Replacing integrated shifters on an old Trek mtb
I have an old 1996 Trek 7000 mountain bike that I want to keep running, and I need to replace the 7 speed integrated shift / brake levers. Suffice it to say that I ruined the originals.
I sense it’s not as easy as just buying any old Shimano integrated shifter that I can find. Can someone help a newbie understand what knowledge I need to gain in order to properly replace these shifters? Would most 7 speed Shimano Integrated style shifters work (if I can find them)? Would they likely have the same pull ratio? Could modern components possibly be compatible with the old cantilever brakes?
I’m hoping to do it myself so that I can learn, and save the shop fees.
And yes, I’ll be buying a new bike, but this is the bike I want to learn on, in case I decide to build a bike someday. Thanks!
How far down the rabbit hole do you wanna go? Integrated 7 speed shifter/brake levers is gonna be a tough one. Buying used is a crapshoot - you really don't know if the parts is in good serviceable condition.
My recommendation: Get a cheap (on your wallet, not quality) 9 speed groupset - shifter, derailleur, chain. Microshift Advent is a quality groupset I can wholeheartedly recommend - I have it on two bikes. Ditch the front shifter/derailleur and go 1x. 1x chainrings of your gearing choosing can be had for cheap (Amazon/ebay) you don't have to go fancy on a 90s project bike. Plenty of how-to videos on Youtube from Microshift and Park Tool will help guide you with the appropriate tools needed. Oh, if you really wanted to, Advent can be had in an 8 speed version, if that's your jam....
Quoted: 4210 Post(s)
Liked 3,875 Times
Shimano has been producing their EF series for a number of years in 7, 8 and 9 speed versions, some with a brake lever that is convertible from canti to linear pulls. Andy
AndrewRStewart
AndrewRStewart
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.amazon.com/Bike-Shimano-...xpY2s9dHJ1ZQ==
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I work at non-profit where most of the nicer bikes donated have broken/inoperable shifters. I replace shifters like this with salvaged or new parts several times a week. I repair/lubricate most of the others. Cable replacement is easy on these (assuming you can still shift in to high gear). Many times the hardest part is removing old grips. You may need new grips, and you may need to repair dented bar ends. (Use eye protection when filing.)
If there's a bike co-op in your area, they'll have a bin full of salvaged shifters. Staff can help with installation, and getting the proper brake lever for canti or linear pull.
Really Old Senior Member
According to bikeapedia, that bike came with twist shifters,
The main question though is-
Do you have V brakes or canti's?
V brake shifters are easy to find.
Canti's need a 4 Finger version like in the pic. They are convertible to either.
Quoted: 581 Post(s)
Liked 921 Times
It is possible that the shift mechanism can be removed from the integrated shift/bnrake lever and a new shifter can be removed from its mount and bolted in place where the old one came off. This was possible for a abunch of shimano shifters - very likely if the shifter can be removed with one allen head bolt from the top. If the shifter has multiple bolts holding it to the integrated shift/brake lever mount, it is probably not possible.
Another option is to remove the shift mechanism and hacksaw off the part of the mount that does not affect the brake lever, then get a separate 7 speed shift lever to mount beside it. The one possible snag with this strategy is that the exisiting handlebar clamp might be too wide and interfere with some new shift levers.
The best 7 speed shifters I know of are: https://www.amazon.ca/SHIMANO-Altus-.../dp/B0833BY837 but other options are available.
Also, if your bike has V-brakes (linear pull) then just about any modern brake lever will work if you decide you don't want the hassle of combined shift/brake levers.
Quoted: 1944 Post(s)
Liked 2,164 Times
The ST-EF51 shifters that have been noted above are your best bet for ease of replacement, especially since they will work with your cantilever brakes.
The only other option would be to buy separate shifters and brake levers.
Something like a Tektro RT354AG brake levers and separate Shimano shifters like the SL-M315 or equivalent.
I still run 7/8 speed and have both V and canti brakes. I have used integrated 90's shifters and you lose the ability to swap just the shifters (25 years later as you are aware) when it goes bad. I am also a bit leery that the newer shifters will hold up anything close to the older ones that were made with more metal in their construction, which means ongoing integrated replacement.
John
John
Quoted: 581 Post(s)
Liked 921 Times
Also, you can get very inexpensive direct-pull brakes that will bolt on where cantis are removed, and these will work with any new brake levers you can find. Direct pul brakes are, IMO, superior to cantilevers - easier to set up and maintain, and generally better braking.
Thanks, appreciate all the great input. Yes, they are canti brakes, and I might have had the shop replace the twist shifters with index when I bought it, can't remember all the details. I'll search for a bike co-op in Los Angeles area as suggested by andrewclaus, would be great to have some hands-on guidance in the beginning. Thanks again!
