How deep of snow can you ride in?
Just gota fat bike and waiting for snow. What air pressure do you run in tires in snow?
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times
If it is fresh snow, with no tracks, 4" is about my max. You are making tracks through 4" of snow and that is a lot of resistance to pedal against.
I run 4-5 pounds because I have tubes, but some of my tubeless riding buddies go as low as 3-3 1/2.
The best riding is after the snowmobiles packing down the snow. You can roll faster than on dirt and the roots and rocks are covered over, so it gets to be fast and smooth with lots of traction.
Psi? Less. Rider weight, rim width? Running tubeless? Tire width?
Bicyclerider4life
Bikes: 2018 Lynskey R 260 Disc; 2008 Trek 4.7 Madone; 2017 Framed Minnesota 3.0 Fat Bike; 1984 Nishiki International
Quoted: 111 Post(s)
13 inches fresh now on the road (combination of fresh and tire tracks) worked great yesterday. Tried it on the towpath (no tracks to get moving) and it was an epic fail.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
In addition to the points about tires, tubeless, rims, weight ... Not all snow is created equal, light fluffy pow is ridable when much deeper than heavy wet snow.
With all that said, I'm able to ride 4 inch deep snow consistently and can ride deep snow depending on the condition of the snow.
One last consideration, is the riders strength and bike handling, snow conditions that are ridable for a strong/experience rider will be unridable for a n00bie.
I was hoping to find the answer this week end, then the temperature jumped up and rain melted most of the area I wanted to put tracks in.
Quoted: 175 Post(s)
Are we talking powder or mash potatoes? Chunder from a snowplow? Granular stuff? Flat or slope?
No single answer on this one. I've ridden on snow deep enough to leave the pedal imprint on the side. Had to push on less deep snow.
Quoted: 4409 Post(s)
Liked 1,566 Times
These numbers don't sound significantly different than 2" MTB tires. But I imagine there is a certain snow density where a fat bike can ride on top and an MTB would sink.
meh
Liked 1,013 Times
Today I tested the limits of deep snow... My Dillinger 4 tires couldn't keep my riding in 8 inches of fresh snow. If I was going down a slope, it was OK. But I couldn't get any traction to push up a hill or on the flat sections of trail. I had the front at 3 psi, and found I dropped the rear to 0 psi. I ended up walking when I couldn't get on plowed trails/roads.
Is it because you just can't pedal?
meh
Liked 1,013 Times
The rear tire just spins out on you - no traction. I think you could ride these conditions with 5" tires and bigger knobs on the tires. Surly's Lou is a rear specific designed tire for these kind of conditions. I know a lot of people that love the Bud and Lou combo for snow riding.
Funny enough, I'm going to end up with more tires for my fatbike than the rest of my bikes combined
^^^ Go up to 2 XL.
Broom Wagon Fodder
Bikes: Fuji Supreme; Kona Wo; Nashbar road frame custom build; Schwinn Varsity; Nishiki International; Schwinn Premis, Falcon Merckx, American Flyer muscle bike, Motobecane Mulekick
Quoted: 52 Post(s)
Liked 64 Times
meh
Liked 1,013 Times
My experience also. We rode out to LTD in Hopkins for a couple of beers. I couldn't handle that snow at all. Back wheel kept spinning when I tried to start and when I did get going any rut took me out. Luckily it was only a block and a half to a plowed street and we were able to ride just fine there! I pretty much walked it the last block home.
meh
Liked 1,013 Times
I want to ask about your experiences with deep snow and fat tires:
Do you find it easier to get through deep snow when you reverse the tire pattern on rear tire? Making the rear tire more of a paddle wheel.
Here's a post from the makers of the Dillinger - 45 NRTH: https://45nrth.com/blog/post/pro-tip...tire-direction (yes, this is a promo post)
I typically have my winter tires set up like this post suggests. However, this winter I've been working with a LBS to convert to tubeless (my Marge Lite rims are not tubeless compatible and I want some experienced help). The person that made the tubeless conversion had the rear tire set up like the front tire, good for rolling resistance, bad for traction/grip when pushing in deep snow.
My post above about walking because of 8 inches of fresh snow was on my way back to the LBS for help with a leak in the rim of my rear wheel (free of charge). When they returned my bike, the tech set up the rear tire per the link above and I found it much easier to push through deep snow. Unfortunately, we'd had a big melt day and the snow conditions were very different, so it wasn't a great comparison.
Quoted: 2976 Post(s)
Liked 1,182 Times
There is no magic number that applies to everyone. It all depends on the weight of the person. 3psi for a 200lb person isn't the same as 3psi for a 140 lb person. It's something that has to be experimented with individually.
Jet Jockey
I tried to pull off the path on my Pugsley today by Minnehaha. Don't know how deep the snow was, but it was deeper than 4", and heavy, and I ground to a halt real quick.
Good night...and good luck
Bikes: See Signature...
Quoted: 9 Post(s)
Tried riding my fatbike with Mission Command tires around the yard today. nearly 40, snow was wet and heavy. 2-4" wasn't too bad, but once I got in the 6-8" stuff...forget it, rear tire would spin out. I dropped pressure down pretty low, I'm only 165lbs.
Still was fun to play around. I think in fluffy powder, i would have kept going in the deeper snow. Packed trails? I would have been fine at slower speeds, only limited by the tires (not the best, but they worked well on my driveway which is packed snow) Almost tempted to go ride the snowmobile trails, but... that might not be welcomed lol.
Bikes: Motobecane Vent Noir, Specialized Crux, Specialized Carve
Quoted: 14 Post(s)
I think fat bikes really excel on trails that have either been groomed or gone over by a snowmobile. Fresh snow is tough no matter what.
UnfilteredDregs
General Cycling Discussion
13
12-23-13 10:01 AM
slipknot0129
22
04-01-10 12:58 PM
