Calling all Trek experts on mystery
Cycling addiction
Mysterious trek 620 finally restored
I recently pick up this unknown vintage trek as a parts bike. It had a mix of shimano 600 6200 and 6400 and matrix titan 27x13mm rims , campagnolo grand sport hub, sakae litage Fx fork. Reynolds 531 frame suntour drop out, rack mount, the reason I bought this bike is for the first gen 6400 brake calipers and brake lever for my Schwinn Peloton.
This looks like a very early model like 613 or 614, but I no expert and that why I’m ask for help on this mysterious trek.
Last edited by Danbianchi881; 07-29-18 at 06:33 AM. Reason: Finally finished the bike
Quoted: 5888 Post(s)
Liked 3,471 Times
Looks like a crashed vintage Trek with that fork but the frame may be OK. Still the bike looks a bit abused; what's up with that headtube? Is that tape?
The vintage Trek website is your friend here in ID'ing the bike. With the serial number, you'll be able to ID the bike.
Cycling addiction
Assuming that headbadge is original, it's 1981-83 - no screws attaching it to the frame, which were phased out between 1980 and 1981.
Quoted: 4412 Post(s)
Liked 1,567 Times
Lots of ways to damage a fork that don't hurt the rest of the bike. Or someone just wanted to upgrade to a lighter, softer riding fork. This was clearly a project bike for at least one previous owner.
The headtube tape looks like something an owner did as well.
Quoted: 887 Post(s)
Liked 335 Times
It is a mongrel. I agree with Kontact that the Litage fork may be evidence of damage. Hope the frame is OK.
Liked 1,567 Times
The usual damage you'll find on a bike that killed its fork is bumpyness or paint cracks under the top of the downtube. If that area looks and feels smooth, I wouldn't worry too much about it.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
There were some 5nn and 6nn bikes that used a problematic stamped fork crown that could crack at the sockets. If this is the case, the anomalous fork may be from a fork issue, rather than collision damage.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
The Reynolds 531 decal indicating "butted frame tubes" would be consistent with a 61x, corresponding to what JohnDThompson said. The H Lloyd Cycles Reynolds decal timeline says that decal was used from 1982 on. My 1982 614 has the slightly earlier decal, but since 1982 is a boundary year that doesn't really mean much.
As other have said, the serial number will probably settle everything.
My Bikes
My Bikes
Quoted: 1858 Post(s)
Liked 664 Times
i would start with the S/N and frame details. These bikes are now 35 years old and ANYTHING could have been done to them.
I have an '84 610 that I bought new, and I think this has different rear dropouts, and different seat binder bolt attachment. i think its not a 1984 610.
do you have more complete pics in better light and better focus?
Quoted: 1627 Post(s)
Liked 630 Times
Exactly; flip that baby upside down and read the digits on the bottom bracket. That's your starting point.
Quoted: 360 Post(s)
Liked 328 Times
It is not an 82 61x because they had the rear derailleur cable housing stop on the top of the chainstay. I am going with 83 640 which came with a Tange Levin headset, 531 CS frame and it came in black. The only thing off is that the 640 came with a red head tube. Is that usually a decal or paint?
Andy
Andy
Liked 664 Times
I'm not even sure its a 6xx! The Reynolds Sticker could have been added incorrectly.
Hard to see, buy I think the lugs eliminate 1985 and later.
Danbianchi, please measure the chain stay length and read out the serial number.
Liked 664 Times
i guess it goes without saying you can't measure the head, top, and seat tube angles consistently to 0.1 degree?
Cycling addiction
I think you were right on the money with the year 1983 640, because it did come with campagnolo Gran sport pedals, campy hubs,Cinelli bar and stem. Here a picture of the head tube which I removed the white pin strips and I see red color paint under it.
were you able to get the SN decoded from Vintage trek website?
Cycling addiction
Liked 664 Times
Dan,
There is no arcane secret code here, and it is not a fail for you not to know it. All you need to do is turn the bike upside down, read all the numbers and letters stamped into the bottom of the BB shell, post them all here in this thread, and then one of us here who has a lot of experience with the Trek site (like me) will do all the decoding for you (i.e. open the site and see what it says). We can tell you year, model, any geometry features, original color scheme, size, and original parts list. We can then see if it really is (barring production errors on Trek's end) a 600 series, a tourer, a racing bike of the day, or what.
It's as easy as that.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
And if the numbers aren't on the bottom of the BB shell, they're on the seat tube behind the crank- then its an 84 400 series frame.
Commence to jigglin’ huh?!?!
Liked 3,471 Times
Good point; there are reasons other than a crash why someone might switch out a fork. And the frame may be fine after a crash (if that's why the fork was switched out) which is why a visual inspection helps.
Liked 1,703 Times
I suppose we should stop all the silly conjecture until Dan posts the SN.
Then we can resume with the silly conjecture and flights of wild fancy.
I still say it was the shape shifting lizard overlord aliens. Bent the fork with powers of their minds.
Liked 1,703 Times
So it's refinished, so no paint or decals matter....
got the Trek seat stay caps- 84 and earlier-
no screws in the head badge, 80 and later...
under the BB cable routing, 82/83 and later...
Liked 664 Times
Nice to eliminate the TXs as well.
Liked 1,703 Times
It's got eyelets on the dropouts- so no x60-
