Just got a fixed gear a couple days ago, wanna learn how to skid
Bikes: Fixed Gear
Title basically sums it up, I wanna learn how to skid. I currently dont have pedal straps so that might be an issue. Any tips would be appreciated
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
1. Put your nuts on the stem.
2. Extend dominant leg backwards.
3. Buy new tire.
3. Buy new tire.
It takes a bit for the lifting leg to come around. It's a strange motion for a muscle group that is used to pushing weight not pulling it. I just ride as usual and toss a skid in when needed or wanted. Saves the legs
you usually want to lock the rear (dominant) leg around the 45 degree or so. I ride fixed mtb a lot and can skid pretty readily without straps in place. skip stops are much more effective for actual stopping though - another good one to practice and with both legs.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
On a velodrome everyone is going in the same direction with the same goal so braking would be quite dangerous but on the roads where everything is completely unpredictable braking is extremely important and could save your life when ruining undies, back tires, knees and ankles to uncontrollably slow down a bit could cause issues.
Aesthetics are great but the aesthetics of being a red Jackson Pollock painting on the pavement aren't so good. Also those cool points you think you scored aren't redeemable for anything anywhere and especially not when you couldn't stop in a controllable fashion. If you are around people who have issues with you having brakes, than I would suggest not being around those people as they don't care about you and probably don't care about themselves either.
Also keep in mind this is an old thread not as old as some other zombie threads but this sub-forum is usually pretty dead and has been for quite a while.
Clark W. Griswold
Liked 3,995 Times
Some people more often some people less often but in the end skidding is not stopping and is not really practical in an urban environment. Get brakes and save a ton of money on tires and not be so wasteful.
Likes For veganbikes:
Quoted: 4806 Post(s)
Liked 3,932 Times
I don't skid. I have zero advice on good skidding tires. Contact a shop that sells fix gears. They will know and have the popular tires. I bet a good Google search will tell you also.
