Park FR-18 Vs. FR-1, FR-11, etc.
A large bike shop in my area is having its End-Of-Season Sale today and I just got back with a couple of tools I am having second thoughts about.
I needed to replace the chain whip I use to remove my 7-speed cassette, so I took the first one the salesman handed me, which I thought was the only one out there. It's a Park FR-18, which, upon closer inspection of the package, is designed for freewheel removal. I Googled it a few minutes ago and found that the FR-1 and FR-11 are both listed as "cassette removal" whips. Is there a problem using the FR-18 on my Shimano HG 7-speed cassette? I don't see much difference between this and any other chain whip.
I also bought a new FR-5 Lockring Remover. It's actually the FR-5G, the one with the guide pin through the middle. Of course, not until I got it home did I have that "duuuuuuh" moment when I realized I cannot use this on wheels that aren't quick-release. I guess that's OK, as this won't affect our main bikes, but it means I have to use my old (semi-stripped) FR-5 anytime I do a favor for someone with a non-quick-release wheel. Anyway, the question is: I initially wanted a lockring remover with a long handle attached so I don't have to screw around with a lock wrench or vice. Is there a lockring remover out there (doesn't have to be Park) for standard Shimano cassettes that fits this bill?
Quoted: 2026 Post(s)
Liked 1,096 Times
Chainwhips are universal and there is no such thing as one dedicated to a freewheel or a cassette. One size fits all. The FR5G can be converted to a non-pinned FR5 by driving out the centering pin. Place the FR5G, pin up, over a vise opened just far enough to clear the head of the pin assembly and drive out the pin with a mallet.
Thanks for confirming what I suspected about the chain whip.
Quoted: 4218 Post(s)
Liked 3,897 Times
The only spec differences that chain whips do have is the chain size. Some will use 1/8" chains, some will use 5,6,7 speed width chains and some likely now have 10, 11 speed chain widths. Cramming a wide chain onto the middle cogs of a narrow spaced cassette is a pain but better then not having a whip with a wide enough chain... Andy.
The SR-18 (sorry, I've been calling the "FR-18") only says that it will "fit 1/8" Fixed Gear Sprockets." It makes no mention of chain size, but I did notice that the chain segments appear a little wider than my 7-speed chain. When I brought this up with the salesman, he barked at me like I had insulted him. "It fits any chain, man!"
Liked 1,096 Times
OK, chainwhips aren't as universal as I said. A chainwhip for a 1/8" singlespeed/track/fixie chain is going to be an excessively tight fit if used for cogs using a 3/32" derailleur chain. You need an SR-1, SR-11 or SR-2.2. The salesman was wrong too. Take it back and have the shop give you the right one.
I've Googled it a little further and the general consensus (I did not say "the truth") seems to be that the SR18 is OK for a 7-speed chain, as long as you use it on the largest cog, which provides the best leverage anyway.
I just returned the FR5G and took home an FR5, even though I had already ordered a lockring remover from Nashbar that seems to fit all my original specs (attached handle). So now I'll have two of these, but I didn't have the heart to take a refund from the store where the salesman had spent so much time with me.
At least it was only $5 on sale.
Quoted: 358 Post(s)
For $5, I would have kept it, especially if you have the other tool on the way.
I discovered a long time ago that the tool you expect to never use turns out to be one you wear out.
Sr Member on Sr bikes
Dan
