Recover ride from internal storage of Garmin 800
Bikes: Saracen Skyline, Canyon Ultimate, Stanton Switchback, Cotic SolarisMAX
Quoted: 39 Post(s)
The USB connection on my Garmin 800 has died - for a while, I would get an on-screen message that "This device is not supported" when I turned it on (with nothing plugged into the USB), and recently it stopped connecting to my PC when it was plugged in (although it will still charge). I can't see any signs of corrosion around the connector (something they are known for). Anyway - there is a ride on the internal storage (not SD card) I'd really like to copy to my PC. The device apparently doesn't have a feature to copy data from internal storage to SD card. I thought maybe the spring contacts had worn, and tried making a connection with four pieces of thin wire pushed into the holes in the USB socket. I've also taken it apart, and tried to find the USB data lines on the internal inter-board connector, but had no luck.
I'm running out of ideas - does anyone else have any??
Randomhead
Liked 3,701 Times
That stinks. Did you try another data cable?
Quoted: 456 Post(s)
Liked 112 Times
Our Garmin 800 USB port start acting bup last year on tour. I sent it to a guy in Arizona that works on devices. Had a new port and battery installed. Worked great this year while we toured Europe for 3 months!
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
How much trouble and money is one ride worth? Honest question, for everyone the value is different.
Presuming the problem is local to the USB port and its solder connections--you might be able to replace it...if the problem is deeper you may be hosed anyway.
Have you tried a different PC? Sometimes the USB driver on a PC gets messed up. If you only have 1 PC and running Windows go to device manager and delete the USB adapter. Restart the PC to re-install the USB adapter.
Do you use Garmin Connect? You could try connecting to it and uploading rides.
Quoted: 39 Post(s)
I have tried multiple cables and PCs with no joy. The solder connections for the USB socket are on the other side of a PCB that is epoxied in place, so I wanted to see if I have any other options before attacking that.
As for this being worth it - yes, it was a stonking ride. Also, I enjoy fixing things as a hobby, so I don't mind the time too much. I'm not going to spend any money on it though.
Ta,
Andy.
Ta,
Andy.
Quoted: 39 Post(s)
In case anyone is interested - I solved my problem. As the Garmin was already very broken, I decided to unglue the USB board. It came out quite easily in the end, as it was sealed in with a flexible glue and not epoxy. I was then able to clean off the corrosion on the other side, which allowed the USB to work again and I could download my latest rides. FWIW, I got 11 trophies on Strava.
Likes For andy_p:
Quoted: 18883 Post(s)
Liked 10,646 Times
Was the cure fatal?
Quoted: 39 Post(s)
Not necessarily - I could replace the USB connector (or just clean off the corrosion as best I can) and put it all back together. However, the battery holds around 1/3 the charge it used to, and the only replacements I can find are of poor quality. Not sure what I'm gonna do with it yet.
Quoted: 2604 Post(s)
Liked 1,934 Times
If you do get it back together, might be a good idea to start saving your rides to the SD card ...
Liked 10,646 Times
The 800 is still a good computer. I had and used one for most of a decade, from when it was brand new until I lost it. It can do mapping, navigation, and power, which is really the core of what's useful. If you don't want it and it doesn't cost much to revive, it would make a great gift for a young cyclist getting started in the sport.
In any case, I'm glad you got your data.
Quoted: 39 Post(s)
I think you can get a replacement battery pretty cheap, @njkayaker seems to be an expert on this and might have some info.
Quoted: 4260 Post(s)
Liked 1,364 Times
What replacements did you find that are of poor quality?
There are lots of batteries for about $12.
These "NewPower" guys have been selling them for years. Not exactly cheap at $28.
https://www.amazon.com/Edge-800-Repl.../dp/B00JH79K08
I did replace the back on a 800. The back included a battery. It's old but it seems to have a lot of life in it.
Note that there are two different backs for the 800. Garmin changed the position of the connectors sometime in the middle of the production run for the 800.
Some of the 800's use backs that work with the 810.
Yes, it is. I like to see people still get use out of them.
Quoted: 39 Post(s)
Thanks for dropping by!
All of them. The $28 one in the link gets 3 stars (admittedly, I think some of the reviewers have overly optimistic expectations, but still). That same page has a number of Amazon-recommended similar batteries, but they all look the same and get mixed or poor reviews.
Liked 1,364 Times
It's odd that it's that hard to get a reasonable battery.
The 800 does work plugged into an external battery.
I think Garmin will replace it with a refurbished unit for $100.
Quoted: 39 Post(s)
Honestly, it's not that surprising. Garmin don't make replacement batteries (or at least, don't make them available to the public). It's a custom size, and I imagine demand is quite low. I would imagine the cost of making a quality replacement at these low quantities is so high, that only the cheapest manufacturers can make it worthwhile. There's also a good chance these replacements have been sitting around for a few years, which is also not good.
Liked 1,364 Times
The battery I can look at says "Made in Japan, Finished in China".
How many hours/miles do you get out of the replacement battery?
Quoted: 39 Post(s)
Maybe, but without Garmin's quality control, I don't trust unbranded stuff from China. Quite a few of the reviews of similar replacements state it has poor initial capacity (50% - 75% of what is expected), and a poor cycle life (noticeable degradation after a few months).
I haven't bought a replacement battery yet, I was already thinking about what to do with this 800 before the USB recently failed.
Edit: I will check out the NewGen guys, thanks for the tip!
Liked 1,364 Times
Quoted: 550 Post(s)
Liked 325 Times
Randomhead
Liked 3,701 Times
no experience, sounds good for usb repair
https://www.nabilselectronics.com/ga...rsreadthis.htm
