tyre help please???
tyre help please???
i have a 700 c wheels and the tyre's on them are 700 x 35 c they where the tyre's that come with them.
would 700 x 24c tyre's fit the rim?
thanks in advanced
thanks in advanced
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
What is the rims inner and outer width? If you don't know that, what rims are they?
Bicycle Repair Man !!!
700c by 35... the c is an old French designation for a wider 622 tyre where 622 is the bead seat measurement and there is no c after the second number which means the tyre is 35mm wide.
Your tyre will have a 622-35 marking which is the best way to measure tyres and the range of tyres that will fit your rim is dependent on the rim width.
Bikes: Litespeed Teramo, Argon 18 Road, Fuji Mt Fuji Pro MTB, Fuji Track Pro FG, & Cannondale Quick CX Cross
I'm 99.9 % positive it will fit.
Your cog is slipping.
FWIW - all of my parts distributors list tires as 650 or 700x__c in their catalogs and on their websites. Whether it's correct or not, it's easy to see why everyone makes that mistake.
Oh, and to the question - I think you will be fine. You are not going to maximize performance, but you probably won't crash. But tell us the rim specs.
I'm only aware of the A, B and C designations. C is narrower than B which is narrower than A.
And Scrod is correct. The manufacturers and distributors have done little to clean up the confusion around various tires sizes. I just speak in BSD and mm width to try and avoid confusion, but that only works if the person you're talking to knows as much about tires as you do.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
thanks for all the help i was just worried about the 700 x 24 c wheel would be to skinny for the rim thaks for all of the help will order the tyre and hope for the best :0 thanks everyone
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
65er was correct. The original 700C tire was wider than the 700A and 700B. The issue is confused because we mostly see skinny tires on 700C rims. Same deal for 650C.
