Seat clamp torque...
Clamp torque value...
...for alloy seat post in carbon frame?
It's not on manufacturers web site.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Who knows with so much information?
Quoted: 839 Post(s)
Liked 1,062 Times
Yes, more info needed. There are no universal CF seat tube clamp bolt fastener torque values. Just knowing what make/model your bike is can help you find this info with a quick google search too.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
The saddle has a carbon frame and rails? Seat clamp = the the clamp that secures the saddle to the post? Or you talking about the frame clamp on the seatpost? If so, is the seatpost carbon.
edited
Advocatus Diaboli
Liked 1,533 Times
7Nm
Quoted: 6196 Post(s)
Liked 4,810 Times
Just tighten it enough to not slip.
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
The pressure on your post won't be a problem, its most likely the thread in the clamp that you need to watch.
Start with 5nm for a 4mm hex head bolt or 6nm for a 5mm hex head bolt, and put some insulation tape 1cm above the clamp to monitor if your post stays at the right height.
Likes For SquishyBiker:
