, 03:01 PM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
Not exactly 'uninformed' but 559 MTBs were and are most commonly referred to as 26" probably from their Schwinn / Klunker origins. Nobody has ever, outside of the pedantics at BiekForums, referred to them as 559's. There have been occasional '700c' (622mm) MTBs appearing as far back as ~1991, but the y2k-era 29" moniker better describes how it's different from a 26er, than '700c'.
Same for 27.5", which is really 650b, but again, tells you much more easily that it's bigger than a 26er but smaller than a 29er.
With the trends towards wider rims/tires in the gravel/adv segment, the line's getting blurred, but generally, "29er" has referred to 622mm wheels for all-terrain tires wider than 47mm or so (1.75" for you MTBers), and "700" for narrower, pavement-biased tires. Same for 650b -v- 27.5"
Ironfish653 is offline
Old 05-19-22, 03:02 PM
ClydeClydeson
Quoted: 581 Post(s)
John
Think of the size - 26" or 27.5" or 650B or 700C as the 'name' of the size - it is related to the size but not necessarily directly.
As to where these names came from -
Bead seat diameter + 2 x nominal tire cross sectional tire diameter = nominal outside diameter of the wheel/tire
584mm/25.4mm/inch + 2 x 2.25inch = 27.5 inch
IOW a 584mm rim plus a 2.25" wide tire has an approximate nominal outside diameter of 27.5"
Similarly, a 559mm rim (trad. 26 inch mountain bike size) plus 2 x 2inch tires = 26 inch nominal outside diameter
Same goes for 700C - 622mm + 2 x 39mm tire = approx. 700mm
ANd when 700C wheels started being used for mountain bikes:
622mm/25.4mm/inch + 2 x 2.25" = 29", hence the correct although slightly confusing name of '29er'
With the fatter tires for mountain bikes, the original French 650 or 700 sizing isn't accurate, but the modern 'inch' designations kinda is when you have a particular tire size.
Old 05-19-22, 04:10 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
No...they're not equal to 27.5 they just happen to share those 2 names. It would be more accurate to say '27.5 is the same wheel size as 650b'.
cxwrench is offline
Old 05-19-22, 04:24 PM
70sSanO
70sSanO's Avatar
Good math. Thanks!
I won’t go to 20psi tubeless.
John
70sSanO is offline
Old 05-19-22, 06:52 PM
cyccommute
cyccommute's Avatar
So far so good. What you are missing is that the “standard” tire differs for each of those sizes to reach the magic nominal tire diameter. A 559mm rim, for example, is 22” in diameter. To reach 26” outside tire diameter means that a 2” tire is used. For a 622mm rim, the diameter is 24.5”. To get to a 28” diameter, a 1.75” tire (a 44mm). Not many people now, or even when the tires were first made, would use that wide a tire.
The French sizing system is even goofier. There are 700 and 650 rims but the size is based on the width of the tire designated A to D with the A being a narrow tire and the D being a wide one. The 700 series rim sizes are 642mm (A), 635 (B), 622 (C), and 583 (D). The tire width needed would be 29mm (A), 32mm (B), 39mm (C) and 58mm (D). A similar system existed for 650 series rim/tire size. Obviously we aren’t really using the tire size that was meant for the French system with 700C tires. Some are but, for the most part, people have traditionally used narrower tires on those rims.
The 26” tires that were originally used for mountain bikes are a left over of where mountain bikes came from. The converted balloon tire bikes used in the early ages of mountain biking were really closer to 26”…a 559mm tire with a 50mm (2”) tire…then a 700C is to 700mm. The 27.5er (584mm) and 29er designations are due to the true tire size which is what you get when you put a 2.3” (58mm) wide tire on 622mm rim (for example).
Stuart Black
Old 05-19-22, 07:06 PM
70sSanO
70sSanO's Avatar
Thanks!
John
70sSanO is offline
Old 05-19-22, 09:01 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Such is life.
John
650c is a 26" tire, not 650b.
cxwrench is offline
Old 05-19-22, 09:13 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
Not entirely true. Referring to 650b as a "26 inch" size is uncommon, but historically it has carried the "26 x 1 1/2" label.
HTupolev is offline
Old 05-19-22, 10:18 PM
70sSanO
70sSanO's Avatar
Nope. 650c and 650b are considered the same outside diameter; 650mm. So if 650c is 26” so is 650b.
The b and c refer to the bead diameter; 584mm and 571mm.
650b tires were around before you were born.
Obviously as tires increase in width they increase in height so all sizes are not measured at 650mm outside diameter.
No different from a 700c, (c doesn’t mean clincher), X 23 through 40. They are all identified as 700mm outside diameter, but they all cannot actually measure 700mm in diameter.
John
Edit Added: If you had used etrto 584, such as 60-584, you would have been correct.
70sSanO is offline
Likes For 70sSanO:
Old 05-19-22, 10:43 PM
cyccommute
cyccommute's Avatar
John
Correct. There is (or was) a 650A (590mm diameter). I can’t find any reference to a D in the 650 series although if there is I suspect it would be pretty close to a 559mm rim diameter.
Stuart Black
Old 05-20-22, 07:15 AM
ClydeClydeson
Quoted: 581 Post(s)
650A is also called (IIRC) 26x1-3/8 (590mm BSD) and this was a very common size up until the early/mid eighties. The 26x1-3/8 was the common name for the size - I didn't even realize it was also called 650A until a few years ago, and I owned, serviced, and sold tires for many '650A' bikes over the years.
Old 05-20-22, 09:16 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Like with 700D, I doubt that a 650D existed in the original French system. By that point, you'd probably be looking at wheels with a smaller nominal diameter like 600A.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 05-20-22, 01:43 PM
cyccommute
cyccommute's Avatar
According to Sheldon Brown, the 700D did exist and was used by GT on the Tachyon. They introduced that bike in the late 80s and want to make the wheels the new standard. It didn’t work, obviously. Here’s details on the history of the Tachyon
Stuart Black
Old 05-20-22, 02:12 PM
ThermionicScott
Did 700D exist before GT used it, though? I believe they created it out of whole cloth to have a propriety wheel size, and gave it a French-sounding designator to make it sound legit...
Balloon tires on 650B rims was a well-established thing in early 20th century French bicycles, so they would have had no need to create another standard so close to it.
RUSA #7498
