26" for gravel grinding
Old 09-29-14, 10:44 AM
GravelMN
GravelMN's Avatar
Quoted: 75 Post(s)
My current gravel grinder is based on a 1993 Trek 730 frameset that will only clear 700c x 40-42mm tires with any mud clearance. There are a lot of sandy areas around here and a number of the organized gravel events and some of my personal riding takes me on some very loose soft sandy minimum maintenance and single track. The old 730 does an admirable job on a wide variety of surfaces, but sometimes I wish for more tire. A new monstercross or gravel bike is not in the cards right now but I do have a Trek 820 from the same era. It will clear a 26 x 2.1 tire between the chainstays and a 26 x 2.3 up front.
What do you gravel grinders think about using a 26" rigid MTB for gravel grinding? Anyone else using one? Any disadvantage/advantages? I'm not looking to be competitive, just to have fun. I'll probably give it a try this fall anyway, but am interested in hearing others' opinions and experiences.
GravelMN is offline
Old 09-29-14, 11:54 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
So why not ? riding the old Cruiser bike was good enough on Farm Roads , Gravel , for decades ... before Now ..
fietsbob is offline
Old 09-29-14, 12:09 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
Vintage mtbs can make great gravel grinders but fitting drops on them can be a bit of a problem as they typically have long top tubes and were really designed for flat bars. Yes you can get a short stem and fit drops but the handling is not the same. I used trekking bars on mine but then I'm not racing gravel, just riding. Still it makes a great gravel grinder and cheap to boot:
bikemig is offline
Old 09-29-14, 01:17 PM
jcivic00
keep moving forward...
jcivic00's Avatar
Bikes: 2009 Motobecane Fantom CX
Honestly, isn't gravel-grinding essentially mountain biking over longer distances?
jcivic00 is offline
Old 09-29-14, 01:51 PM
Skankingbiker
Skankingbiker's Avatar
Bikes: AllCity Nature Boy, On-one Pompino) , Fuji Roubaix road bike, Niner EMD, Voodoo Hoodoo MTB, Surly Pugsley/Krampug, Performer Midracer Custom
Quoted: 58 Post(s)
Liked 5 Times in 3 Posts
Not really, though it depends on how you define "mountain biking." Most "mountain bikers" do not consider anything wider than singletrack to be "mountain biking"; yes you can ride a mountain bike on gravel, cow paths, etc. And, no reason you CANT ride a mountain bike on gravel roads, although 2.3 tires and 6 inches of suspension is overkill.
An early 90s, 26inch rigid, hardtail "mountain bike" makes a great gravel grinder, although if going long distances, a 700cc wheel will be more efficient.
Skankingbiker is offline
Old 09-29-14, 02:28 PM
jcivic00
jcivic00's Avatar
oh, ok, I consider myself a little more purist and have only ever owned rigid hardtail mtbs. Guess I should have made that distinction. I say run what you brung, let's ride!
jcivic00 is offline
Old 09-29-14, 05:08 PM
Skankingbiker
Quoted: 58 Post(s)
I agree. That stumpjumper would make for a nice GG. I tried outfitting an old 26 rigid hardtail with drop bars. The problem is that the top tubes on the old ones were so long, that setting up drops and maintaining your normal "cockpit length" is nigh impossible.
Old 09-29-14, 10:35 PM
knobster
Bikes: Specialized Roubaix Comp, Soma ES
It would do great in the type of riding you're wanting to do. Might not be as fast as say a cyclocross bike but it'd be more versatile. I have an old 89 Trek 950 MTB that works great for this type of riding. I actually pick it over my cyclocross bike in situations where I'm not familiar with the terrain because many of the forest service roads I ride are STEEP and the 950 has MTB gearing so works great in those type of roads.
Demented internet tail wagging imbicile.
knobster is offline
Old 09-29-14, 10:47 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
My gravel-grinder *is* a rigid MTB. With drops... and fenders... and fixed-gear.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
kidadam
Touring
35
03-23-19 06:27 PM
raria
19
11-11-17 06:15 PM
absoludicrous
18
08-09-16 07:59 AM
thehammerdog
6
06-04-15 06:30 AM
wunderkind
Road Cycling
48
09-02-10 05:09 AM
