Strong urge to buy a fixed gear
I had one before. A 53cm kilo wt that I regretted selling not long after I did. Loved the bike. The simplicity of riding with no gears and brakes was so engaging and the ease of maintenance made it all the more enjoyable. Wished it was a little lighter and didn't need the extra tire clearance. 32mm is what I like. 165mm cranks that came on it felt better to me than the 175mm on the other bikes I owned before. The geo felt great. Not too twitchy but not too slack either.
Looking to getting something that has the same attributes that the kilo had but lighter. Is there a complete bike that has all those attributes or do I need to buy parts individually? Can it be done for under a grand? I've heard wabi has nice riding frames that are lightweight, but if there are other options too I'd love to hear. Any reccomendations for 165mm cranks, bottom bracket, cogs, decently light but strong enough rims and anything else I would need would be appreciated too. I've put bmx bikes together so piecing a fixed gear together should be doable I would think. Thanks for any help.
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
65mm cranks would be comically small, unless there is a mobility limitation.
Do you mean a 165mm crank?
Also, interesting that you want wider tires and more capabilities, but are intending to ride brakeless?
What type of riding do you do most? Surface and terrain? What's wrong with another WT, and slowly building with lighter parts? If brakes don't matter, why not just a vintage conversion, it would be much cheaper and depending on year 32mm would be no problem.
Lots of variables. Give us some more specifics on what you want, outside of 65mm cranks.
Quoted: 279 Post(s)
Liked 326 Times
Oh, check out St Sheldon Brown for some fixed gear basics. Will provide a general overview, and is pretty solid and a good resource.
Likes For Senrab62:
I don't want wider tires. 32mm is as big as I'd want to go
Not even sure what a vintage conversion is. Not looking to build slowly. I want to just buy everything at once and get to riding.
Just looking to ride around my towns streets.
Quoted: 823 Post(s)
Liked 1,395 Times
Senrab61 mentioned St. Sheldon. His works on fixed-gear bikes are likely THE most influential on the resurgence of fixed-gear cycling in this century. When I first read him and assembled my first fixed-gear in 1998, there were very few dedicated fixed-gear bikes available to purchase. Unfortunately, the bulk of what came along pre-built was very much influenced by track designs with narrow tire clearances, deep dish aero rims and aggressive frame geometry that might be great for a sprint on a board track but is a drag on city streets and quiet back roads. The Kilo WT is kind of an anomaly, being a production fixed-gear with clearance for something larger than a 23-25mm tire.
You used the words "light" and "strong" in the same sentence and mentioned a desire to run 32 mm tires and ride the streets of your town. My experience has been that a light, comfortable-but-nimble frame capable of taking that size tire generally points towards two options. The first is full custom. I have done that, and 20 years later I realize that I honestly would have done better, saved myself a lot of money and had a more flexible, adaptable bike had I simply converted a quality vintage road bike to fixed operation. Over the last decade I have returned to that method, so much so that I have been seriously considering parting with my full custom Mercian.
St. Sheldon explains all of this in detail, but the basic idea is that lots of bikes ranging from pretty good to amazing were sold in the past that can be converted to fixed with relative ease. They'll have clearance for 32 mm tires. They'll have nimble handling - for the road - vs the lightning-quick but possibly twitchy and certainly jarring handling of something inspired by racing on a smooth track. And while you mentioned brakeless riding, I would strongly urge you to run a front brake - that in conjunction with a fixed cog and lockring is the minimum braking standard of the U.K., which is probably the ONLY country with laws about that. The fact that in the U.S. we have crap laws about bike brakes is a reflection of the toy status assigned to bicycling in America.
A lot depends on the mindset you bring to riding. Most of the "ready-to-ride" bikes out there are very track-inspired, built for short fast rides with aggressive geometry. Philosophically, lots of them reflect a hipster pose with styling meant to imply fast, aero dynamic, no-nonsense, hard guy looks by appropriating the style of bike messengers who were themselves appropriating folks who rode brakeless fixed-gears between the world wars. Sheldon's writings are a middle ground, pointing the way to the OTHER fixed-gear cycling tradition, which is primarily British, often revolving around cycling clubs, and demanding a balance of nimble and light combined with the ability to travel long distances in all weather with the capacity to carry light luggage (we would say credit card touring today).
The choice of 32 mm tires is a good one - you can ride city streets, they'll work well on poorly maintained rural roads, and with a bit of skill you can manage gravel and hard packed dirt roads. My best cycling buddy and I rode all of this county's dirt roads on fixed-gears running 28 mm tires, and 32 would be better still. But if you're going for the ride quality of 32s, you might as well look at frames with the right geometry, and the affordable way to that would be converting an old road bike. There are lots of those out there with minimal braze-ons - people will hate you if you have perfectly good fixtures shaved off, so avoid doing that! - and the sort of geometry that was once all out racing that is now considered sport touring. If you're patient and find a good deal, you can then spend your money on some good wheels (NO deep dish stuff!) and a good crankset - and seriously, at least a front brake that works.
Senrab61 mentioned St. Sheldon. His works on fixed-gear bikes are likely THE most influential on the resurgence of fixed-gear cycling in this century.[/url] When I first read him and assembled my first fixed-gear in 1998, there were very few dedicated fixed-gear bikes available to purchase. Unfortunately, the bulk of what came along pre-built was very much influenced by track designs with narrow tire clearances, deep dish aero rims and aggressive frame geometry that might be great for a sprint on a board track but is a drag on city streets and quiet back roads. The Kilo WT is kind of an anomaly, being a production fixed-gear with clearance for something larger than a 23-25mm tire.
Decided I'm going with a complete wabi classic. Is the performance of the sub 15 wheelset for an extra $100 worth it for a guy who will just be riding his town streets with a few minor inclines? I assume they will be plenty strong since I'm only 135lbs.
Quoted: 4806 Post(s)
Liked 3,932 Times
32c tires for a fix gear for someone who weights 135? I'm 150 and have never ridden fixed on bigger than 28c except in winter with the threat or reality of snow and/or ice. And on one bike I set up as a grave fix gear. No brakes? On streets? So you are skidding to stop? I trust you are planning to ride a beefy rear tire you can afford to skid on. Performance? Why ride a light, high end bike with mediocre tires to save a pound on brakes? Good rubber, especially in back, has a much higher performance payoff than the weight and aero of brakes slow you. (And those brake levers double as really nice climb assists if you ever have to go uphill. The calipers allow faster repeatable descents.)
Just words from an old cadger who's been riding fix gear on the road 45 years and 100,000 miles. (And, thanks to brakes, can still do it.) Take 'em as you will.
Likes For 79pmooney:
Fxxxxr
Quoted: 2671 Post(s)
Liked 1,151 Times
brakes brakes brakes at the very least a brake up front ............................... from a guy who has paid his brakeless dues
State Bicycle Black Label
Depends on where you live for availability, but I got a State Bicycle Black Label this year, and it’s both affordable and awesome! Highly recommended. Max tire clearance size for me though has been 28mm (Continental Grand Prix 5000, and super light TPU tubes). Light, cheap and fast. Not quite at 1000 miles so far, but regular 20-40 mile rides, longest single ride 60 miles, max speed 46 mph. Under 18 lbs and under $800.
Likes For highandlowrpm:
Anyone not like the slacker geometry on the wabi classic? I'm this close to buying one but not sure if I would miss the quicker handling of something closer to track geo.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
There's only one solution......buy both.
Likes For Speedway2:
Likes For jack pot:
Quoted: 279 Post(s)
Liked 326 Times
I've never heard anyone say that the Wabi handling was slow, so you'd be fine I'm sure. I have an actual track bike with very precise handling, and while it's a beast, it doesn't get the most miles out of my collection.
What bike has the track like geo you are considering?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1336 Post(s)
Liked 765 Times
A single speed has a freewheel, allowing you to coast. A fixed gear is connected directly to the hub, such that you must continue pedaling.
Wabi is likely the better, overall bike to be ridden on the road. If you were going to ride on the track some, then that might sway your choice.
And also highly recommend the White Industries Dos Eno dual freewheel, so you have two easily adjustable gear ratio options. Would need to change to 3/32” compatible chainring (Wabi has them) and chain, though.
Quoted: 279 Post(s)
Liked 326 Times
I wouldn’t write off a track based bike. Mine gets a lot of road use and is light, responsive and fast. Only gets a little twitchy going down fast hairpin descents at 35-40 mph or so. Have over 600 miles on it, over the past 5 months, including several metric centuries.
Bikes designed for the track are designed for the track and typically are typically harsher, more fatiguing, more chance for toe overlap, less likely to accommodate larger tires, less likely to have accomodations for water cage bosses or fenders, etc. Why would I want a less capable bike?
What makes you think that a road bike, or something designed for road l wouldn't be light, and responsive? Many people say that about Wabi, and they make one of the lighter production steel fixed gears on the market. I only mentioned them as an example. There are multiple option, that would meet your criteria and have water bottle bosses with slightly less aggressive geos.
If you look at my posts I have a pretty broad collection, including conversions all the way to true track. Spice is the variety of life. My next custom, will be more road like in geo and be versatile. Because I mainly ride.on the road. I never wrote off a track specific bikes, I own multiple. Just a point of what would be a better all rounder.
I never wrote it off. And 30-45 mph is crazy! What gear ratio and RPM are you getting to?
Regarding higher speeds, getting up to 35-40mph has been with an adjustment (for me) of dealing with a SS. Down steeper hills or down mountains, due to the gearing, I crank it up to 100-130rpm, and I’ve been practicing this year getting into as aero a tuck as possible to maximize speed and coasting distance (which translates into less energy expended, to save the energy for the other parts of the ride, including standing up climbing for bigger grades, and especially for the longer 40-50+ mile rides). For general riding including hills using 42x17/19, but for flats sometimes swap over to the 50x17/19 (WI Dos Eno 17/19 freewheel).
Btw, I did end up getting a geared road (hybrid) bike, since the 4000ft+ elevation rides were just a bit too much for my SS. But I keep going back to riding the SS bike whenever possible, for the simplicity, workout, lower maintenance and lighter weight.
