How taut should the chain be?
On my Schwinn Madison, when I replace my rear wheel I generally make the chain pretty taut but not as taut as possible. I obviously don't use stops or spacers (don't know the proper names). I'm wondering about efficiency. Should there be any or much slack in the chain? How best to measure proper chain tension?
Thank you.
Thank you.
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
slack is whack. it should be tight enough to play feudin banjos and give a nice crunchy washboard rhythmic with every revolution as it eats away your drivetrain.
First of all, it's dueling banjos. I was really hoping for intelligent and helpful answers. I guess your avatar truly represents who and what you are.
dumb
Quoted: 174 Post(s)
tight but not so much that it causes binding... about 1/4”-1/2” of play
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Every system I've ever worked on always had a variance in slack / tightness as it spins. I'm guessing they all do... some more than others. I like to find the tightest spot and make sure it has the tiniest amount of slack possible. Then the looser spots in the revolutions will naturally have more. I'm quite meticulous so this can take several adjustments before I'm satisfied.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I don't like the feeling of having lots of slack in the chain.
Too much lash I let off and increase pedal force is really annoying. It feels like the prawls in a freehub engaging.
Right or wrong, I try to tighten the chain enough so that there is very little slack but no so much that the chain is completely taunt.
-Tim-
-Tim-
Quoted: 1074 Post(s)
Liked 295 Times
The general recommendation IMO is that is should be possible to lift the chain about 1/2” mid-run at the tightest spot.
You can shrink this down a little If you’re real meticulous in checking that you’ve really found the tightest spot, and set the chain with a little slack there.
Quoted: 2952 Post(s)
Liked 3,106 Times
1/2 inch sounds right. Enough that it makes a little *tunk* in the pedals when I trackstand at a light.
Quoted: 278 Post(s)
Liked 122 Times
https://www.bikeforums.net/search.php?searchid=4609301
Thank you for your responses.
Mouse...Probably 90% of the stuff on BF could be googled but I trust the riders on BF more than Google users who may or may not know what they are talking about.
dumb
Quoted: 174 Post(s)
Happy riding ✌🏻
Beausage is Beautiful
Bikes: Nabiis Alchemy
Quoted: 20 Post(s)
Liked 13 Times
Yeah, this had already been discussed to death on this forum 15 years ago. The years pass, but people still can't use the search function. A dance as old as the internet itself.
Yo. Everything I’m doing is linked on What’s up with Dave? but most of note currently is Somewhere in Japan.
Quoted: 49 Post(s)
Liked 11 Times
I used to set my chain very tight because I hated chain noise while riding.
However, a very tight chain will wear your drivetrain down.
I'll add that you should be able to rotate freely and smoothly through your tight spot (all chainrings are oval, very few chainrings -- like the sugino super zen -- are made to be as round as possible).
You and I are not spending $350+ on a chainring so here's the other part of the taughtness:
I would say that checking for "skippage" is more important than free spinning at the tight spot.
Let's call "skippage" the probability of the chain ring hopping off the chain.
High skippage means your chain is likely to fall off.
This is very important on a fixed gear. If your chain falls off, bye bye (unless you've practiced emergency stopping maneuvers).
i check this by putting a tire lever between the chain and the chainring with just a little bit of pressure. Just enough to try and "nudge" it off the chainring.
Then, rotate your cranks in the direction of sandwiching your tire lever between your chainring and chain.
If your chain falls off while doing this, it's not tight enough.
Sort of liberally check this around the whole chain.
I would put much more importance on low skippage than I would on drivetrain wear, but no even semi decent setup will be so oval that you can't get into the goldilocks zone.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I've never been able to make measurements and numbers work for me on this. I just put the bike on the stand, spin the cranks, and sight down the top run of the chain. If there's more than a tiny bit of droop at the tightest point, I'll tighten the chain and spin the cranks again. If it pulls completely straight at any point, I'll loosen it again.
This method gives a pretty free-running drivetrain without excessive slack.
Fresh Garbage
Quoted: 4806 Post(s)
Liked 3,932 Times
I like about a half inch of slack.. My QAD (quick and dirty) practice is to pull the wheel back hard with my left hand at the chainstay, also pulling the tire over to the left. Tighten right hub nut just enough. Center the tire and do the same with the left nut, Check chain slack with the wrench, Spin the cranks ~1/2 turn and repeat check. If good, fully tighten the right, then the left. If not, dial in with the right, tighten, then center and tighten the left. Done. (My routine for on-the-road wheel flips.) I never want to see the chain go straight. More than 1/2" of slack max is OK assuming chainring and chain are in decent shape and the chainline is good.
Oh, Eurasia cogs and $20 Izumi chains, everything 1/8". Cogs are cut square, chain plates are not finished off. Slightly rough and noisy, Very secure. (Go to a velodrome and you will see a lot of riders on budgets riding the same.)
Ben
Ben
