Near-Miss: Blocked Sightline Behind Me
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times
Don't make my mistakes.
I was in this situation:
Approaching traffic signal with blocked vision to my rear.
The setup: To access a MUP on a quiet Saturday morning, I used a two-lane road for about 1/3 of a mile to reach the traffic signal. When I entered the road I saw a full-size pickup truck headed in my direction but a long ways away. I took the lane and sure enough, that truck reached me about the time I got near the red traffic signal, which does not reliably trigger with bicycle metal. I was watching the truck (black above) for a signal indication but they did not signal (and they can't go straight). I decided to change to the left lane to make the crossing. I signaled my left before the "paint" of the left lane and checked my mirror and the truck was pretty close to me. I then moved left without looking over my shoulder and heard a honk .. a motorist (yellow above) had pulled out from behind the truck to pass to get to the left turn lane. I can't be sure, but I think we both moved left in the portion that had cross-hatched paint. I didn't hear any skidding so I have to assume they did not have any drama avoiding me.
My reflections on this incident:
1. I’ve been accultured (60 years of immersion) to keep traffic moving so that probably motivated me to move left as my guess was the truck would turn right (which it did). I need to put my safety first and consciously work to change my habits.
2. I remember thinking there was no traffic behind the truck, probably because I didn’t see it at any time on the 1/3 mile stretch. I have to remember that if I can’t see it, I have to assume there is a hazard on the other side.
3. Most of the time I look over my shoulder before changing lanes and I failed to do so this time. I’m not sure I’d have seen the motorist on my normal quick check, but my bad for not looking.
4. My decision on lane position is often last-minute; in some conditions I would use the crosswalk. In retrospect, staying in the right lane was a safer choice.
Looking back over my near-misses and crashes over 60 years, the majority have been related to some kind of vision issue: blockage, glare, lighting. Anytime I can’t see well, the red warning light must come on in my head.
Clearly motorists behaving better (using turn signals, obeying lane markings) would help but in the real world I can only control my own actions.
I welcome other perspectives.
Likes For flangehead:
Quoted: 6196 Post(s)
Liked 4,811 Times
I'd just be thankful that you didn't get hit. I'd also assume that the person person honking at you was in the wrong as it appears they were passing the other vehicle on a stretch that is a solid yellow line and near a intersection where there should be no passing or use of the lane for oncoming traffic.
Crap happens. Don't beat yourself up for it. Just remember to consider that such might happen and be prepared.
Quoted: 5224 Post(s)
Liked 3,585 Times
that close to an intersection, if I'm one of those cars, I just lay back & stay out of the equation
if I was on the bike, I'd pull over & let the traffic pass, or not even get on the road until the traffic passed
I almost got t-boned on my bike, at a road crossing, one time, due to obstructed view. it's a killer
Likes For rumrunn6:
Quoted: 3777 Post(s)
Liked 1,048 Times
It's hard to give a precise evaluation without knowing how close the car was when it honked and at what point they went around the pickup. When I'm coming up to a red light I always take the lane and sometimes a car honks their horn, because I know most cyclist continue to FRAP as they come up to a red light, so it probably confuses them a little.
Not only do I take the lane at a red light, but also at a stop signs and those traffic circles. You're just much more visible in those places, when in the center of the lane, otherwise you can easily enter a blind zone with vehicles turning.
All I can say is what I would have done in that situation.
As I approach the red light, I'm constantly checking my mirror for speed of vehicles behind me and based on that, along with the distance to the light is what determines when I take the lane. I will take the lane in front of a car, as long as I'm not unduly slowing them down. I will physically look behind me at least once before taking the lane, but most of my evaluation is done by looking in my mirror.
As the light turns green, I stay in the middle of the lane, until the car in front of me is well clear, you have to be careful here, because they can turn quickly without turning on their turn signal.
**Also, there can be a entrance point that they are shooting for and it's in a position where the vehicle doesn't make a full 90 degree turn – maybe they only turn 45 degrees, before suddenly turning the opposite direction to enter the gas station (or whatever is at that corner).
**Actually, from your picture, this scenario seemed to apply to you, since the MUP was catty-corner to the intersection.
Fxxxxr
Quoted: 2671 Post(s)
Liked 1,151 Times
there are too too many variables in play to lay down a hard & fast assessment but always remember the bicycler's best move when in a lot of traffic situations is to get to the curb and dismount > i know it aint kool and it is an interruption of your pedaling but you will live to pedal another day
Likes For jack pot:
Quoted: 3956 Post(s)
Liked 7,308 Times
Aside from your admission that you should have looked over your shoulder, I'm not sure did make any mistake.
Many times while driving, I look over my shoulder to check my blind spot before making any lane changes. Then when the lane change is complete, I find another car at my tail and I'm wondering where he all if a sudden appeared from. Either I didn't check carefully enough or the other driver was weaving in and out if traffic.
In your case, I'd bet the driver normally doesn't bother to anticipate anybody in front of the vehicle he is passing. That's why school busses have such a tough time with bad drivers when they let school kids off the bus.
Liked 4,811 Times
Okay, thanks for your more thorough reading and keeping us straight.
Still doesn't really change the results. The honking driver was still the one in the most wrong. The OP was in front and in that case the vehicle behind has to yield to the vehicle or person in front of them. Even when both are where they shouldn't be.
Quoted: 969 Post(s)
Liked 1,631 Times
In Houston you almost ended up being just another Hood Ornament... But this situation presents itself all over the world. I nearly slammed a guy on a moped trying to pass a big rig on a back road. Luckily the rig gave me a tap on the horn and I was able to avoid a mishap.
We all need to stay awake out there... For Sure...
Likes For zandoval:
Liked 7,308 Times
Likes For tomato coupe:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
Situations can be hard to gauge, depending. Glad it worked out, more or less.
Myself, I ride so slowly and have so little power (due to old injuries) that I simply go the most-cautious way in a situation. In the map shown in the OP, I would keep in the right-hand lane, head across the intersection when it turns green, then (keeping right) I'd angle off onto the indicated MUP. That'd keep me from heading into a left-hand lane with known vehicles approaching, and it'd keep me out of that left lane (which many vehicle drivers abhor).
Likes For Clyde1820:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
We are all guilty of letting our guards down from time to time. It's human nature. When there are blind spots, a move out of lane, through an intersection, etc. isn't a single glance process. It's a process of continual evaluation.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
TBH, nit sure what the point of these post mortems is supposed to be. I don't know that there's a lesson to be drawn from a situation involving fluke timing that you probably couldn't duplicte if you tried. I'd like to think that I'd have been into the left turn lane earlier than you were so that the car behind the pickup would have more than enough warning I was there but, not having been there, I think this is just 20/20 hindsight at best.
Likes For livedarklions:
Quoted: 1104 Post(s)
Liked 1,825 Times
Liked 3,585 Times
I'd like to see a helmet cam view of this ride segment
I have found, that some videos I take are boring &/or not worth sharing, but they often help me retrace my steps & I can ponder what I did & other options. Wifey often asks, why are you watching that more than once. I gave up trying to explain
Likes For rumrunn6:
Liked 1,048 Times
I'd also like to see video of this segment, but the next best option is Google Street View, which we could look up if you provide the name of the roads intersecting.
Likes For work4bike:
Likes For mr_bill:
Liked 3,585 Times
Liked 3,585 Times
no shame using the cross walk once you get to the intersection
there's no apparent cycling infrastructure on the roadways (aka we don't matter)
looks like a nice trail in there
Likes For rumrunn6:
Quoted: 390 Post(s)
Liked 572 Times
Patterson Rd and Hwy 6-mr. bill
Be careful out there!
Tragically Ignorant
Liked 9,098 Times
I would point out that the "20/20 hindsight at best" quote you excerpted was my valuation of my own opinion on how to handle it and wasn't a shot at yours or anyone else's opinion.
BTW, I think the feature of a situation like that that I find super frustrating is the weight-triggered traffic light. It just adds another complicating factor into lane placement as you need to leave a car enough room to roll over the trigger. I've also been in too many situations where the presence of such a light leaves me with rolling a red as being the only viable solution.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 462 Times
Similar to the OP, some of my car driving tendencies carry over into my cycling.
I like traffic to flow and generally do my best not to impede others.
In his scenario, I probably would mosey over to that right-side crosswalk and hit the button.
On a busy boulevard, it removes you out of harm’s way, especially if the light takes forever to change.
Tailgating vehicles behind other vehicles bothers me more.
On some of my routes, I find myself riding with nary a shoulder. That tailgater may not see me until the last second.
Likes For roadcrankr:
Tragically Ignorant
Liked 9,098 Times
I think I've spotted the major problem with this intersection--it's the magic road cones. Pull out of this driveway and take a left:
https://www.google.com/maps/@29.8133...8i6656!5m1!1e3
Quoted: 4806 Post(s)
Liked 3,932 Times
If you take a quick look with your mirror as you move to the left of the truck behind you, you will get a good look at that lane to the truck's left. Car? Stay put on the line of the left side of the truck. Mirrors are perfect for that. No need to turn your head (and possible move further left with the weight change). Yes, in my racing days I worked diligently on never veering as I looked but now that I've broken my collarbone and other stuff, that is much harder.
I say this as a user of the Third Eye Helmet Mirror which has excellent field of view. So does the EVT Safe Zone Bicycle Helmet Mirror. Both are better than my car mirrors. (Except my right rear is a huge blind spot. Cars don't fit in it if they are close but bikes do.)
Liked 7,308 Times
